I have a project where I want to pull the gate of a power P-MOSFET down to ground using a Teensy output pin.
This gate is by default pulled up to +15V through a 47 kOhm resistor.
Can the open drain switch on the Teensy GPIO pins take that?
(And what happens before my program has managed to configure the pins to open drain?)
Or do I need to use the pins to drive a buffer (a signal MOSFET like the BS170) which in turns pulls down the P-MOSFET gate?
