Hi all,
I have a project in mind in which I would like to use 2 times RS232 and ehternet. Teensy 3.2 looks perfect, the Wiz820io looks perfect and the adapterboard offers additional SD which I might use as well.
It's however not clear to me from the description if I can use 2 times RS232 (HW wise, not SW wise) together with the Wiz820 and SD. Serial1 (pin 0/1) should be ok, Serial 2 (pin 9/10) can not be used, but what about Serial 3? There is some description about pin 8 and jumper pads left side but I don't understand what that means, could anyone explain?
thank you and happy new year to all,
Jef
Jef
