Here is my current situation:
I have a Teensy 3.1 mounted to an Audio board. The audio board also has the flash chip attached to it.
I am using Serial1 for a 4D Systems LCD screen. And from my understanding, The Audio Board uses
Serial2 and Serial3 for its operations.
I need an option for serial communication as I want to implement a midi solution with my current set up.
I have tried disabling the Serial3 pins for the audio board, but then the audio output does not work.
What choices do I have to implement serial comms while also keeping the current functionality of
the audio board?
I am aware of Software Serial, but would only want to use this as a last resort.
Thank you for any help on this!
the audio board?
