start audio file at any point within the file
I would like to be able to play an audio file from a SD card; stop the file and then restart where it left off at a later time. Is there a pointer that can be implemented to start or restart anywhere in the audio file?
This is on the TO-DO list for the audio lib. Here's the closest thing available right now:
https://forum.pjrc.com/threads/32503...t-to-playSDraw
Originally Posted by
PaulStoffregen
Paul,
Thank you for the reply. As a one on the steep side of the learning curve for C, I'm not quite sure of how to incorporate the playSkip function into code. I will try several approaches and see what happens.
I appreciate your response.
TAE
- You may not post replies
- You may not edit your posts
Forum Rules
