Results 1 to 9 of 9
Thread: Effect: Remove Vocals, aka "Karaoke"
    Germany
    8,625
    i wrote a new effect for the audio-lib. It removes the vocals from songs.
    For some songs it work good, for others not. For a good effect, the vocals must be in the mid of both stereo-channels.
    How does it work ?
    Simple. It inverts the right channel and adds it to the left (the result is one mono channel - ideally, the vocals are the same on l+r and subtracting the values gives 0...).
    Its the same way as the "Vocals Remover" in audacity works.
    I added a enable(bool) function which enables or disables the effect.
    That means, if you disable it, you can use the effect as a simple way to transform stereo to mono.
    Link with additional example-sketch:
    https://github.com/FrankBoesing/Teen...-Remove-Vocals
    @Paul: it's MIT licence ;-)
    Have fun,
    Frank.
    Germany
    8,625
    Karaoke
    Hi Frank B!
    Great job, that's a clean implementation!
    This is what I was able to concoct some time back, not as elegant, but good enough to impress my kids!
    https://forum.pjrc.com/threads/24793...ll=1#post48468
    Cheers,
    Alfa66
    Germany
    8,625
    oops..i did'nt know that this existed
    Hey, no worries!
    It turns out that we have both come up with something that maybe is not really needed - check this: http://www.pjrc.com/teensy/gui/?info=AudioEffectMidSide
    Anyway (and off topic) what is the best way to display (oscillscope-like) the waveform in the audio buffer? Should I use queue?
    Thanks!
    PS Really appreciate your many contributions to the Audio Forum!
    24,486
    Quote Originally Posted by alfa66 View Post
    Yes, the queue object is the best way to get access to the raw audio samples.
    24,486
    Maybe we should put that remove vocals example into the library, using the existing mid-side object. My understanding is vocal elimination usually also involves a lowpass and highpass filter, to keep the non-vocal frequencies and try to lessen any vocals that get through the first part.
    Anyone want to give that a try? Would love to include a really good vocal eliminator example with the library.
    Germany
    8,625
    @Paul, I don't know, and I'm not familar with the new USB Audio - is it possible to take USB-Input, apply the effect and send it back to the PC ?
    Would be a great example with mid-side, with the filters added. (But it works OK without filters, too - did you hear the example ? (Post #2)).
    Audacity uses no filters for this effect.
    24,486
    Yes.
    However, the USB objects don't implement update responsibility, so at least 1 regular input or output must also be present.
