Hi Community.
Trying to set up a configuration in witch the teensy ++ is master, and comunicates with the slave (teensy 3.2).
Found out that the ++ is using port 0 and 1 and the 3.2 is using 18 and 19 for sda scl.
Problem is that I also has a audio bord piggybacked to the 3.2. so this pins are used up on the 3.2
Any one know how to solve this?? guess the audio boad has its own adress and i that i can set another adress to the 3.2 or ???
Or is there another way to set up com between to teensy ??
Best wiches
Tore
Best wiches
Tore
