Serial locks up when no Serial.read() ?
Jp3141
Simple program outputting some characters. If I type into the serial port (either with Serial Monitor or Coolterm), it frequently hangs when the buffer contains ~30 characters -- not always, but maybe when I cross a 30 (32 ?) threshold within one loop.
void setup() {Serial.begin(9600);}
int i=0;
 //Serial.println(i++);
 Serial.println(Serial.available());
 //while (Serial.available()) Serial.read();
when I enable the Serial.read(), it is 'better' but sometimes still fails.
I this expected ? Even if I don't expect to receive characters in my program, should the Teensy lockup in this way ?
Using Arduino 1.6.7 on OSX 10.9.5; Teensy 3.2
..i tried it, i can't see any fail or hang.
Which OS you are using ? Is it a MAC ?
edit: oops, you mentioned it.
MAC has some problems. Its a Bug in the OS.
