Results 1 to 2 of 2
Thread: teensy wifi artnet lights
    Jun 2015
    11
    Hello everyone, I have made a WS2812 matrix that runs with Glediator i have a working code for using serial cable (usb). now I would like to add a CC3000 wifi module to make the matrix wireless, and use an artnet protocol. I am not quite sure how to acheive that!
    Also I am not sure how to wire the wifi module to the teensy and on to the matrix.
    hope someone can help me.
    -Colin
    #include "FastLED.h"
    #define NUM_LEDS 480
    #define COLOR_ORDER RGB
    const int dataline = 13;
    byte colourStore[NUM_LEDS *3];
    //this is a 1D array, just set out as below for easy reading
    int guitarLeds[] = {
                          4,5,6,        //3
                  26,27,28,29,30,31,32,                                                              //7
                  50,51,52,53,54,55,56,57,                      65,66,67,68,                        //12
           73,74,75,76,77,78,79,80,81,82,83,              87,88,89,90,91,92,93,94,                  //19
        97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,112,113,114,115,116,117,118,119,   //23
    120,121,122,123,124,125,126,127,128,129,130,131,132,133,134,135,136,137,138,139,140,            //21
    144,145,146,147,148,149,150,151,152,153,154,155,156,157,158,159,160,161,162,163,164,            //21
    168,169,170,171,172,173,174,175,176,                181,182,183,184,            188,            //14  //120
    192,193,194,195,196,197    ,199,200,201,            205,206,207,208,                            //13
    216,217,218,219,220,221    ,223,224,225,            229,230,231,232,                            //13
    240,241,242,243,244,245    ,247,248,249,            253,254,255,256,                            //13
    264,265,266,267,268,269    ,271,272,273,            277,278,279,280,                            //13  //172
    288,289,290,291,292,293,294,295,296,                301,302,303,304,            308,            //14
    312,313,314,315,316,317,318,319,320,321,322,323,324,325,326,327,328,329,330,331,332,            //21
    336,337,338,339,        342,343,344,345,346,347,348,349,350,351,352,353,354,355,356,            //19
       361,362,363,364,365,366,367,    369,370,371,372,373,374,375,376,377,378,379,380,381,         //20
       385,386,387,        390,391,    393,394,395            ,399,400,401,402,403,404,405,         //15
           410,411,        414,415,416,417,                            425,426,427,                  //9
            434,435,436,437,438,439,440,                                                             //7
                460,461,462,        //3
    CRGB leds[NUM_LEDS];
    LEDS.addLeds<WS2812B, dataline>(leds, NUM_LEDS);
    int serialGlediator() {
    while (!Serial.available()) {}
    return Serial.read();
    while (serialGlediator() != 1) {}
    for (int i=0; i < NUM_LEDS; i++) {
    leds[i].r = serialGlediator();
    leds[i].g = serialGlediator();
    leds[i].b = serialGlediator();
    for(int x=0;x<280;x++)//change to your actual led number
    leds[x]= leds[guitarLeds[x]];
    FastSPI_LED.show();
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    924
    Here is an image of the basic setup using the cc3000 breakout board from Adafruit with the Teensy 3.0 micro controller.
    This may be a bit out of date regarding the library, but changes were required to the standard pin setup to be able to use octows lib.
    Both are able run off 5volt inputs if you want them to, as both have on board regulators to convert to 3.3v logic (hence using a standard 4xAA battery setup = rechargeable NOT regular batteries as these give 6v).
    The hookup of the cc3000 uses the Adafruit library with some changes. The library allows for pin changes, and in order for the Teensy to run both the CC3000 wifi board and the Octows2811 library to run the led array, I had to change some of the pins to avoid conflicts.
    The led array is hooked up in the usual way, using eight pins of the Teensy
    https://github.com/PaulStoffregen/Ad...CC3000_Library
    CLK to pin 13
    MISO to pin 12
    MOSI to pin 11
    CS to pin 10
    VBEN to pin 5
    IRQ to pin 2 // and remember change the code in the standard sketch from pin 3 to pin 2 :-)
