//LCD & SHIELD Libraries
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
//#include <usb_keyboard.h>
// LCD backlight color
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
//Pushbuttons Debounce Library
#include <Bounce.h>
//Midi Library
#include <MIDI.h>
const int MIDI_CHAN = 5;
//buttons on following pins, left to right, top to bottom: {2,3,4,5,/*6,*/7,8,9,10,/*11,*/12,20,21,22,/*23*/}
#define BUTTONBANK 6 //bankswitch button
#define BUTTONSTOP 11 //stop button (not part of bank)
#define BUTTONPLAY 23 //play (not part of bank)
int buttonaPins[] = {2, 4, 7, 9, 12, 21}; //button group a, responsible for sending start go and stop ctrl msgs
int buttonbPins[] = { 3, 5, 8, 10, 20, 22}; //button group b, responsible for sending clear and del msgs
#define BOUNCE_T 50 //bounce time in ms
#define CTRLBUTTONSA_N 6 //ctrl A buttons used to trigger loopers
#define CTRLBUTTONSB_N 6 //ctrl B buttons used to redo/clear
#define CTRL_PLAY 65 //begin of control values available to footpedal (71-128)
#define CTRL_STOP 66
#define CTRL_RACK 67 //CTRL value for instrument rack changes
#define CTRL_RECSTART 68 //start of ctrl values for rec buttons (number up in forloop)
#define CTRL_STOPSTART 80 //start of ctrl values for stop buttons (number up in forloop)
#define CTRL_CLEARSTART 92 //start of ctrl values for clear buttons (number up in forloop)
#define CTRL_TRACKSTART 104 //start of ctrl values for track on/off buttons (number up in forloop)
#define CTRL_UNDOSTART 116 //start of ctrl values for undo buttons (number up in forloop)
#define NUM_CTRLBANKS 2 //bank variables
#define NUM_RACKBANKS 2
int ctrlbank = 0; //two banks, 0 and 1
int rackbank = 0;
int ctrlbankadd = 0; //add variable, bankadd = bank * CTRLBUTTONS_N
int rackbankadd = 0;
bool bankBool = false;
int holdTime = 1500;
int doubleTime = 300;
int rackvar = 0;
bool racktimeBool = false;
unsigned long millisTime=0; //time counter
unsigned long bankTime=0;
unsigned long clearallTime=0;
bool stoppressBool=false;
bool clearallBool=false;
bool recaBool[CTRLBUTTONSA_N] = {true, true, true, true, true, true};
bool recbBool[CTRLBUTTONSA_N] = {true, true, true, true, true, true};
bool recapressBool[CTRLBUTTONSA_N] = {false, false, false, false, false, false};
bool recbpressBool[CTRLBUTTONSA_N] = {false, false, false, false, false, false};
bool doubleaBool[CTRLBUTTONSA_N] = {false, false, false, false, false, false};
bool doublebBool[CTRLBUTTONSB_N] = {false, false, false, false, false, false};
bool doubleapressBool[CTRLBUTTONSA_N] = {false, false, false, false, false, false};
bool doublebpressBool[CTRLBUTTONSB_N] = {false, false, false, false, false, false};
bool doubleacountBool[CTRLBUTTONSA_N] = {false, false, false, false, false, false};
bool doublebcountBool[CTRLBUTTONSB_N] = {false, false, false, false, false, false};
unsigned long doubleaTime[CTRLBUTTONSA_N]={0,0,0,0,0,0};
unsigned long doublebTime[CTRLBUTTONSB_N]={0,0,0,0,0,0};
int x=0;
bool holdaBool[CTRLBUTTONSA_N] = {false, false, false, false, false, false};
bool holdbBool[CTRLBUTTONSB_N] = {false, false, false, false, false, false};
bool holdapressBool[CTRLBUTTONSA_N] = {false, false, false, false, false, false};
bool holdbpressBool[CTRLBUTTONSB_N] = {false, false, false, false, false, false};
unsigned long holdaTime[CTRLBUTTONSA_N]={0,0,0,0,0,0};
unsigned long holdbTime[CTRLBUTTONSB_N]={0,0,0,0,0,0};
Bounce buttonBank = Bounce(BUTTONBANK, BOUNCE_T);
Bounce buttonStop = Bounce(BUTTONSTOP, BOUNCE_T);
Bounce buttonPlay = Bounce (BUTTONPLAY, BOUNCE_T);
Bounce buttonsA[6] = {
Bounce (buttonaPins[0], BOUNCE_T),
Bounce (buttonaPins[1], BOUNCE_T),
Bounce (buttonaPins[2], BOUNCE_T),
Bounce (buttonaPins[3], BOUNCE_T),
Bounce (buttonaPins[4], BOUNCE_T),
Bounce (buttonaPins[5], BOUNCE_T),
Bounce buttonsB[6] = {
Bounce (buttonbPins[0], BOUNCE_T),
Bounce (buttonbPins[1], BOUNCE_T),
Bounce (buttonbPins[2], BOUNCE_T),
Bounce (buttonbPins[3], BOUNCE_T),
Bounce (buttonbPins[4], BOUNCE_T),
Bounce (buttonbPins[5], BOUNCE_T),
void setup(){
pinMode (BUTTONBANK, INPUT_PULLUP);
pinMode (BUTTONSTOP, INPUT_PULLUP);
pinMode (BUTTONPLAY, INPUT_PULLUP);
pinMode(buttonaPins[0], INPUT_PULLUP);
pinMode(buttonaPins[1], INPUT_PULLUP);
pinMode(buttonaPins[2], INPUT_PULLUP);
pinMode(buttonaPins[3], INPUT_PULLUP);
pinMode(buttonaPins[4], INPUT_PULLUP);
pinMode(buttonaPins[5], INPUT_PULLUP);
pinMode(buttonbPins[0], INPUT_PULLUP);
pinMode(buttonbPins[1], INPUT_PULLUP);
pinMode(buttonbPins[2], INPUT_PULLUP);
pinMode(buttonbPins[3], INPUT_PULLUP);
pinMode(buttonbPins[4], INPUT_PULLUP);
pinMode(buttonbPins[5], INPUT_PULLUP);
lcd.begin(16, 2); //LCD START
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("START");
Serial.println("serial start");
void loop(){
millisTime = millis(); //time var running WHATS THE MAX MILLIS VALUE?
while (usbMIDI.read());
readButtons();
if(buttonBank.fallingEdge() && racktimeBool==false) { //bank button
ctrlbank++;
ctrlbank %= NUM_CTRLBANKS;
ctrlbankadd = ctrlbank * CTRLBUTTONSA_N;
bankTime=millisTime;
bankBool=true;
Serial.print("CTRL Bank ");
Serial.println(ctrlbank);
lcd.clear();
lcd.print("CTRL Bank ");
lcd.print(ctrlbank);
if (buttonBank.risingEdge()) {
bankBool=false;
if (millisTime-bankTime>=holdTime && bankBool==true && racktimeBool==false) {
bankBool=false;
ctrlbank=ctrlbank-1;
racktimeBool = true;
Serial.println ("Rack Time");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("RACKTIME BABY");
rackbank=0;
if (racktimeBool==true){ //RACKTTIME BABY time to choose your rack
if(buttonBank.fallingEdge()) {
rackbank++;
rackbank %= NUM_RACKBANKS;
Serial.print("Rack Bank ");
Serial.println(rackbank);
lcd.clear();
lcd.print("Rack Bank ");
lcd.print(rackbank);
rackbankadd = rackbank * (CTRLBUTTONSA_N+CTRLBUTTONSB_N);
bankBool=true;
bankBool=false;
if (millisTime-bankTime>=holdTime && bankBool==true && racktimeBool==true) {
bankBool=false;
rackbank=rackbank-1;
Serial.println ("Control Time");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("YOU GOT CONTROL!");
if (buttonStop.fallingEdge()) {
rackvar = rackvar+1;
if (rackvar>23) rackvar=0;
sendrackVar();
if (buttonPlay.fallingEdge()) {
rackvar = rackvar-1;
if (rackvar<0) rackvar=23;
sendrackVar();
for(int i=0; i<CTRLBUTTONSA_N; i++){
if (buttonsA[i].fallingEdge()) {
rackvar=(i*2)+rackbankadd;
sendrackVar();
for(int i=0; i<CTRLBUTTONSB_N; i++){
if (buttonsB[i].fallingEdge()) {
rackvar=(i*2)+rackbankadd+1;
sendrackVar();
else if (racktimeBool==false){ //CONTROL TIME time to send looper controls
if (buttonStop.fallingEdge() && stoppressBool==false) { //if press is registered and button is not pressed
clearallTime=millisTime; //start clear all counter
stoppressBool=true; //button is pressed
clearallBool=true; //expect clear all
if (buttonStop.risingEdge() && stoppressBool==true && clearallBool==true) { //if button is raised and it was pressed before and clearall was expected
usbMIDI.sendControlChange((CTRL_STOP), 127, MIDI_CHAN); //send a stop message
usbMIDI.sendControlChange((CTRL_STOP), 0, MIDI_CHAN);
for(int i=0; i<12; i++){
usbMIDI.sendControlChange(CTRL_STOPSTART+i, 127, MIDI_CHAN); //we send stop messages
stoppressBool=false; //but is not pressed anymore
clearallBool=false; //we do not exect a clearall
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Stop ");
Serial.println(String("ch=") + MIDI_CHAN + (", Control=") + (CTRL_STOP) + ("Velocity=127"));
Serial.println(String("ch=") + MIDI_CHAN + (", Control=") + (CTRL_STOP) + ("Velocity=0"));
if (millisTime-clearallTime>=holdTime && clearallBool==true && stoppressBool==true) { //if time has run out and we still expect a clearall and the button is pressed
usbMIDI.sendControlChange(CTRL_CLEARSTART+i, 127, MIDI_CHAN); //we send clearall messages
clearallBool=false; //we do not expect a clearall
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Loopers cleared");
if (buttonStop.risingEdge() && stoppressBool==true && clearallBool==false) { //if button is released and was pressed and we do not expect a clearall
stoppressBool=false; //button is not pressed anymore
usbMIDI.sendControlChange(CTRL_CLEARSTART+i, 0, MIDI_CHAN);
delay(3);
usbMIDI.sendControlChange((CTRL_PLAY), 127, MIDI_CHAN);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Play ");
Serial.println(String("ch=") + MIDI_CHAN + (", Control=") + (CTRL_PLAY) + ("Velocity=127"));
if (buttonPlay.risingEdge()) {
usbMIDI.sendControlChange((CTRL_PLAY), 0, MIDI_CHAN);
Serial.println(String("ch=") + MIDI_CHAN + (", Control=") + (CTRL_PLAY) + ("Velocity=0"));
for(int i=0; i<CTRLBUTTONSA_N; i++){ //BUTTON GROUP A
if (buttonsA[i].fallingEdge() && recaBool[i]==true) { //if ctrlabutton is pressed and if we are waiting for a rec 127
usbMIDI.sendControlChange((CTRL_RECSTART+ctrlbankadd+i), 127, MIDI_CHAN); //we send a rec ctrl message
recaBool[i]=false; //we are not waiting for a rec 127
recapressBool[i]=true; //we are ready to send the 0 value for rec
holdaTime[i]=millisTime; //hold time is starting
holdaBool[i]=true; //we are waiting for a hold
Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_RECSTART+ctrlbankadd+i) + (" Velocity = 127 "));
lcd.clear();
lcd.setCursor(0,0);
lcd.print("REC CTRL ");
lcd.print(CTRL_RECSTART+ctrlbankadd+i);
lcd.setCursor(0,1);
lcd.print("127");
if (buttonsA[i].risingEdge() && recapressBool[i]==true) { //if the button gets released and if we were ready for a 0 rec value
usbMIDI.sendControlChange(CTRL_RECSTART+ctrlbankadd+i, 0, MIDI_CHAN); //we send the 0 rec value
recapressBool[i]=false; //we are not ready for a rec 0
doubleaBool[i]=true; //we are ready for a double 127
doubleaTime[i]=millisTime; //double press time is starting
doubleacountBool[i]=true;
holdaBool[i]=false; //we are not ready for a hold 127
Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_RECSTART+ctrlbankadd+i) + (" Velocity = 0 MOMENTARY "));
lcd.clear();
lcd.setCursor(0,0);
lcd.print (CTRL_RECSTART+ctrlbankadd+i);
lcd.setCursor(0,1);
lcd.print("0");
if (millisTime-doubleaTime[i]>doubleTime && doubleacountBool[i]==true){ //if double press time has run out
recaBool[i]=true; //we are ready for a rec 127
doubleaBool[i]=false; //we are not ready for a double 127
doubleacountBool[i]=false;
else if (buttonsA[i].fallingEdge() && millisTime-doubleaTime[i]<=doubleTime && doubleaBool[i]==true){ //if double press has not run out and we are waiting for a double 127
usbMIDI.sendControlChange(CTRL_STOPSTART+ctrlbankadd+i, 127, MIDI_CHAN); //we send a double press stop ctrl value
doubleapressBool[i]=true; //we are ready for a double 0 value
holdaTime[i]=millisTime; //we are again starting the hold clock
holdaBool[i]=true; //we are waiting for a hold 127
Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_STOPSTART+ctrlbankadd+i) + (" Velocity = 127 "));
lcd.clear();
lcd.setCursor(0,0);
lcd.print("STOP CTRL ");
lcd.print(CTRL_STOPSTART+ctrlbankadd+i);
lcd.setCursor(0,1);
lcd.print("127");
if (buttonsA[i].risingEdge()&& doubleapressBool[i]==true){ //if we are ready for a double0 and it happens
usbMIDI.sendControlChange(CTRL_STOPSTART+ctrlbankadd+i, 0, MIDI_CHAN); //we send a 0 stop value
doubleapressBool[i]=false; //we are not ready for a double 0
holdaBool[i]=false; //we are not anymore waiting for a hold
Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_STOPSTART+ctrlbankadd+i) + (" Velocity = 0 "));
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("0");
if (millisTime-holdaTime[i]>=holdTime && holdaBool[i]==true) { //if we are ready for a hold 127 and it happens
delay (4);
delay (4);
usbMIDI.sendControlChange(CTRL_CLEARSTART+ctrlbankadd+i, 127, MIDI_CHAN); //we send the clear message
holdaBool[i]=false; //we are not anymore waiting for a hold127
holdapressBool[i]=true; //we are ready for a hold0
Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_CLEARSTART+ctrlbankadd+i) + (" Velocity = 127"));
lcd.clear();
lcd.setCursor(0,0);
lcd.print("CLEAR CTRL ");
lcd.print(CTRL_CLEARSTART+ctrlbankadd+i);
lcd.setCursor(0,1);
lcd.print("127");
if (buttonsA[i].risingEdge()&& holdapressBool[i]==true) { //if we are ready for a hold0 and the buttons rises
usbMIDI.sendControlChange(CTRL_CLEARSTART+ctrlbankadd+i, 0, MIDI_CHAN); //we send the 0 clear message
recaBool[i]=true;
holdapressBool[i]=false;
Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_CLEARSTART+ctrlbankadd+i) + (" Velocity = 0 "));
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("0");
for(int i=0; i<CTRLBUTTONSB_N; i++){ //BUTTON GROUP B TRACK ON/OFF and UNDO
if (buttonsB[i].fallingEdge() && recbBool[i]==true) { //if ctrlbbutton is pressed and if we are waiting for a rec 127
recbBool[i]=false; //we are not waiting for a rec 127
recbpressBool[i]=true; //we are ready to send the 0 value for rec
holdbTime[i]=millisTime; //hold time is starting
holdbBool[i]=true; //we are waiting for a hold
if (buttonsB[i].risingEdge() && recbpressBool[i]==true) { //if the button gets release
doublebBool[i]=true; //we are ready for a double 127
doublebTime[i]=millisTime; //double press time is starting
doublebcountBool[i]=true;
holdbBool[i]=false; //we are not ready for a hold 127
if (millisTime-doublebTime[i]>doubleTime && doublebcountBool[i]==true){ //if double press time has run out
recbBool[i]=true; //we are ready for a rec 127
doublebBool[i]=false; //we are not ready for a double 127
doublebcountBool[i]=false;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("HAA, TOO SLOW!!!");
else if (buttonsB[i].fallingEdge() && millisTime-doublebTime[i]<=doubleTime && doublebBool[i]==true){ //STOP if double press has not run out and we are waiting for a double 127
//usbMIDI.sendControlChange(CTRL_TRACKSTART+ctrlbankadd+i, 127, MIDI_CHAN); //we send a double press stop ctrl value
doublebpressBool[i]=true; //we are ready for a double 0 value
holdbTime[i]=millisTime; //we are again starting the hold clock
holdbBool[i]=true; //we are waiting for a hold 127
/*Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_TRACKSTART+ctrlbankadd+i) + (" Velocity = 127 "));
lcd.clear();
lcd.setCursor(0,0);
lcd.print("TRACK CTRL ");
lcd.print(CTRL_TRACKSTART+ctrlbankadd+i);
lcd.setCursor(0,1);
lcd.print("127");*/
if (buttonsB[i].risingEdge()&& doublebpressBool[i]==true){ //if we are ready for a double0 and it happens
x++;
if (x>1) x=0;
if (x==0){
usbMIDI.sendControlChange(CTRL_TRACKSTART+ctrlbankadd+i, 0, MIDI_CHAN); //we send a 0 track value
Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_TRACKSTART+ctrlbankadd+i) + (" Velocity = 0 "));
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("0");
if (x==1){
usbMIDI.sendControlChange(CTRL_TRACKSTART+ctrlbankadd+i, 127, MIDI_CHAN); //we send a 127 track value
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("127");
doublebpressBool[i]=false; //we are not ready for a double 0
holdbBool[i]=false; //we are not anymore waiting for a hold
if (millisTime-holdbTime[i]>=holdTime && holdbBool[i]==true) { //if we are ready for a hold 127 and it happens
usbMIDI.sendControlChange(CTRL_UNDOSTART+ctrlbankadd+i, 127, MIDI_CHAN); //we send the undo message
holdbBool[i]=false; //we are not anymore waiting for a hold127
holdbpressBool[i]=true; //we are ready for a hold0
Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_UNDOSTART+ctrlbankadd+i) + (" Velocity = 127"));
lcd.clear();
lcd.setCursor(0,0);
lcd.print("UNDO CTRL ");
lcd.print(CTRL_UNDOSTART+ctrlbankadd+i);
lcd.setCursor(0,1);
lcd.print("127");
if (buttonsB[i].risingEdge()&& holdbpressBool[i]==true) { //if we are ready for a hold0 and the buttons rises
usbMIDI.sendControlChange(CTRL_UNDOSTART+ctrlbankadd+i, 0, MIDI_CHAN); //we send the 0 clear message
recbBool[i]=true;
holdbpressBool[i]=false;
Serial.println(String(" ch= ") + MIDI_CHAN + (", Control = ") + (CTRL_UNDOSTART+ctrlbankadd+i) + (" Velocity = 0 "));
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("0");
void readButtons(){
buttonBank.update();
buttonStop.update();
buttonPlay.update();
buttonsA[i].update();
buttonsB[i].update();
void sendrackVar(){
usbMIDI.sendControlChange(CTRL_RACK, rackvar, MIDI_CHAN);
Serial.print(" Rack Nr ");
Serial.println(rackvar);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Rack Nr: ");
lcd.print(rackvar);
