I am trying to get Infrared remote control working with a Teensy LC.
The code compiles and works perfectly with Teensy 3.0 and 3.1 ( don't have a 3.2 yet).
I've had good luck with using the IRlib library that another user here on the forum adapted to work with the Teensy 3.0 and 3.1
The code compiles and works fine for Teensy 3.0 and 3.1 and based on what I see in kinetis.h likely also with 3.2.
However when I select the Teensy LC as the board the compiler complains about "IRQ_CMT' was not declared in this scope:
And sure enough the section for Teensy LC is missing such a definition while hit's present in the Teensy 3.0/3.1/3.2 sections.
Any help and suggestion is appreciated.
