Teensy 3.2 3D Model
I just made this 3D model of the Teensy 3.2. I designed it as a visualization model and something that I could use to help me model enclosures etc.... I used a combination of the library file posted here:
https://www.pjrc.com/teensy/eagle_lib.html
and physical measurements/observations of my existing board. It is not by any means uber precise, and I haven't finished adding the pads and traces to the board. The bottom is incomplete.
I'll update it as I finish it.
https://www.dropbox.com/s/o39lxf25mg...y_3-2.stp?dl=0
Here is the updated 3D Model, hosted on GrabCAD:
=> Traces on Top and Bottom are finished.
=> Sub Component Positions are refined.
=> Silkscreen layer was added for visualization purposes.
=> Crystal for RTC added to the bottom.
https://grabcad.com/library/teensy-3-2-1
Enjoy!
Aaron
Here are renders of the current 3D Model.
Very nicely done. Thanks for sharing!
Very nice! I've added a link to this thread.
http://www.pjrc.com/teensy/eagle_lib.html
Nice job. For the Rhino ver., I moved the real time clock oscillator to it's own layer. Thanks!
Thanks for the 3D model but boy that Teensy 3.2 is tough to mount...
I've not 3D printed this yet but it's tough to get any place to hold the board down.
I'm putting the pins in sticking up so jumper wires can be easily installed and still have access to the LED and button.
I was hoping to just capture the PCB on the edge but the pin holes are so close to the edge the solder could leave only .5mm at best.
- You may not post replies
- You may not edit your posts
Forum Rules
