fuzzylogic
New member
Hi All,
I am trying to make the Teensy++ 2.0 communicate with WIZ820io module, but with no success. When I compile and upload the WebServer example, the following message appears in the console window "server is at 0.0.0.0". Moreover, when I try to see through the w5100.cpp file which chip is selected, the response I get is that no chip was found.
Any ideas? I am using Arduino IDE 1.6.5 and Teensyduino 1.26. I used the following wiring to connect the Teensy++ 2.0 with the WIZ820io module:
9 ->RESET
10 -> SS
11 -> MOSI
12 -> MISO
13 -> SCLK
Extrenal 3.3V Power Supply -> VIN33,VIN33
GND -> GND,GND,GND
Thanks in advance!
9 ->RESET
10 -> SS
11 -> MOSI
12 -> MISO
13 -> SCLK
GND -> GND,GND,GND
Thanks in advance!
