Page 12 of 21 FirstFirst ... 2 10 11 12 13 14 ... LastLast
Results 276 to 300 of 502
Thread: Prop Shield Beta Test
  1. #276
    Germany NRW
    5,679
    I made a little tool to transfer files from and to the serial flash.
    Would be great if you could test it.
    I plan to extend it, to allow access to the internal eeprom, and maybe, SD.
    Usage:
    • open Arduino, set USB-Mode to "Raw Hid"
    • load teensytransfertool.ino, compile, and flash it to the teensy
    On PC:
    The gz - file contains the Linux-version, the *.zip the Windows-version
    Commandline:
    List files : teensytransfer -l
    Write file to flash : teensytransfer [-w] filename
    Read file from flash : teensytransfer -r filename > file
    Delete file from flash : teensytransfer -e filename
    It should work for the optional flash on the audio shield, too (not tested)
    Sorry, at the moment there is no MAC version (I don't know how to compile it - any hints ? )
    https://github.com/FrankBoesing/TeensyTransfer
    Edit: It would be great if there was a "Serial + Raw Hid" mode..
  2. #277
    May 2015
    San Francisco
    157
    Did you enable pin 5 output HIGH if you are using th eAMP +/-: Prop-Shield-Beta-Test
    I did. Part of the problem was in my code. Gain set too low.
    Set up a trivial 1k sine generator and seeing approx 1.25vpp on the DAC output and at peak I'm seeing a 1:3 duty cycle on the amplifier output, which works out to about 1 watt. All good.
  3. #278
    May 2015
    San Francisco
    157
    This is awesome!
    Don't see the source to the uploader tool, will that be added?
  4. #279
    2,196
    Quote Originally Posted by Ben View Post
    My TestGyroscope program has evolved into something useful and is now called SensorStatistics.ino
    data from my shield
    T      402357
    AX     228.78078   58.08316
    AY     206.97097   60.35888
    AZ     8448.96897   109.68140
    GX     -36.82182   10.15259
    GY     57.46747   5.83436
    GZ     1.26026   4.80394
    MX     585.61662   34.81780
    MY     362.76176   28.28387
    MZ     233.38338   71.03423
    AMag   8454.60658   109.85294
    MMag   727.39721   38.06576
  5. #280
    Germany NRW
    5,679
    Quote Originally Posted by blackketter View Post
    This is awesome!
    i forgot to "sync" .)
    It's online now, in the "extras" folder.
    Yes, it needs a bit cleanup... its a bit "quick and dirty..."
    I use a "LUBUNTU" VM with mingw to compile it.
    Edit:
    The hid - parts are (c) Paul Stoffregen
  6. #281
    2,334
    I think you can use SEREMU when Raw HID
  7. #282
    Germany NRW
    5,679
    I know, but that gives no COM.
    I don't need it for transfer, but it would be handy, because you don't need to switch between Raw Hid and Serial ... or can use both simultanously.
    Edit:
    Fixed a little bug..
  8. #283
    Oct 2012
    Portland OR
    676
    Thanks for the stats program Ben. I ran my device for a while in two different orientations 90 degrees apart. I found that the indicated magnetic field magnitude changed by a factor of two, so it looks like my device is not calibrated at all, even though I ran Paul's calibration routine twice a few days ago and the data is supposed to be in non-volatile memory (?) Device is attached with blu-tack to a PVC pipe with nothing obviously magnetic nearby.
    Orientation #1:
    T      1151535
    AX     95.78476   82.97887
    AY     -146.31886   85.62780
    AZ     8420.29286   127.10109
    GX     -3.97540   10.94797
    GY     1.13623   5.25695
    GZ     1.24945   4.23888
    MX     -151.51830   63.28133
    MY     301.91118   63.38867
    MZ     323.56851   105.54708
    AMag   8422.11877   126.86002
    MMag   467.91951   88.26177
    Orientation#2:
    T      3503084
    AX     8088.87297   77.19855
    AY     951.09982   85.89620
    AZ     -60.34327   121.99499
    GX     -3.57672   11.01727
    GY     0.12062   4.99525
    GZ     1.35267   4.24195
    MX     -440.87618   79.11492
    MY     249.32266   58.89927
    MZ     850.53691   106.00579
    AMag   8144.83313   76.43046
    MMag   989.99544   99.65079
  9. #284
    Senior Member Wozzy's Avatar
    354
    Axis Swapped?
    I've noticed a discrepancy, in my output when using either the Madgwick or Mahony AHRS.
    I see it in multiple examples, but it's very noticible when I run the MadgwickIMU sketch in the NXPMotionSense library
    with the CurieIMU Visualizer withing the Processing IDE
    It seems as if Pitch and Roll are Swapped relative to the Inked Direction Vectors stenciled on the board.
    The stencil does seem to agree with the FXOS8700 orientation.
Name:	FXOS8700 Axis Orientation.JPG
    Pitch should be about the short axis of the Prop Shield (About the Y-Axis)
    Roll should be about the long axis of the Prop Shield (about the X-Axis)
    Also It seems like Roll feeds into Pitch.
    When the device is Yawed 90 degrees both Pitch and Roll output Pitch.
    Is anyone else seeing this?
    Maybe I mucked up one of the library files.
  10. #285
    9,710
    @Ben - I started your code this morning - my unit mostly motionless on my desk . . . I just rotated it some part of 90 at "T 9398309"
    The file ( I had to ZIP it ) : SensorStatistics0101.zip
  11. #286
    Oct 2012
    Portland OR
    676
    Quote Originally Posted by Wozzy View Post
    Also It seems like Roll feeds into Pitch as the device is Yawed at 90 degrees both Pitch and Roll output Pitch.
    Is anyone else seeing this?.
    Yes, that is what I observed also. I assumed it was because the calibration had failed somehow.
  12. #287
    Senior Member sumotoy's Avatar
    Venezia, Italia
    421
    Wozzy,
    I've noted this as well. I have modified a bit the visualizer for Processing to observe this.
    Looks like there's axis swap somewhere, I hope this will fixed soon since this Prop Shield it's really enjoyable!
    Following Processing Code for Visualizer....
    import processing.serial.*;
    Serial myPort;
    int newLine = 13; // new line character in ASCII
    float yaw;
    float pitch;
    float roll;
    String message;
    String [] ypr = new String [3];
      size(600, 500, P3D);
      /*Set my serial port to same as Arduino, baud rate 9600*/
      myPort = new Serial(this, Serial.list()[0], 9600); // if you have only ONE COM port active
      //myPort = new Serial(this, "COM5", 9600);  // if you know the 101 COM port
      textSize(16); // set text size
      textMode(SHAPE); // set text mode to shape
    void draw()
      serialEvent();  // read and parse incoming serial message
      background(255); // set background to white
      translate(width/2, height/2); // set position to centre
      pushMatrix(); // begin object
      rotateX(pitch); // RotateX pitch value
      rotateY(-yaw); // yaw
      rotateZ(-roll); // roll
      drawArduino(); // function to draw rough Arduino shape
      popMatrix(); // end of object
      // Print values to console
      print(pitch);
      print("\t");
      print(roll);
      print("\t");
      print(-yaw);
      println("\t");
      myPort.write("s"); // write an "s" to receive more data from Arduino
    void serialEvent()
      message = myPort.readStringUntil(newLine); // read from port until new line (ASCII code 13)
      if (message != null) {
        ypr = split(message, ","); // split message by commas and store in String array
        yaw = float(ypr[0]); // convert to float yaw
        pitch = float(ypr[1]); // convert to float pitch
        roll = float(ypr[2]); // convert to float roll
    void drawArduino() {
      /* function contains shape(s) that are rotated with the IMU */
      stroke(0, 90, 90); // set outline colour to darker teal
      fill(130, 130, 130); // set fill colour to lighter teal
      box(300, 50, 100); // draw Arduino board base shape
      //stroke(0); // set outline colour to black
      //fill(80); // set fill colour to dark grey
      stroke(13, 250, 109);
      line(-180, 0, 0, 180, 0, 0);
      stroke(19, 13, 250);
      line(0, -80, 0, 0, 80, 0);
      stroke(250, 13, 40);
      line(0, 0, -80, 0, 0, 80);
      //translate(60, -10, 90); // set position to edge of Arduino box
      //box(170, 20, 10); // draw pin header as box
      //translate(-20, 0, -180); // set position to other edge of Arduino box
      //box(210, 20, 10); // draw other pin header as box
  13. #288
    20,576
    I saw the axis swap also. I'm also finding a number of other little issues, while integrating Mahony into the calibration program. Fixing coming soon....
  14. #289
    354
    Quote Originally Posted by sumotoy View Post
    Wozzy,
    Thanks Sumotoy
    I did something very similar to correct the axis Swap.
    The bigger problem which I can't seem to find the error is the Roll feeding into Pitch when the Prop Shield is Yawed 90 deg from the startup position.
    I ran your Processing code, and still see the crosstalk problem.
    I also reloaded all the libraries, and tried several different calibrations.
  15. #290
    354
    Here are my Calibration results and results from Ben's TestGyroscope program at several orientations:
    Magnetic Calibration
    Hard Iron Offset
      -0.59
       2.52
       71.00
    Soft Iron Mapping
       0.9668  -0.0220   0.0160
      -0.0220   0.9792   0.0451
       0.0160   0.0451   1.0592
    Expected Magnetic Field Strength
      50.00 uT
    TestGyroscope Output
    Startup...................
    T      21220
    AX     171.63163    164.09663
    AY     27.79179     92.04478
    AZ     8481.54555   141.54477
    GX     -4.91191     10.38101
    GY     0.40340      5.09261
    GZ     0.83483      5.15205
    MX     27.25225     22.35514
    MY     234.22623    66.75037
    MZ     306.24625    58.61465
    AMag   8483.34253   141.58025
    MMag   386.61695    66.34669
    Pitched 45...................
    T      71573
    AX     3859.75976   114.60355
    AY     -156.56056   135.95800
    AZ     7678.44645   123.94878
    GX     -4.77978     13.56268
    GY     -0.06006     4.96833
    GZ     0.66266      6.59851
    MX     -179.24925   40.78250
    MY     245.70270    66.92656
    MZ     342.29930    53.00151
    AMag   8595.40816   129.20368
    MMag   458.00782    58.36403
    Yawed 90...................
    T      111856
    AX     145.37738    593.37147
    AY     146.01802    1537.11791
    AZ     8478.45445   152.15799
    GX     -3.48949     43.99964
    GY     0.70771      6.19304
    GZ     1.74775      1292.22689
    MX     189.79980    30.24445
    MY     -5.75075     42.11116
    MZ     302.79580    58.25485
    AMag   8481.08300   157.42702
    MMag   357.52273    50.35370
    Yawed 90 & Pitched 45...................
    T      152139
    AX     3849.22122   133.03217
    AY     77.25325     780.29552
    AZ     7678.92693   142.10989
    GX     -4.79179     102.90450
    GY     0.84184      7.77256
    GZ     1.24324      31.32454
    MX     -16.20420    42.83401
    MY     -2.72773     95.92579
    MZ     255.96797    55.01500
    AMag   8590.07022   138.97610
    MMag   256.75076    62.30623
    Yawed 90 & Rolled 45...................
    T      212563
    AX     414.65065    280.96701
    AY     5123.15115   101.65950
    AZ     6492.55656   159.73803
    GX     -4.44645     7.60810
    GY     -0.43343     11.82497
    GZ     1.32833      9.90011
    MX     176.36436    30.44626
    MY     -277.17518   250.87008
    MZ     418.87788    35.18547
    AMag   8280.83984   137.03049
    MMag   532.58679    56.70108
    Return back to startup orientation...................
    T      262918
    AX     169.65365    84.30077
    AY     41.98599     58.51283
    AZ     8481.44945   143.56433
    GX     -5.08809     7.22269
    GY     -0.50050     4.07991
    GZ     0.82482      6.35706
    MX     33.14715     37.86310
    MY     237.66567    40.26486
    MZ     302.91992    59.26813
    AMag   8483.25837   143.64890
    MMag   386.55250    58.66205
  16. #291
    May 2015
    San Francisco
    157
    Quote Originally Posted by GremlinWrangler View Post
    Well it had to be done -- https://github.com/GremlinWrangler/SaberSounds is a try at doing live synth of a light saber like effect, complete with strike/clash detection.
    Great idea! Gotta add that to my string of LEDs with some visual effects.
    None of this is very pretty but currently the biggest issue is that the audio is easily missable in a quiet room at a foot away from the speaker, so much quieter than those cheesy greeting cards. Unsure if this is my speaker being poorly matched to the amp, or the class D amp just can't do much with the fairly bass heavy audio I'm generating.
    It's probably a combination. An efficient speaker can be pretty loud even at 1W. The easiest way to make it more efficient is to put it in a sealed enclosure (and making sure the seal is tight). You can even buy inexpensive speakers already in an enclosure. I'm using one of these, which is well matched to the 1W amp:
    And little speakers aren't going to generate much bass at all. Size does matter.
    Ideally the amp chip would have a little more power (2.5W seems to be a sweet spot to me), not sure if that's something that can be looked at at this time in the development cycle.
  17. #292
    Oct 2012
    Portland OR
    676
    saving stats for plotting
    You can add the following functions to Ben's stats program to get a 23-column table to plot and look for any trends.
    I like the KST Plot program for that purpose, you can double-click on a .csv file and it immedately gives you plots for each column.
    Looks like the variance of the accel(x,y,z) channels are good for seeing if someone walked into the room, as it sees the vibration of the floor.
    void printHeaderLine() {
      Serial.print("T,Ax,AxV,Ay,AyV,Az,AzV,Gx,GxV,Gy,GyV,Gz,GzV,");
      Serial.println("Mx,MxV,My,MyV,Mz,MzV,AMag,AMagV,MMag,MMagV");
    void printStatsLine() {
      Serial.print(millis()/1000.0,1);
      for (int i=0;i<11;i++) {
        Serial.print(",");
        Serial.print(mean[i], 2);
        Serial.print(",");
        Serial.print(variance[i], 2);
  18. #293
    9,710
    ... which is well matched to the 1W amp:
    OP says : 2 watt audio amp
    This larger 2W (3W max) listed;
  19. #294
    May 2015
    San Francisco
    157
    Crazy, not sure how I got 1W into my head for the spec of that amplifier. Sorry 'bout that.
    I'm glad, though I'm not sure what the true output will be.
    I'm a poor EE, but looking at the datasheet, I'm calculating a maximum power of 1.17W.
    EDIT: dac1.analogReference() does the trick. Seeing full power output now. This should probably be documented somewhere...
  20. #295
    Germany NRW
    5,679
    TeensyTransfer:
    Blackketter (thank you!) was so kind and has compiled a MAC version.
    I do not know if it works .. (hint, hint
  21. #296
    Senior Member Pensive's Avatar
    Aug 2014
    Basingstoke, UK
    562
    Hi everyone
    Can anyone confirm - Which pins are absolutely required for operation of the Accelerometer?
    I'm guessing SDL (SCL?),SDA, 3.3v, GND should provide power and i2c connectivity, but will i need 5v, or IRQ? Does the i2c run at 3.3v on Teensy-LC and Teensy 3.2?
    Sorry bit late in the game here, but i need to add sensitive shock sensing to my project and the prop board is ideal, but I can't stack it - I have to mount adjacent as my enclosure is very tight, and similarly i'm all out of pins.
    First step will be a simple shock sensor demo with a software buffer to store the peak shock levels in the last XX milliseconds
    J
  22. #297
    2,196
    I have run shield I2C with just 3.3v/GND/SCL/SDA. The schematic also suggests you just need those 4 wires for I2C.
    EDIT: Actually, connecting pin 2's (I2C IRQ) is probably a good idea.
  23. #298
    354
    Quote Originally Posted by Pensive View Post
    If you're really tight on space you might consider Onehorse's BNO-055 9-axis motion sensor with hardware fusion
    Edit... I just stumbled on to a great comparison that Kris wrote: 9 DoF Motion Sensor Bakeoff
  24. #299
    2,196
    maybe Kris will update his bakeoff with the prop shield sensors ....
  25. #300
    20,576
    After much frustration with wrong results in Arduino's orientation visualizer example, I finally arrived at this conclusion:
