Page 6 of 6 FirstFirst ... 4 5 6
Results 126 to 130 of 130
Thread: TeensyTransfer
  1. #126
    Dec 2017
    11
    Thanks, should have googled that one harder. Got the rebuilt executable to run, but having the same problems. Just to clarify, this doesn't need any hardware to run correctly, other than the Teensy and prop shield, yes? Would extra wiring mess it up?
    Also to clarify, by format do you just mean erase it? Or is there extra stuff to do before the flash will accept uploads?
  2. #127
    2,952
    Quote Originally Posted by zenby View Post
    Extra wiring should not make a difference.
    Note, I am not the author of of Teensy Transfer (FrankB is). Typically format means to recreate the file system in the flash.
    I assume you have installed the UDEV rules on your system?
    You might want to watch the system log message to see what kinds of log messages are going by. On older systems, you would create a new terminal window and do:
    sudo tail -f /var/log/messages
    On newer systems you might want to use:
    journalctl -f
  3. #128
    1,917
    Alright, I'm getting a communication error only when I try writing things to the prop shield. I have erased the chip; -l and -i don't give me communication errors. And after I get a communication error I have to unplug it and plug it back in to fix the connection. Any ideas?
    Sorry propshield+TeensyTransfer is still not working for you.
    1) can you attach a photo of your setup (wiring and soldering)
    2) Do the SerialFlash examples work? Examples > SerialFlash > ... first run EraseEverything, then RawHardWareTest (what does RawHardwareTest write on monitor?), then EraseEverything and ListFiles (you may need to run other examples to put files on SerialFlash, or create your own file creation sketch) Note: if you want to run RawHardwareTest again, you must run EraseEverything first. And run EraseEverything before starting to create files.
    3) For TeensyTransfer you have to build and load Examples > TeeensyTransfer > teensytransfertool and in Tools you must change USB Type to Raw HID. What does teensytransfer -i report? teensytransfer -l ? teensytransfer yourfile ?
    4) if you get errors, can you paste into your post the actual messages
  4. #129
    May 2019
    1
    I see this thread is rather old but it still looks like >THE< thread for teensytransfer...
    I have a Teensy3.2 and a prop shield. I have the teenstransfer hex file downloaded to the teensy, but the command prompt program just returns with no output.
    I've tried: teensytransfer -i
    and teensytransfer -l
    I've tried it on two PC's (WIN7 and WIN10) and in both cases there is no return on the console.
    And the weird thing is... the teensytransfer.exe program itself dissapears from my system after I run it. These are work (corporate) PC's so I guess an anti-virus might be the issue, even though I get no notification of malware etc.
  5. #130
    8,325
    Hasn't been much activity with TeensyTransfer recently - it was finicky with a number of steps to get right in the right order as I recall.
    But AFAIK it was last working when the needed steps were found and followed.
