Results 1 to 8 of 8
Thread: AudioConnection costructors
    Member darioconcilio's Avatar
    Feb 2016
    Varese, Italy
    52
    Hi to all,
    Has AudioConnection class a costructors with 0 parameter?
    I can't find header file of this class, I'm finding in ..\Arduino\hardware\teensy\avr\libraries\Audio
    Is it correct my search or not?
    Feb 2016
    Varese, Italy
    52
    Thank's Paul, but It could add a costructors without parameter?
    Sothat I could create an AudioConnection in my header file, and then I'll instance varaible in cpp file?
    19,928
    I do not understand what you're asking. Maybe if you explain *why* or illustrate with some code, it might make sense?
    However, if you look at how the AudioConnection connection code works, a constructors without a way to define the connection would be silly.
    Nov 2015
    Wales
    579
    Do you mean a declaration then a later definition:
    AudioConnection *audioCon = NULL;
    In your header
    Then in setup():
    extern AudioConnection *audioCon;
    audioCon = new AudioConnection(arg1, arg2...)
    Feb 2016
    Varese, Italy
    52
    Great! You are wonderful!
    Thank you.
    Dec 2014
    253
    Using "new" in embedded systems is generally a bad idea, because any "churn" on the heap will be hard to plan for and test 100%.
    A better method is to separate the declaration, and the definition. In C++, this is how almost everything is done. In your header, you do something like:
    /* myfile.h */
    class AudioConnection;
    extern AudioConnection theAudio;
    Then in the source file, you do:
    /* myfile.cpp */
    #include "myfile.h"
    #include <AudioConnection.h>
    AudioConnection theAudio(arg1, arg2, ...);
    Now, any file that wants to use theAudio can #include "myfile.h" can use "theAudio" global variable.
    Note that the method described by Xenoamor will NOT WORK if you #include the header from more than one cpp file, because it will fail with a duplicate defined symbol linker error.
    Nov 2015
    Wales
    579
    Ah of course, you want extern in the header as the declaration.
    Cheers Jwatte! I'm still really rather green when it comes to c++
