Results 1 to 4 of 4
Thread: Atmel Qtouch and Qmatrix
    162
    Hello!
    I am curious if anyone out there has tried getting Teensy to work with the Atmel Qtouch or Qmatrix touch sensor chips?
    I am making a QT1481 touch sensitive board (Qmatrix methodology) and am going through the available Qtouch AVR libraries from Atmel, but if someone has already made progress, it would be super helpful!
    Thank you!
    Tenkai
    May 2013
    San Jose, CA
    700
    The Teensy support for touchRead() is so good that adding another device to do capacitive seems like it would only complicate things.
    Sep 2019
    Sevilla, Spain
    55
    Quote Originally Posted by pictographer View Post
    as far as I know the Teensy 4 processor does not support touch pins at all, so you can't use the touchRead library,
    plus the Qmatrix allows 64 touch pads, which is way far of the possibilities of the previous Teensy boards
    Sep 2019
    Sevilla, Spain
    55
    Quote Originally Posted by tenkai View Post
    Tenkai
    I would like to use the Atmel AT42QT2640, are those libraries usable with Arduino/Teensyduino? because I haven't seen nothing 'open'
