AudioConnection costructors
darioconcilio
Hi to all,
Has AudioConnection class a costructors with 0 parameter?
I can't find header file of this class, I'm finding in ..\Arduino\hardware\teensy\avr\libraries\Audio
Is it correct my search or not?
Thank's Paul, but It could add a costructors without parameter?
Sothat I could create an AudioConnection in my header file, and then I'll instance varaible in cpp file?
I do not understand what you're asking. Maybe if you explain *why* or illustrate with some code, it might make sense?
However, if you look at how the AudioConnection connection code works, a constructors without a way to define the connection would be silly.
Do you mean a declaration then a later definition:
AudioConnection *audioCon = NULL;
In your header
Then in setup():
extern AudioConnection *audioCon;
audioCon = new AudioConnection(arg1, arg2...)
Using "new" in embedded systems is generally a bad idea, because any "churn" on the heap will be hard to plan for and test 100%.
A better method is to separate the declaration, and the definition. In C++, this is how almost everything is done. In your header, you do something like:
/* myfile.h */
class AudioConnection;
extern AudioConnection theAudio;
Then in the source file, you do:
/* myfile.cpp */
#include "myfile.h"
#include <AudioConnection.h>
AudioConnection theAudio(arg1, arg2, ...);
Now, any file that wants to use theAudio can #include "myfile.h" can use "theAudio" global variable.
Note that the method described by Xenoamor will NOT WORK if you #include the header from more than one cpp file, because it will fail with a duplicate defined symbol linker error.
Ah of course, you want extern in the header as the declaration.
Cheers Jwatte! I'm still really rather green when it comes to c++
