MIDI.h says...
...but the date on that file is older than Teensy 3 (which introduced 3 serial ports). Am I supposed to be able to "#define USE_SERIAL_PORT Serial3" now? Or can this be handled in the sketch?Code:// Use Serial1 on all Teensy boards, because Serial is USB virtual serial // Arduino.h must be included before MIDI.h to define CORE_TEENSY #if defined(CORE_TEENSY) #undef USE_SERIAL_PORT #define USE_SERIAL_PORT Serial1 #endif
