I've been checking the VBAN protocol lately (http://vb-audio.pagesperso-orange.fr/Voicemeeter/vban.htm)
It's an open protocol for streaming uncompressed audio on the network via udp.
How realistic would it be to use a Teensy 3.2 + Audio Adaptor + Wiz820io to decode the stream ?
I assume I would need to use the queue object to feed samples. The question would then be is the wiz820/teensy fast enough to decode the udp packets ?
