Teensy USB not recognised.
Dear Paul,
I'm using teensy seens 2 years, a great board. I purchased 30+ 3.1 and 3.2 boards till now but boards life is not more than 2 or 3 days. Previously i thought thwre must be some problem with my hardware but only teensy working in lab is the first teensy 3.1 later npt a sigle teensy worked for me more than 2 days.. most common problem is with usb teensy not recogised/ code 43 or sometimes its not even showing any message on windows. I tried different computers,operating systems I'm harassed troubleshooting those boards please help!
I have more than failed 18 teensy boards.
Mostly i use teensy jist to get imu data and run micro servos..
I tried bad code recovery process but most of teensy are still dead
Seems very likely something you're connecting to Teensy is stressing it and causing the chip to blow.
Can you try running a Teensy with only the USB cable connect, no other hardware. Just run the LED blink and allow it to blink for more than 2 days. That can at least confirm if Teensy itself works, without the other stuff connected.
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
