Results 1 to 5 of 5
Thread: chorus ?
    Germany NRW
    5,567
    chorus ?
    i tried the chorus-effect. Is that really a chorus ? (buggy??)
    It sounds more and more "digitally" the more "num_chorus" or memory i add. Or, is this intended ?
    Germany NRW
    5,567
    ...hm... the sourcecode shows only delays, no pitch shift per "voice", this can't work (obviously, as you can hear)
    What ever this effect is, it's not a chorus :-( Perhaps the same can be done with the delay-effect.
    Looking over the source, yeah, that looks like a set of static comb filters. Something like the multi-tap delay line followed by a mixer.
    Take a look at the Flanger class. It has sinusoid modulation and interpolation. Flange with slow modulation and overall delay of 25-ish milliseconds moves into chorus territory.
    1,069
    When I wrote the chorus and flange effects, I used this as a guide:
    http://www.cs.cf.ac.uk/Dave/CM0268/P...8_Audio_FX.pdf
    It says that chorus doesn't use modulation so I didn't try any. I couldn't find anything else which explained how to get those effects.
    Pete
    Senior Member adrian's Avatar
    Oct 2015
    Wellington, NZ
    504
    all you need to know about chorus
    evidently a lfo modulates a clock signal, giving variable delay times. From the page ....
    "The chorus effect is created by the slow modulation of the delay time using a Low Frequency Oscillator (LFO). As the LFO cycles, the delay time goes up and down and therefore the delayed audio pitch slightly shifts up and down."
    Sounds a bit like how imagined a flanger would work ....
    the delay is a bucket brigade device (whatever the hell that is)
    You don't happen to have MIJ HM-2 source-code??
