telstar505
Hi! New here so bear with me.
I'm working on a project idea that involves using a Teensy 3.2 board to send mp3 data(not playback) from buffer memory, probably a micro SD card over bluetooth to a smartphone. The maximum size of the mp3 file to be sent is about 300mb(160kbps) so I guess I need Bluetooth v3.0, not BLE. There seems to be a lot of bluetooth packages around but choosing one can get quite confusing!
- Has any of you had good experiences with a particular board that you might recommend?
- Will a serial bluetooth board like the BlueSMiRF work for this use? https://www.sparkfun.com/products/12582
or this Teensy Bluetooth serial module? https://hackerspaceshop.com/collections/teensy/products/teensy-3-1-bluetooth-serial-module
- Also, for this kind of Bluetooth application, would you recommend developing on Android or iOS?
As far as I know I wouldn't need and Apple MFi to perform this kind of task.
This is the setup I'm thinking of. Still in very early stage of development
Thanks a lot!
Thanks a lot!
