Results 1 to 5 of 5
Thread: Directly connect a USB MIDI controller to a Teensy
    Jun 2015
    11
    Hi!
    What I'd like is to connect a USB MIDI controller directly to a Teensy and make them communicate via MIDI. I can not find similar project, so if you know one, I'd love the link.
    Would it be as straight forward than having a USB plug soldered to VUSB D+ D- GND and an external power supply on Vin and GND? Or is it something I am missing?
    Any input really appreciated! Thank you!
    Senior Member adrian's Avatar
    Oct 2015
    Wellington, NZ
    504
    teensy can not act as a usb midi host... if your controller has old school midi out you are in luck. The whole usb device to teensy as usb host has been discussed a few times. I think the upshot is a usb host board. they are pretty cheap, and output serial to the teensy (from memory). There are a number of posts on the issue. I'll find them for you later .......
    Jun 2015
    11
    Thank you adrian, now I know it is called USB host, it helps a lot.
    So, probably this won't work either?
    https://www.pjrc.com/teensy/td_libs_USBHostShield.html
    I can not find the upshot.
    But I found this:
    http://www.hobbytronics.co.uk/usb-host-midi
    Is it something similar?
    Jun 2015
    11
    This is probably one of the post you spoke about
    https://forum.pjrc.com/threads/27594...has-a-USB-port
    And they suggest this usb host board
    http://www.hobbytronics.co.uk/usb-ho...-host-board-v2
    Oct 2015
    Wellington, NZ
    504
    Yes. You have it
