I have a teensy 3.2 with the OctoW2811 adapter. I'm using WS2812B LED strips. I have only wired 4 channels. I've cut strips of 30 and each channel has back and forth rows of 4, so each channel has 120 LED's.
I'm using the 'BasicTest' example from your page. It seems when I plug in my power supply what ever LED's come on at that time is all that will come on. I've added the slow blinky LED on the teensy board so I can see something twinkle.
I'm using Arduino 1.6.7 under linux Kubuntu. Under tools settings I have board set to teensy 3.1/3.2. USB type serial. CPU speed 96 MHz optimized over clocked. Programmer is set to AVRISP mkll. What should these settings be?
/* OctoWS2811 BasicTest.ino - Basic RGB LED Test
http://www.pjrc.com/teensy/td_libs_OctoWS2811.html
Copyright (c) 2013 Paul Stoffregen, PJRC.COM, LLC
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
Required Connections
pin 2: LED Strip #1 OctoWS2811 drives 8 LED Strips.
pin 14: LED strip #2 All 8 are the same length.
pin 7: LED strip #3
pin 8: LED strip #4 A 100 ohm resistor should used
pin 6: LED strip #5 between each Teensy pin and the
pin 20: LED strip #6 wire to the LED strip, to minimize
pin 21: LED strip #7 high frequency ringining & noise.
pin 5: LED strip #8
pin 15 & 16 - Connect together, but do not use
pin 4 - Do not use
pin 3 - Do not use as PWM. Normal use is ok.
This test is useful for checking if your LED strips work, and which
color config (WS2811_RGB, WS2811_GRB, etc) they require.
#include <OctoWS2811.h>
const int ledsPerStrip = 120;
const int led = LED_BUILTIN;
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
pinMode(led, OUTPUT);
leds.begin();
leds.show();
#define RED 0xFF0000
#define GREEN 0x00FF00
#define BLUE 0x0000FF
#define YELLOW 0xFFFF00
#define PINK 0xFF1088
#define ORANGE 0xE05800
#define WHITE 0xFFFFFF
int microsec = 2000000 / leds.numPixels(); // change them all in 2 seconds
digitalWrite(led, HIGH);
// uncomment for voltage controlled speed
// millisec = analogRead(A9) / 40;
colorWipe(RED, microsec);
colorWipe(GREEN, microsec);
colorWipe(BLUE, microsec);
digitalWrite(led, LOW);
colorWipe(YELLOW, microsec);
colorWipe(PINK, microsec);
colorWipe(ORANGE, microsec);
colorWipe(WHITE, microsec);
void colorWipe(int color, int wait)
for (int i=0; i < leds.numPixels(); i++) {
leds.setPixel(i, color);
leds.show();
delayMicroseconds(wait);
THE SOFTWARE.
pin 7: LED strip #3
pin 5: LED strip #8
pin 4 - Do not use
leds.begin();
leds.show();
leds.show();
