I have a custom product designed around the teensy 3.2. I used a bad i2c library on it and somehow corrupted its ability to receive a program, both from the arduino IDE and from tyQt. It still runs the firmware I have in it just fine. Pushbutton etc dont work.
1) is there any way to resurrect it without a soldering iron?
2) if I replace the MKL02 will that likely fix it? Or will it be best to also replace the K20 at the same time?
This is a hand soldered first prototype so its possible I have a cold solder joint. I was playing with the said i2c library on an airplane when it failed.
Thanks,
David
Thanks,
David
