I have two Teensy 3.1. The first sends data to the second over an XBee connection. The second has sensors and sends data from those sensors and should transmit everything to a computer as MIDI messages over USB.
The question is: if the messages sent from the first Teensy were encoded as MIDI directly from start would it ease their retransmission from the second Teensy or should I rather transmit them as regular serial messages over the Xbee connection first and convert them to MIDI in the second Teensy afterwards? Also, if I'd go MIDI-over-XBee, would a non-MIDI baudrate (that is, different from, probably bigger than 31250) for the XBee transmission cause any issue?
Thank you in advance.
