I've been using onehorse's BNO-055 breakout board, which also has a BMP280 pressure sensor.
https://www.tindie.com/products/onehorse/bno-055-9-axis-motion-sensor-with-hardware-sensor-fusion/
I also have some BMP280 breakout boards from Adafruit, and wanted to try using the more teensy-focused code from the one above.
https://learn.adafruit.com/adafruit...ure-plus-temperature-sensor-breakout/overview
I removed the bno-055 code from onehorse's demo sketch, and used it to read values from the Adafruit breakout board. Works great w/T3.2 & TLC.
Although the adafruit bmp280 board works well with teensy, should I be using 4.7k pullups for it? If so, where do I put those?
Ultimately, I want to be able to read from multiple Adafruit BMP280 breakout boards. Do I just need to wire them each up to SCL/SDA. I assume that each BMP280 will report the same address, so what should I do for that?
Do I hook them up separately and figure out how to write the address to each so that they are different?
