Results 1 to 7 of 7
Thread: teensy audio board i2c question
    Does the board already have pull-up resistors on the i2c lines, or do I need to add them?
    Thanks!
    Nov 2013
    719
    The I2C library uses the internal pull-ups in Teensy's processor - effectively plug and play.
    21,104
    The audio board has 2.2K resistors for SDA and SCL.
    Nov 2013
    719
    sorry, had a squiz at the circuit and just did not look at those (glaringly obvious) 2k2 resistors clear as crystal on the schematic - that I2C library enables the pullups on the I2C pins on the MCU tho doesn't it?
    Quote Originally Posted by lamikam View Post
    Thanks!
    Thanks! I am not using with teensy board.
    21,104
    Oh. I hope you'll post a photo at some point. So far I've never seen anyone use it with any other I2S device. I'm curious to see....
    I'm trying to get it to work with a STM32F4 dev board. Lots to learn though, so may be a while!
