Constantin
I am looking into using RTS/CTS with a set of Xbee radios on Serial 3. Looking through the UART page, I see that I need to use D14 at attach a CTS for serial3. Paul mentions that the CTS of the Teensy needs to be attached to the RTS of the other serial device. i.e.
However, the Xbee seems to break that convention as it's manual states:
In other words, the datasheet suggests that the CTS pin on the Xbee is an output that should be connected to the CTS input on the Teensy. Am I correct?
The RTS output from Teensy should be connected to the CTS input on the other serial device, similarly to the TX output connecting to the other device's RX input. Do not simply connect same-named signals with serial.
(see page 10-12 of the manual)Hardware Flow Control (CTS). When the DI buffer is 17 bytes away from being full; by default, the module de-asserts CTS (high) to signal to the host device to stop sending data [refer to D7 (DIO7 Configuration) parameter]. CTS is re-asserted after the DI Buffer has 34 bytes of memory available.
