Results 1 to 13 of 13
Thread: Teensy 3.1 Mouse horizontal scroll
    Aug 2015
    7
    Hello guys,
    I'm currently working on a gaming mouse with the teeny 3.1, I've been trying to implement the horizontal scroll but with no success. I tried changing the mouse descriptor with the one provided by microsoft Here and editing the "usb_mouse.c" and "usb_mouse.h" but still doesn't seem to work (it worked after i changed something random which i don't remember anymore, but it was not working as intended), do you have any idea on what i should do or what files should I work on and put me on the right track ? I would really appreciate it.
    Nov 2015
    Wales
    579
    *(tx_packet->buf + 0) = 1;
            *(tx_packet->buf + 1) = usb_mouse_buttons_state;
            *(tx_packet->buf + 2) = x;
            *(tx_packet->buf + 3) = y;
            *(tx_packet->buf + 4) = wheel;
            tx_packet->len = 5;
    Would need to be extended to:
            *(tx_packet->buf + 5) = acPan;
            tx_packet->len = 6;
    usb_desc.c/h will probably also need to be adjusted to ensure the computer is expected the correct packet sizes
    USB spec 9.6.5, page 267-269, Table 9-12
    and
    HID 1.11 spec, section 6.2.1
    Will probably both need looking at. I recommend looking at usb_desc.c/h to get a feel for it
    EDIT -
    usb_desc.c
    static uint8_t mouse_report_desc[] = {
            0x05, 0x01,                     // Usage Page (Generic Desktop)
            0x09, 0x02,                     // Usage (Mouse)
            0xA1, 0x01,                     // Collection (Application)
            0x85, 0x01,                     //   REPORT_ID (1)
            0x05, 0x09,                     //   Usage Page (Button)
            0x19, 0x01,                     //   Usage Minimum (Button #1)
            0x29, 0x08,                     //   Usage Maximum (Button #8)
            0x15, 0x00,                     //   Logical Minimum (0)
            0x25, 0x01,                     //   Logical Maximum (1)
            0x95, 0x08,                     //   Report Count (8)
            0x75, 0x01,                     //   Report Size (1)
            0x81, 0x02,                     //   Input (Data, Variable, Absolute)
            0x09, 0x30,                     //   Usage (X)
            0x09, 0x31,                     //   Usage (Y)
            0x09, 0x38,                     //   Usage (Wheel)
            0x15, 0x81,                     //   Logical Minimum (-127)
            0x25, 0x7F,                     //   Logical Maximum (127)
            0x75, 0x08,                     //   Report Size (8),
            0x95, 0x03,                     //   Report Count (3),
            0x81, 0x06,                     //   Input (Data, Variable, Relative)
            0xC0,                           // End Collection
            0x85, 0x02,                     //   REPORT_ID (2)
            0x26, 0xFF, 0x7F,               //   Logical Maximum (32767)
            0x75, 0x10,                     //   Report Size (16),
            0x95, 0x02,                     //   Report Count (2),
            0xC0                            // End Collection
    This would need changing to the structure suggested in the document you linked. This is beyond me though I'm afraid.
    I believe:
    INPUT (Var, Rel)			;Vertical wheel scroll
          END COLLECTION (Logical)
            REPORT ID (0x02)
            USAGE (Resolution Multiplier)
            REPORT SIZE (2) 			;OS requires > 1
            LOGICAL MINIMUM (0)
            LOGICAL MAXIMUM (1)
    Needs adding. Report ID will need to be unique I should imagine
    EDIT EDIT -
    This page looks very useful
    I'm not on windows but go here and download the HID descriptor tool. Use that to reconstruct the HID header from wheel-1.docx
    EDIT EDIT EDIT -
    Tomorrow I'll try and add the forward and back buttons to get myself slowly involved in the USB side of things. I'll submit a pull request if it works
    EDIT EDIT EDIT EDIT -
    This tool can confirm if what you are doing is correct
    25,517
    I see you also posted this some time ago...
    https://forum.pjrc.com/threads/30517...4417#post84417
    25,517
    This is good, sending the extra byte for the new scroll data.
    Quote Originally Posted by Xenoamor View Post
            tx_packet->len = 6;
    Two things need to changed in the report descriptor, so the PC knows to expect 1 more byte and knows what it means.
    These three lines tell your PC that the 2nd, 3rd, 4th bytes are the X & Y and normal wheel movement data. Another line needs to be added here to tell the PC how the use the extra byte. I'm honestly not sure which usage number is should be.
    The this other part needs to be updated.
    This informs your PC to expect three numbers, each 8 bits. Obviously this 3 needs to be increased to 4, so your PC knows there's 1 more byte. You need both the usage info, which tells the PC how to use the data (but not how many bits/bytes it is) and this to tell it how many bits of actual data to expect.
    25,517
    Oh, looks like "AC Pan" is in a different usage table "consumer devices" rather than "generic desktop". Not nice.
    Maybe try keeping these the same, and then add another group just for the last byte.
    Then try adding these lines immediately after:
            0x05, 0x0C,                     //   Usage Page (Consumer Devices)
            0x09, 0xEE,                     //   Usage (AC Pan)
            0x95, 0x01,                     //   Report Count (1),
    The HID usage tables spec says Consumer Devices is 12, and "AC Pan" is 238.
    Nov 2015
    Wales
    579
    Okay well implementing the forward/backwards buttons were simple so I've created a pull request for this.
    Thanks for the input Paul!
    Would implementing another usage table potentially break the mouse's compatibility with certain systems? If not I'd be happy to pull request it into the core
    EDIT -
    After testing of course
    Aug 2015
    7
    Hello guys, It's finally working, i had to change the descriptor to the one here : http://www.keil.com/forum/15671/usb-...-scroll-wheel/
    Here's the code :
    		0x05, 0x01,        // USAGE_PAGE (Generic Desktop)
    		0x09, 0x02,        // USAGE (Mouse)
    		0xa1, 0x01,        // COLLECTION (Application)
    		0xa1, 0x02,        //   COLLECTION (Logical)
    		0x09, 0x01,        //     USAGE (Pointer)
    		0xa1, 0x00,        //     COLLECTION (Physical)
    						// ------------------------------  Buttons
    		0x05, 0x09,        //       USAGE_PAGE (Button)
    		0x19, 0x01,        //       USAGE_MINIMUM (Button 1)
    		0x29, 0x05,        //       USAGE_MAXIMUM (Button 5)
    		0x15, 0x00,        //       LOGICAL_MINIMUM (0)
    		0x25, 0x01,        //       LOGICAL_MAXIMUM (1)
    		0x75, 0x01,        //       REPORT_SIZE (1)
    		0x95, 0x05,        //       REPORT_COUNT (5)
    		0x81, 0x02,        //       INPUT (Data,Var,Abs)
    						// ------------------------------  Padding
    		0x75, 0x03,        //       REPORT_SIZE (3)
    		0x95, 0x01,        //       REPORT_COUNT (1)
    		0x81, 0x03,        //       INPUT (Cnst,Var,Abs)
    						// ------------------------------  X,Y position
    		0x09, 0x30,        //       USAGE (X)
    		0x09, 0x31,        //       USAGE (Y)
    		0x15, 0x81,        //       LOGICAL_MINIMUM (-127)
    		0x25, 0x7f,        //       LOGICAL_MAXIMUM (127)
    		0x75, 0x08,        //       REPORT_SIZE (8)
    		0x95, 0x02,        //       REPORT_COUNT (2)
    		0x81, 0x06,        //       INPUT (Data,Var,Rel)
    						// ------------------------------  Vertical wheel res multiplier
    		0x09, 0x48,        //         USAGE (Resolution Multiplier)
    		0x35, 0x01,        //         PHYSICAL_MINIMUM (1)
    		0x45, 0x04,        //         PHYSICAL_MAXIMUM (4)
    		0x75, 0x02,        //         REPORT_SIZE (2)
    		0xa4,              //         PUSH
    		0xb1, 0x02,        //         FEATURE (Data,Var,Abs)
    		0x09, 0x38,        //         USAGE (Wheel)
    		0x35, 0x00,        //         PHYSICAL_MINIMUM (0)        - reset physical
    		0x45, 0x00,        //         PHYSICAL_MAXIMUM (0)
    		0xc0,              //       END_COLLECTION
    						// ------------------------------  Horizontal wheel res multiplier
    		0xb4,              //         POP
    						// ------------------------------  Padding for Feature report
    		0x75, 0x04,        //         REPORT_SIZE (4)
    		0xb1, 0x03,        //         FEATURE (Cnst,Var,Abs)
    		0x05, 0x0c,        //         USAGE_PAGE (Consumer Devices)
    		0x0a, 0x38, 0x02,  //         USAGE (AC Pan)
    		0xc0               // END_COLLECTION
    Then I had to change this :
            tx_packet->len = 5;
    to this :
    *(tx_packet->buf + 0) = usb_mouse_buttons_state;
            *(tx_packet->buf + 1) = x;
            *(tx_packet->buf + 2) = y;
            *(tx_packet->buf + 3) = wheel;
            *(tx_packet->buf + 4) = pan;
            tx_packet->len = 5;
    Then it was just a matter of editing the other functions to add the pan, now the 5 buttons and the horizontal scroll are all working
    Thank you guys so much for the help
    Here are the files : usb_mouse.c usb_mouse.h usb_de.c
    25,517
    Does this break Mouse.moveTo() ?
    Aug 2015
    7
    Just tried it now, yes it did unfortunatly, any idea on how to fix it ?
    Nov 2015
    Wales
    579
    I'll have a crack at this on Monday Freakeyyy providing the hardware team still have nothing for me to program
    Try adding Paul's changes. Changing the entire descriptor is bound to cause some real issues
    Nov 2015
    Wales
    579
    Okay I've added acPan. To use it use Mouse.pan(val); Where val lies between -127 and 127
    The basic change was the addition of:
             0x05, 0x0C,        // Usage Page (Consumer)
             0x0A, 0x38, 0x02,  // Usage (AC Pan)
             0x81, 0x06,        // Input (Data, Variable, Absolute)
    I've attached the modified files.
    usb_de.c <- this should be "usb_desc.c" For some reason the attachment process is renaming it
    usb_mouse.c
    usb_mouse.h
    Do you want me to make a pull request for this Paul?
    It's questionable if this goes beyond being just a mouse and doesn't actually belong in the core
    Tested on Ubuntu 15.01
    mouse.moveTo() confirmed to still work
    FYI these files do not contain the MOUSE_BACK, MOUSE_FORWARD additions I made prior
    Aug 2015
    7
    Just added that part to the descriptor and now everything is working great, the Pan, moveTo, mouse_backward and mouse_forward too, tested on windows 7. Thank you guys so much
    25,517
    I merged this today.
    https://github.com/PaulStoffregen/co...17651df1d93215
    In testing, I couldn't find any programs on Ubuntu 14.04 which respond to the horizontal scroll. Likewise on Windows, for a while I though it wasn't working. Then I tried IE, which does support it. Macintosh seems to be the only system where it's widely supported.
    Does anyone know of any programs on Linux which respond to horizontal scroll (AC Pan) input?
