Results 1 to 3 of 3
Thread: AudioOctoWiz
    Junior Member bananaflux's Avatar
    Aug 2015
    DC
    4
    AudioOctoWiz
    Hi Everyone,
    Long time lurker, first time poster! I thought I'd share this project with anyone interested in a general-purpose board to which one can easily attach Neopixels, audio signals and MIDI devices. I have tested most of the features and everything seems to work very well. The PCB and associated design notes can be found on the OSHPark Shared Project Site:
    https://oshpark.com/projects/nWS6zMNn
    The PCB was laid out manually in Diptrace. I attempted to keep analog ground separate from digital ground. Though I did a separate copper pour for the audio ground, it appears that the AGND on the SGTL5000 (SGTL5000 pin 7) is connected to the Teensy's digital ground. I assume one could get a better noise floor if SGTL5000 AGND was isolated from Teensy DGND?
    This is the most complex board layout I've done, and would appreciate any feedback. There is certainly some extraneous copper between some of the traces, but those were difficult to get rid of with the way Diptrace does the copper pours. Also, yes, there is one mistake on the board -- the top silkscreen should read OctoWS2811 in lieu of OctoWS2911! Otherwise, I haven't found any whoopsies.
    Top Copper + Top Silk:
    Bottom Copper:
    Teensy Pad Breakout:
    Audio Octo Board:
    Audio Octo Board, plugged up:
    Here is a video of the system in action with the code shown below:
    https://youtu.be/xgWj9RQGZ4c
    It uses four of the OctoWS2811 "channels", and the pots control the color function. I also welcome any comments on my code!
    #include <OctoWS2811.h>
    #include <Encoder.h>
    #include <Bounce.h>
    const int EncoderOneSwitch = 24;
    const int EncoderOneA = 31;
    const int EncoderOneB = 25;
    const int EncoderTwoSwitch = 28;
    const int EncoderTwoA = 26;
    const int EncoderTwoB = 27;
    const int analogPotOne = A12;
    const int analogPotTwo = A13;
    const int LED = 32;
    const int ledsPerStrip = 64;
    // The display size and color to use
    const unsigned int matrix_width = 32;
    const unsigned int matrix_height = 8;
    // These parameters adjust the vertical thresholds
    const float maxLevel = 0.4;      // 1.0 = max, lower is more "sensitive"
    const float dynamicRange = 40.0; // total range to display, in decibels
    const float linearBlend = 0.3;   // useful range is 0 to 0.7
    DMAMEM int displayMemory[ledsPerStrip*6];
    int drawingMemory[ledsPerStrip*6];
    const int config = WS2811_GRB | WS2811_800kHz;
    AudioInputI2S           audioInput;         // audio shield: mic or line-in
    AudioAnalyzeFFT1024     myFFT;
    AudioOutputI2S          audioOutput;        // audio shield: headphones & line-out
    // Connect live input
    AudioConnection patchCord1(audioInput, 0, myFFT, 0);
    AudioConnection c3(audioInput,0,audioOutput,0);
    AudioConnection c4(audioInput,1,audioOutput,1);
    OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
    const int lowerFFTBins[] = {0,1,2,3,4,5,6,8,10,12,15,18,22,27,32,38,45,53,63,74,87,102,119,138,160,186,216,250,289,334,385,444};
    const int upperFFTBins[] = {0,1,2,3,4,5,7,9,11,14,17,21,26,31,37,44,52,62,73,86,101,118,137,159,185,215,249,288,333,384,443,511};
    float thresholdVertical[matrix_height];
    float thresholdVert[matrix_height];
    Bounce encButton1 = Bounce(EncoderOneSwitch, 5);
    Bounce encButton2 = Bounce(EncoderTwoSwitch, 5);
    Encoder myEnc1(EncoderOneA, EncoderOneB);
    Encoder myEnc2(EncoderTwoA, EncoderTwoB);
      pinMode(EncoderOneSwitch, INPUT_PULLUP);
      pinMode(EncoderTwoSwitch, INPUT_PULLUP);
      pinMode(LED, OUTPUT);
      leds.begin();
      leds.show();
      analogReadResolution(8);
      analogReadAveraging(4);
      AudioMemory(20);
      // compute the vertical thresholds before starting
      computeVerticalLevels();
      for(int i = 0; i < 8; i++){
        Serial.print("thresholdVertical ");
        Serial.print(i);
        Serial.print(" = ");
        Serial.println(thresholdVertical[i]);
      for(unsigned int j = 0; j < matrix_height; j++) {
        thresholdVert[j] = thresholdVertical[matrix_height-j-1];
      // Enable the audio shield and set the output volume.
      audioShield.enable();
      audioShield.inputSelect(myInput);
      audioShield.volume(0.6);
      // Configure the window algorithm to use
      myFFT.windowFunction(AudioWindowHanning1024);
      //myFFT.windowFunction(NULL);
    byte oldEncValue1 = 0;
    byte oldEncValue2 = 0;
    byte color = 0;
    byte bright = 0;
    byte potOne;
    byte potTwo;
    byte mode;
    unsigned int x, y;
    float level;
    elapsedMillis fps;
    elapsedMillis cycle;
    //elapsedMicros xTime;
      if (cycle > 200){
        cycle = 0;
        potOne = analogRead(analogPotOne);
        potTwo = analogRead(analogPotTwo);
        if(potOne >= 0 && potOne < 64){mode = 0;}
        if(potOne >= 64 && potOne < 128){mode = 1;}
        if(potOne >= 128 && potOne < 192){mode = 2;}
        if(potOne >= 192 && potOne < 256){mode = 3;}
      if (myFFT.available()) {
        //xTime = 0;
        switch(mode){
          case 0:
            colorRainbow();
          case 1:
            colorFixed(potTwo);
          case 2:
            colorSweep(potTwo);
          case 3:
            colorBright(potTwo);
          default:
            colorRainbow();
        //Serial.println(xTime);
    void colorRainbow(){
       for(x=0; x < matrix_width; x++){
          level = myFFT.read(lowerFFTBins[x],upperFFTBins[x]);
          for(y=0; y < 8; y++){
            if(level >= thresholdVert[y]){
              leds.setPixel(xy(x,y), Wheel(y*32));
            else {
              leds.setPixel(xy(x,y), 0x000000);
        leds.show();
    void colorFixed(byte c){
              leds.setPixel(xy(x,y), Wheel(c));
            else {
        leds.show();
    void colorSweep(byte p){
        if(fps > p){
          fps = 0;
          color++;
              leds.setPixel(xy(x,y), Wheel(color));
            else {
        leds.show();
    void colorBright(byte c){
            bright = 16+y*24;
          else{
            leds.setPixel(xy(x,y), WheelBright(c, bright));
          else {
      leds.show();
    void colorPixel(byte c){
        for(y=0; y < 7; y++){
          if((level >= thresholdVert[y]) && (level < thresholdVert[y+1])){
            leds.setPixel(xy(x,y), 128);
          else {
      leds.show();
    // Input a value 0 to 255 to get a color value.
    // The colours are a transition r - g - b - back to r.
    uint32_t Wheel(byte WheelPos) {
      WheelPos = 255 - WheelPos;
      if(WheelPos < 85) {
       return color2color(255 - WheelPos * 3, 0, WheelPos * 3);
      } else if(WheelPos < 170) {
        WheelPos -= 85;
       return color2color(0, WheelPos * 3, 255 - WheelPos * 3);
       WheelPos -= 170;
       return color2color(WheelPos * 3, 255 - WheelPos * 3, 0);
    uint32_t WheelBright(byte WheelPos, byte b) {
      if(WheelPos < 85) {
       return color2color(b*(255 - WheelPos * 3)/255, 0, b*(WheelPos * 3)/255);
        WheelPos -= 85;
       return color2color(0, b*(WheelPos * 3)/255, b*(255 - WheelPos * 3)/255);
       WheelPos -= 170;
       return color2color(b*(WheelPos * 3)/255, b*(255 - WheelPos * 3)/255, 0);
    uint32_t color2color(uint8_t r, uint8_t g, uint8_t b) {
      return ((uint32_t)r << 16) | ((uint32_t)g <<  8) | b;
    unsigned int xy(unsigned int x, unsigned int y) {
      return x*8+y;
    // Run once from setup, the compute the vertical levels
    void computeVerticalLevels() {
      unsigned int y;
      float n, logLevel, linearLevel;
      for (y=0; y < matrix_height; y++) {
        n = (float)y / (float)(matrix_height - 1);
        logLevel = pow10f(n * -1.0 * (dynamicRange / 20.0));
        linearLevel = 1.0 - n;
        linearLevel = linearLevel * linearBlend;
        logLevel = logLevel * (1.0 - linearBlend);
        thresholdVertical[y] = (logLevel + linearLevel) * maxLevel;
    I don't know that I'll revisit this anytime soon, but are there any other features others might like to see on a board like this? Certainly the most difficult part of putting this together is the complicated Teensy/Audioboard breakout soldering. It would be so much easier if the SGTL5000 were just directly on the board, but unfortunately, I feel like I need a reflow soldering setup to make that a reality. Quad-channel support would also be nice. Though I've only started to play around with FastLED and APA102s, I regret not putting an easily accessible breakout for level-shifted pins 7 and 14. I would also love to add a nice amp to the two 16-bit outputs. Maybe that's what I can do with all the extra space in the middle of the board!
    This is a really nice build! Thank you for sharing your discoveries when using the Audio and Octo adapters together. Will be having a go at a similar combo as well, and might need some assistance, will send you a PM.
    Hi bananaflux!
    Great job. Nice donee!
    I know that is pretty old topic but still hot. I have similar idea for using octo and audio board simultaneously and I have to find compromise between amount octo “channels” and pins for SGTL 5000 to get maximum functionality without conflicts and errors. In my project I have 1728 leds.
    24 strips and 72 leds per strip. I have plans connecting it in zigzag way.
    6 octo channels if I get, is enough for that I think.
    I’m wondering if you have any progress with your led projects?
