Results 1 to 5 of 5
Thread: A Question about Peak
    Hey guys,
    I have a question about the Peak function from the audio library,
    I am attaching the code here for reference :
    This is analyse_peak.h :
    #ifndef analyze_peakdetect_h_
    #define analyze_peakdetect_h_
    #include "Arduino.h"
    #include "AudioStream.h"
    class AudioAnalyzePeak : public AudioStream
    public:
    	AudioAnalyzePeak(void) : AudioStream(1, inputQueueArray) {
    		min_sample = 32767;
    		max_sample = -32768;
    	bool available(void) {
    		__disable_irq();
    		bool flag = new_output;
    		if (flag) new_output = false;
    		__enable_irq();
    		return flag;
    	float read(void) {
    		__disable_irq();
    		int min = min_sample;
    		int max = max_sample;
    		min_sample = 32767;
    		__enable_irq();
    		min = abs(min);
    		max = abs(max);
    		if (min > max) max = min;
    		return (float)max / 32767.0f;
    	float readPeakToPeak(void) {
    		__disable_irq();
    		min_sample = 32767;
    		__enable_irq();
    		return (float)(max - min) / 32767.0f;
    	virtual void update(void);
    private:
    	volatile bool new_output;
    	int16_t min_sample;
    	int16_t max_sample;
    and this is analyse_peak.cpp :
    #include "analyze_peak.h"
    void AudioAnalyzePeak::update(void)
    	audio_block_t *block;
    	const int16_t *p, *end;
    	int32_t min, max;
    	block = receiveReadOnly();
    	if (!block) {
    		return;
    	p = block->data;
    	end = p + AUDIO_BLOCK_SAMPLES;
    	min = min_sample;
    	max = max_sample;
    	do {
    		int16_t d=*p++;
    		// TODO: can we speed this up with SSUB16 and SEL
    		// http://www.m4-unleashed.com/parallel-comparison/
    		if (d<min) min=d;
    		if (d>max) max=d;
    	} while (p < end);
    	min_sample = min;
    	max_sample = max;
    	new_output = true;
    	release(block);
    My question is this : How is it possible for min_sample and max_sample to ever be updated ?
    As one can see they are both initialized in the constructor to
    min_sample = 32767;
    and the update function only updates them if they achieve greater or smaller values which seems impossible...
    what am I missing here ?
    thanks in advance, A.H.
    Sorry if this is a trivial question,
    I will be glad to any answer...
    2,642
    Quote Originally Posted by Avi Harel View Post
    for getting the minimal value, you first initialize with overall max value, so that all other values are smaller.
    same with maximal value, that you initialize with overall minimal value
    thanks...for some reason I saw it reversed,don't know how I could have missed that...
    2,642
    Alternative would be to set min/max value to first value encountered. This however, may not always be possible.
