* File: DS28EA00
* Programmer: Maxim Integrated Systems Apps
* Started: 22JAN14
* Updated: 23JAN14
* Description: Demonstration of using the DS28EA00 1-wire devices.
* Program supports up to 10 sensors on the bus.
* Sensors can be added/removed from the bus while the
* program is running to test CHAIN feature of the DS28EA00
* This project requires the OneWire library which can be found at the
* following link - http://www.pjrc.com/teensy/td_libs_OneWire.html
* To make this library visible to the Arduino IDE follow the
* instructions at the following link - http://arduino.cc/en/Guide/Libraries
* This project was developed using the following hardware:
* 1. Arduino UNO - http://arduino.cc/en/Main/ArduinoBoardUno
* 2. Osepp LCD Shield - http://osepp.com/products/shield-arduino-compatible/16x2-lcd-display-keypad-shield/
* 3. DS28EA00EVKIT - http://www.maximintegrated.com/datasheet/index.mvp/id/5489
* One of the EVKIT boards was modified to provide breadboard access to
* the 1-wire data pin on the board. The rest of the boards were
* connected with the provided cables.
* The following is how the dip-switches on each DS28EA00EVKIT board
* were configured:
* Board 1 - This board must be connected directly to the Arduino.
* switch 1 - closed LEDA
* switch 2 - closed LEDB
* switch 3 - open A1
* switch 4 - open A2
* switch 5 - open B EXT
* switch 6 - closed B GND
* switch 7 - closed Vcc
* Board 2 and 3 - The position of these boards is irrelevant.
* Changing the positions of these boards on the fly
* demonstrates the CHAIN feature of the device
* switch 5 - closed B EXT
* switch 6 - open B GND
* The Osepp LCD Shield is not required for this project to work.
* Simply comment out the LCD relevant code (5 lines in setup, 4 lines
* in the main loop) and make sure the function print_bus_data is
* uncommented in the main loop.
#include <LiquidCrystal.h>
#include <OneWire.h>
#include "DS28EA00.h"
*Following is specific to the Osepp LCD Shield
//select the pins used on the LCD Shield
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int lcd_key = 0;
int adc_key_in = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
//Set up ow_bus. Pin can be changed in header file
OneWire ow_bus(OW_BUS_PIN);
//This is an array of structs
ds28ea00_t ds28ea00_array[10];
unsigned char num_ds28ea00_on_bus = 0;
unsigned char old_num_devices = 0;
unsigned char selected_ds28ea00 = 0;
unsigned char idx = 0;
unsigned char idy = 0;
unsigned char data;
/*lcd.begin(16, 2); // start the library
lcd.setCursor(0,0);
lcd.print("DS28EA00# =");
lcd.setCursor(0, 2);
lcd.print("Temp = "); */
while (!Serial) {
yield(); // THIS IS BLOCKING. The sketch will not run until the serial monitor is opened.
Serial.println("-----------------------------------");
ds28ea00_detect_num_devices(ds28ea00_array);
old_num_devices = num_ds28ea00_on_bus;
ds28ea00_config_bus();
//See if DS28EA00 sensors have been added/removed from bus
//If they have, configure them
if(old_num_devices != num_ds28ea00_on_bus)
//Test for user input
if(read_LCD_buttons() == btnSELECT)
selected_ds28ea00++;
if(selected_ds28ea00 >= num_ds28ea00_on_bus)
//Display Current Device
//lcd.setCursor(12, 0);
//lcd.print(selected_ds28ea00 + 1);
//Convert the temperature on selected device
//ds28ea00_convert_temperature(selected_ds28ea00);
//Display temperature
//lcd.setCursor(7, 1);
//lcd.print(ds28ea00_array[selected_ds28ea00].temperature);
// comment the following if print_bus_data() is used
//delay(100);
//The following prints the members of each devices struct to a rolling terminal
//The array of structs updates dynamically when devices are added removed.
print_bus_data();
*Function Defenitions - The arduino ide creates function prototypes
* when the sketch is compiled, therefore none are
* included in the header file as would be done in
* a normal c or cpp project. Please refer to the
* following link for more details about the
* arduino build process.
* http://www.arduino.cc/en/Hacking/BuildProcess
* Function: ds28ea00_detect_num_devices
* Parameters: ds28ea00_t *device_array - Pointer to an array of type
* ds28ea00_t
* Returns: none
* Description: Detects devices on the bus
void ds28ea00_detect_num_devices(ds28ea00_t *device_array)
int state = 0;
do
state = ds28ea00_sequence_discoverey(device_array);
if(state == -1)
Serial.println("Error!");
while(state == -1);
return;
/********** END ds28ea00_detect_num_devices****************************/
* Function: ds28ea00_config_bus
* Parameters: none
* Returns: none
* Description: Populates structs of devices with desired configuration
and writes to devices on bus
void ds28ea00_config_bus(void)
for(idx = 0; idx < num_ds28ea00_on_bus; idx++)
ds28ea00_get_pwr_mode(idx);
//see header file for #defines of the following
ds28ea00_array[idx].temp_lo_alm = LO_ALARM;
ds28ea00_array[idx].temp_hi_alm = HI_ALARM;
ds28ea00_array[idx].config_register = RES_12_BIT;
ds28ea00_write_scratchpad(idx);
ds28ea00_copy_scratchpad(idx);
ds28ea00_convert_temperature(idx);
return;
/********** END ds28ea00_config_bus************************************/
* Function: ds28ea00_sequence_discoverey
* ds28ea00_t
* Returns: none
* Description: Detects devices on the bus and populates the 64-bit rom
* codes of the device_array
int ds28ea00_sequence_discoverey(ds28ea00_t *device_array)
unsigned char test_end_of_bus;
idx = 0;
idy = 0;
ow_bus.reset();
ow_bus.skip();
ow_bus.write(CHAIN);
ow_bus.write(CHAIN_ON);
ow_bus.write(~CHAIN_ON);
data = ow_bus.read();
if(data != VALID_SEQUENCE)
return(-1);
do
ow_bus.reset();
ow_bus.write(CONDITIONAL_READ_ROM);
test_end_of_bus = 0xFF;
for(idy = 0; idy < 8; idy++)
test_end_of_bus &= data;
device_array[idx].rom_code[idy] = data;
if(test_end_of_bus == 0xFF)
idx++;
num_ds28ea00_on_bus = idx;
ow_bus.reset();
ow_bus.write(PIO_ACCESS_WRITE);
ow_bus.write(CHAIN_DONE);
ow_bus.write(~CHAIN_DONE);
return(-1);
while(test_end_of_bus != 0xFF);
ow_bus.reset();
ow_bus.skip();
ow_bus.write(CHAIN_OFF);
ow_bus.write(~CHAIN_OFF);
return(-1);
return(0);
/********** END ds28ea00_sequence_discoverey***************************/
* Function: ds28ea00_get_pwr_mode
* Parameters: unsigned char device - ds28ea00 struct offset in array
* Returns: none
* Description: Initiates a READ_PWR_MODE command with the selected
* ds28ea00 device and updates the power mode member of
* the device's struct.
void ds28ea00_get_pwr_mode(unsigned char device)
ow_bus.reset();
ow_bus.select(ds28ea00_array[device].rom_code);
ow_bus.write(READ_PWR_MODE);
ds28ea00_array[device].pwr_mode = ow_bus.read();
return;
/********** END ds28ea00_get_pwr_mode**********************************/
* Function: ds28ea00_set_resolution
* unsigned char val - byte representing resolution of
* device
* Returns: none
* Description: writes 'val' to configuration register of 'device'
void ds28ea00_set_resolution(unsigned char device, unsigned char val)
ds28ea00_array[device].config_register = val;
ds28ea00_write_scratchpad(device);
ds28ea00_copy_scratchpad(device);
return;
/********** END ds28ea00_set_resolution********************************/
* Function: ds28ea00_set_hi_alarm
* unsigned char val - byte representing hi alarm
* Returns: none
* Description: writes 'val' to hi alarm register of 'device'
void ds28ea00_set_hi_alarm(unsigned char device, unsigned char val)
ds28ea00_array[device].temp_hi_alm = val;
return;
/********** END ds28ea00_set_hi_alarm*********************************/
* Function: ds28ea00_set_lo_alarm
* unsigned char val - byte representing lo alarm
* Returns: none
* Description: writes 'val' to lo alarm register of 'device'
void ds28ea00_set_lo_alarm(unsigned char device, unsigned char val)
ds28ea00_array[device].temp_lo_alm = val;
return;
/********** END ds28ea00_set_lo_alarm*********************************/
* Function: ds28ea00_read_scratchpad
* Returns: none
* Description: Reads the selected device's scratchpad
void ds28ea00_read_scratchpad(unsigned char device)
int temp_lo_byte;
int temp_hi_byte;
ow_bus.reset();
ow_bus.write(READ_SCRATCHPAD);
temp_lo_byte = ow_bus.read();
temp_hi_byte = ow_bus.read();
ds28ea00_array[device].temp_hi_alm = ow_bus.read();
ds28ea00_array[device].temp_lo_alm = ow_bus.read();
ds28ea00_array[device].config_register = ow_bus.read();
//last three bytes of scratchpad reserved so we don't care
ow_bus.reset();
//build temp into single signed int
ds28ea00_array[device].raw_temp = ((temp_hi_byte << 8) | temp_lo_byte);
return;
/********** END ds28ea00_read_scratchpad*******************************/
* Function: ds28ea00_write_scratchpad
* Returns: none
* Description: Writes the desired temperature alarms and configuration
register to the selected device's scratchpad
void ds28ea00_write_scratchpad(unsigned char device)
ow_bus.reset();
ow_bus.write(WRITE_SCRATCHPAD);
ow_bus.write(ds28ea00_array[device].temp_hi_alm);
ow_bus.write(ds28ea00_array[device].temp_lo_alm);
ow_bus.write(ds28ea00_array[device].config_register);
ow_bus.reset();
return;
/********** END ds28ea00_write_scratchpad******************************/
* Function: ds28ea00_copy_scratchpad
* Returns: none
* Description: Copies scratchpad of selected device to its EEPROM
void ds28ea00_copy_scratchpad(unsigned char device)
ow_bus.reset();
ow_bus.write(COPY_SCRATCHPAD);
do
while(data != 0xFF);
return;
/********** END ds28ea00_copy_scratchpad*******************************/
* Function: ds28ea00_convert_temperature
* Returns: none
* Description: Initiates a temperature conversion on selected device
void ds28ea00_convert_temperature(unsigned char device)
int temp_lo_byte;
int temp_hi_byte;
ow_bus.reset();
ow_bus.write(CONVERT_TEMP);
do
while(data = 0);
ow_bus.reset();
//we just want temp bytes so reset
ow_bus.reset();
ds28ea00_format_temperature(device);
return;
/********** END ds28ea00_convert_temperature***************************/
* Function: ds28ea00_format_temperature
* Returns: none
* Description: Formats the raw temperature conversion
void ds28ea00_format_temperature(unsigned char device)
float f_temp = 0;
int r_temp = ds28ea00_array[device].raw_temp;
unsigned char sign = POSITIVE;
if(r_temp & 0x8000)
sign = NEGATIVE;
r_temp = ~r_temp + 1;
switch(ds28ea00_array[device].config_register)
case RES_9_BIT:
r_temp = ((r_temp >> 3) & 0x1FF);
f_temp = (r_temp >> 1);
if(r_temp & 0x001)
f_temp += 0.5;
case RES_10_BIT:
r_temp = ((r_temp >> 2) & 0x3FF);
f_temp = (r_temp >> 2);
for(idy = 0; idy < 2; idy++)
if(r_temp & (1 << idy))
f_temp += (1.0/(1 << (2 - idy)));
case RES_11_BIT:
r_temp = ((r_temp >> 1) & 0x7FF);
f_temp = (r_temp >> 3);
for(idy = 0; idy < 3; idy++)
f_temp += (1.0/(1 << (3 - idy)));
default :
f_temp = (r_temp >> 4);
for(idy = 0; idy < 4; idy++)
f_temp += (1.0/(1 << (4 - idy)));
if(sign == NEGATIVE)
ds28ea00_array[device].temperature = (-1*f_temp);
ds28ea00_array[device].temperature = f_temp;
return;
/********** END ds28ea00_format_temperature***************************/
* Function: ds28ea00_pio_read
* Returns: none
* Description: Reads the PIO status register of the selected device
void ds28ea00_pio_read(unsigned char device)
ow_bus.reset();
ow_bus.write(PIO_ACCESS_READ);
ds28ea00_array[device].pio_state = ow_bus.read();
ow_bus.reset();
return;
/********** END ds28ea00_pio_read**************************************/
* Function: ds28ea00_pio_write
* Returns: none
* Description: Writes to the PIO assignment register of the selected
* device
int ds28ea00_pio_write(unsigned char device, unsigned char val)
ow_bus.reset();
ow_bus.write(val);
ow_bus.write(~val);
return(-1);
ow_bus.reset();
return(0);
/********** END ds28ea00_pio_write*************************************/
* Function: print_bus_data
* Parameters: none
* Returns: none
* Description: Prints how many devices are on the bus and the members
* of their structs.
void print_bus_data(void)
Serial.print("Number of DS28EA00 on bus = ");
Serial.println(num_ds28ea00_on_bus);
Serial.println("");
Serial.print("DS28EA00 #");
Serial.println(idx + 1);
Serial.print("64-bit ROM code = ");
data = ds28ea00_array[idx].rom_code[idy];
if(data > 0x0F)
Serial.print(data , HEX);
Serial.print(0);
Serial.println("");
Serial.print("Power Mode = ");
Serial.println(ds28ea00_array[idx].pwr_mode, HEX);
Serial.print("Raw Temperature = ");
Serial.println(ds28ea00_array[idx].raw_temp, HEX);
Serial.print("High Alarm = ");
Serial.println(ds28ea00_array[idx].temp_hi_alm, HEX);
Serial.print("Low Alarm = ");
Serial.println(ds28ea00_array[idx].temp_lo_alm, HEX);
Serial.print("Configuration Register = ");
Serial.println(ds28ea00_array[idx].config_register, HEX);
Serial.print("Temperature = ");
Serial.println(ds28ea00_array[idx].temperature, HEX);
Serial.print("Pin State = ");
Serial.println(ds28ea00_array[idx].pio_state, HEX);
Serial.println("");
delay(2500);
return;
/********** END print_bus_data*****************************************/
* Function: read_LCD_buttons
* Parameters: none
* Returns: A int representing button pressed
* Description: Taken from Osepp LCD Shield example. The shield uses a
* voltage divider network with different taps to represent
* each button based on the analog voltage read in on A0.
int read_LCD_buttons()
adc_key_in = analogRead(0);
//btnNone read first for speed since most likely case
if (adc_key_in > 1000) return btnNONE;
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 555) return btnLEFT;
if (adc_key_in < 790) return btnSELECT;
return btnNONE; // when all others fail, return this...
/********** END ow_receive_conformation********************************/
* Function:
* Parameters:
* Returns:
* Description:
/********** END function**********************************************/
* Copyright (C) 2013 Maxim Integrated Products, Inc., All Rights Reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included
* in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
* OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
* IN NO EVENT SHALL MAXIM INTEGRATED BE LIABLE FOR ANY CLAIM, DAMAGES
* OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
* ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
* OTHER DEALINGS IN THE SOFTWARE.
* Except as contained in this notice, the name of Maxim Integrated
* Products, Inc. shall not be used except as stated in the Maxim Integrated
* Products, Inc. Branding Policy.
* The mere transfer of this software does not imply any licenses
* of trade secrets, proprietary technology, copyrights, patents,
* trademarks, maskwork rights, or any other form of intellectual
* property whatsoever. Maxim Integrated Products, Inc. retains all
* ownership rights.
