Hello everyone,
For my project I tried to use an HD44780 as Matrix Orbital with temp/fan controller, remote control and power switch on my Openelec media center.
My problem is when i put all the code together my ir remote wont work unless is connected to serial and because of that i cant power on, i've used many hours trying different thing but i cant figure out what im doing wrong.
Im using a Teensy2.0++
Im a noob with out any experience and im trying to learn, so please be kind.
Attached my code.
I think it must have something to do with the rxbyte = serial_getch(); command, but im not sure. Is there a way that i can bypass it so my remote always work or just the power on command?
I hope a kind soul can point me in the right direction so i better can understand this problem and fix it.
Sorry if my english is bad, i try my best.
Attached my code.
#include <math.h>
#include <EEPROM.h>
#include <IRremote.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 11, 7, 8, 9, 10);
int pinButton = 2; //the pin where we connect the button
int fan = 16; // the pin where HDD fan is
int fan2 = 0; // the pin where CPU fan is
int relayPin = 5; // pin out for relay pin
int powerLed = 27; // pin out for Power led
int blueLed = 31; // pin out for Blue led
int greenLed = 30; // pin out for Green led
int RECV_PIN = 4; // pin out for reciever pin
int tempMin = 30; // the temperature to start the fan
int tempMax = 60; // the maximum temperature when fan is at 100%
int fanSpeed;
int fanSpeed2;
int fanLCD;
int fanLCD2;
const int skipRepeat = 3;
int repeatCount = 0;
int lastBtn = 0;
IRrecv irrecv(RECV_PIN);
decode_results results;
// Bit Rate - using 19200 but LCD Smartie defaults to 9600
const int baud = 19200;
// EEPROM address values
const byte BRIGHTNESS = 0; // Brightness
const byte CONTRAST = 1; // Contrast
const byte SERIAL_LO = 2; // Serial number low byte
const byte SERIAL_HI = 3; // Serial number high byte
// IO Pins
const byte GPIO = 6; // D13 - Built in LED on Nano V3.0
const byte backLight = 15; // D10 - Use PWM to change brightness
const byte contrast = 14; // D3 - Use PWM to change contrast
// Variables used in code - can probably optimise some of these out....
byte rxbyte;
byte temp;
byte addr;
byte level;
int val;
int i;
byte data[8]; // buffer for user character data
// Temp Sensor
#define Thermistor1PIN 6 // Analog Pin 6 HDD
#define Thermistor2PIN 7 // Analog Pin 7 CPU
float vcc = 5.06; // only used for display purposes, if used set to the measured Vcc.
float pad7 = 9950; // balance/pad resistor value, set this to
float pad6 = 9930; // the measured resistance of your pad resistor
float thermr = 10000; // thermistor nominal resistance
float Thermistor1(int RawADC) {
long Resistance;
float Temp1; // Dual-Purpose variable to save space.
Resistance=pad6*((1024.0 / RawADC) - 1);
Temp1 = log(Resistance); // Saving the Log(resistance) so not to calculate it 4 times later
Temp1 = 1 / (0.001129148 + (0.000234125 * Temp1) + (0.0000000876741 * Temp1 * Temp1 * Temp1));
Temp1 = Temp1 - 273.15; // Convert Kelvin to Celsius
return Temp1; // Return the Temperature
float Thermistor2(int RawADC) {
long Resistance;
float Temp2; // Dual-Purpose variable to save space.
Resistance=pad7*((1024.0 / RawADC) - 1);
Temp2 = log(Resistance); // Saving the Log(resistance) so not to calculate it 4 times later
Temp2 = 1 / (0.001129148 + (0.000234125 * Temp2) + (0.0000000876741 * Temp2 * Temp2 * Temp2));
Temp2 = Temp2 - 273.15; // Convert Kelvin to Celsius
return Temp2; // Return the Temperature
// Definer 8 karakter-mønstre
byte newChar0[8] = { B10000,B01000,B00100,B00010,B00001,B00010,B00100,B00000}; // >
byte Lae[8] ={ B00000,B00000,B11010,B00101,B01111,B10100,B11111,B00000}; // æ
byte Loe[8] ={ B00000,B00001,B01110,B10101,B10101,B01110,B10000,B00000}; // ø
byte Laa[8] ={ B00100,B00000,B01110,B00001,B01111,B10001,B01111,B00000}; // å
byte Sae[8] ={ B01111,B10100,B10100,B11110,B10100,B10100,B10111,B00000}; // Æ
byte Soe[8] ={ B00001,B01110,B10011,B10101,B11001,B01110,B10000,B00000}; // Ø
byte Saa[8] ={ B00100,B00000,B01110,B10001,B11111,B10001,B10001,B00000}; // Å
byte VT[8] = { B11111,B10101,B10101,B01110,B01110,B00100,B00100,B00000}; // VT
void sendKey(int key) //Send a single key
Keyboard.set_key1(key);
Keyboard.send_now();
Keyboard.set_key1(0);
void sendForButton(int btn) //Map the button and send the command on the Keyboard
if (btn == 0xFFFFFFFF){
repeatCount+=1;
if (repeatCount > skipRepeat){
btn = lastBtn;
return;
repeatCount = 0;
lastBtn = btn;
switch (btn) {
case 0x41E: sendKey(KEY_UP); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //UP
case 0x41F: sendKey(KEY_DOWN); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //DOWN
case 0x420: sendKey(KEY_LEFT); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //LEFT
case 0x421: sendKey(KEY_RIGHT); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //RIGHT
case 0x422: sendKey(KEY_ENTER); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //OK
case 0x423: sendKey(KEY_BACKSPACE); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //BACK
case 0x415: Keyboard.print("r"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //SPOL TILBAGE
case 0x40C: digitalWrite(relayPin, HIGH); delay(500); digitalWrite(relayPin, LOW); digitalWrite(blueLed, LOW); delay(10000); digitalWrite(blueLed, HIGH); break; // POWER ON PC
case 0x414: Keyboard.print("f"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //SPOL FREM
case 0x419: Keyboard.print("x"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //STOP
case 0x416: Keyboard.print(" "); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //PLAY
case 0x412: sendKey(KEY_PAGE_UP); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //CHANNEL UP
case 0x413: sendKey(KEY_PAGE_DOWN); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //CHANNEL DOWN
case 0x40D: Keyboard.print("c"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //WINDOWS
case 0x40F: Keyboard.print("i"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //INFO
case 0x424: Keyboard.print("m"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //DVD MENU
case 0x448: digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //RECORDED TV
case 0x426: digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //GUIDE
case 0x425: digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //LIVE TV
case 0x41B: Keyboard.print(","); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //HOP TILBAGE
case 0x41A: Keyboard.print("."); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //HOP FREM
case 0x40E: sendKey(KEY_F8); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //MUTE
case 0x411: sendKey(KEY_F9); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //VOLUME DOWN
case 0x410: sendKey(KEY_F10); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //VOLUME UP
case 0x400: Keyboard.print("0"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //0
case 0x401: Keyboard.print("1"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //1
case 0x402: Keyboard.print("2"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break;
case 0x403: Keyboard.print("3"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break;
case 0x404: Keyboard.print("4"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break;
case 0x405: Keyboard.print("5"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break;
case 0x406: Keyboard.print("6"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break;
case 0x407: Keyboard.print("7"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break;
case 0x408: Keyboard.print("8"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break;
case 0x409: Keyboard.print("9"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //9
case 0x41D: Keyboard.print("*"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //*
case 0x41C: Keyboard.print("#"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //#
case 0x417: digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //RECORD
case 0x40A: Keyboard.print("KEY_ESC"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //CLEAR
case 0x40B: sendKey(KEY_ENTER); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //ENTER
case 0x45A: digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //TELETEXT
case 0x45B: digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //RØD
case 0x45C: digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //GRØN
case 0x45D: digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //GUL
case 0x45E: digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //BLÅ
case 0x44A: Keyboard.print("t"); digitalWrite(blueLed, LOW); delay(200); digitalWrite(blueLed, HIGH); break; //TEST
default: digitalWrite (blueLed, HIGH);
pinMode(fan, OUTPUT);
pinMode(fan2, OUTPUT);
irrecv.enableIRIn();
pinMode(blueLed, OUTPUT); digitalWrite(blueLed, HIGH); // turn off the blue.
pinMode(greenLed, OUTPUT); digitalWrite(greenLed, HIGH); // turn off the green.
pinMode(powerLed, OUTPUT); analogWrite(powerLed, LOW); // turn off the pled.
pinMode(relayPin, OUTPUT); digitalWrite(relayPin, LOW); // turn off the relay.
pinMode(pinButton, INPUT); //set the button pin as INPUT
// Set the use ouf our output pins
pinMode(GPIO, OUTPUT);
pinMode(backLight, OUTPUT);
pinMode(contrast, OUTPUT);
// Gather default values from EEPROM (could add code here to handle default if EEPROM has never been written to)
digitalWrite(GPIO, LOW);
analogWrite(backLight, EEPROM.read(BRIGHTNESS)); // Read brightness level out of EEPROM
analogWrite(contrast, EEPROM.read(CONTRAST)); // Read contrast level out of EEPROM
// set up the LCD's number of columns and rows:
lcd.begin(20, 4); lcd.clear();
lcd.print(" Display - PS3, DK ");
// Custom Characters for the HTPS Logo
byte htps1[8] = { B10001, B10001, B10001, B11111, B11111, B10001, B10001, B10001 };
byte htps2[8] = { B11111, B11111, B00100, B00100, B00100, B00100, B00100, B00100 };
byte htps3[8] = { B01110, B11011, B10001, B11011, B11110, B10000, B10000, B10000 };
byte htps4[8] = { B01110, B11011, B10001, B11000, B01110, B00001, B11001, B01110 };
lcd.createChar(4, htps1);
lcd.createChar(5, htps2);
lcd.createChar(6, htps3);
lcd.createChar(7, htps4);
lcd.setCursor(1, 2);
lcd.write(4);
lcd.setCursor(2, 2);
lcd.write(5);
lcd.setCursor(3, 2);
lcd.write(6);
lcd.setCursor(4, 2);
lcd.write(7);
lcd.setCursor(8, 2);
// End of custome character generation and display
lcd.print("Input Ready");
lcd.setCursor(8, 3);
lcd.print("19200,8,N,1");
Serial.begin(baud);
// Wait until we receive some data - note we want to hold what data it is as we use it the first iteration
// Clear display, wait a little and load in the custom icons
lcd.clear(); delay(200);
// Generate 3 different bar graph values for 33% 66% and 100%
byte bara[8] = { B10000, B10000, B10000, B10000, B10000, B10000, B11111, B10000 };
byte barb[8] = { B11100, B11100, B11100, B11100, B11100, B11100, B11111, B11100 };
byte barc[8] = { B11111, B11111, B11111, B11111, B11111, B11111, B11111, B11111 };
// Characters for CPU, Nivida Graphics Card, C: drive and D: drive and degrees symbol (DegC)
byte cpu[8] = { B10111, B10101, B10111, B00000, B11101, B10101, B11101, B00000 };
byte nv[8] = { B11101, B10110, B00000, B11111, B11101, B11111, B01100, B00000 };
byte cdrive[8] = { B01100, B10001, B10000, B01101, B00000, B11111, B11101, B11111 };
byte ddrive[8] = { B11000, B10101, B10100, B11001, B00000, B11111, B11101, B11111 };
byte degs[8] = { B11000, B11000, B00000, B00110, B01000, B01000, B00110, B00000 };
// Write characters into LCD RAM
lcd.createChar(0, newChar0); // upload 8 selvdef. karakterer
lcd.createChar(1, barc); lcd.createChar(2, bara); lcd.createChar(3, barb); lcd.createChar(4, cpu);
lcd.createChar(5, nv); lcd.createChar(6, cdrive); lcd.createChar(7, ddrive); lcd.createChar(8, degs);
lcd.createChar(9, VT); // VT ( ;-)
lcd.createChar(10, Lae); // æ
lcd.createChar(11, Loe); // ø
lcd.createChar(12, Laa); // å
lcd.createChar(13, Sae); // Æ
lcd.createChar(14, Soe); // Ø
lcd.createChar(15, Saa); // Å
delay(20); lcd.clear();
// Helper function to read serial input as clean 8 bit byte
byte serial_getch(){ int ch; while (Serial.available() == 0){} ch = Serial.read(); return (byte)(ch & 0xff); } // read the incoming byte:
float temp1; temp1=Thermistor1(analogRead(Thermistor1PIN)); // read ADC and convert it to Celsius
float temp2; temp2=Thermistor2(analogRead(Thermistor2PIN)); // read ADC and convert it to Celsius
if(temp1 < tempMin) { // if temp is lower than minimum temp
fanSpeed = 0; // fan is not spinning
analogWrite(fan, 0);
if((temp1 >= tempMin) && (temp1 <= tempMax)) { // if temperature is higher than minimum temp
fanSpeed = map(temp1, tempMin, tempMax, 32, 255); // the actual speed of fan
fanLCD = map(temp1, tempMin, tempMax, 0, 100); // speed of fan to display on LCD
analogWrite(fan, fanSpeed); // spin the fan at the fanSpeed speed
if(temp1 > tempMax) { // if temp is higher than tempMax
digitalWrite(greenLed, LOW); // turn on led
} else { // else turn of led
if(temp2 < tempMin) { // if temp is lower than minimum temp
fanSpeed2 = 0; // fan is not spinning
analogWrite(fan2, 0);
if((temp2 >= tempMin) && (temp2 <= tempMax)) { // if temperature is higher than minimum temp
fanSpeed2 = map(temp2, tempMin, tempMax, 32, 255); // the actual speed of fan
fanLCD2 = map(temp2, tempMin, tempMax, 0, 100); // speed of fan to display on LCD
analogWrite(fan2, fanSpeed); // spin the fan at the fanSpeed speed
if(temp2 > tempMax) { // if temp is higher than tempMax
if (irrecv.decode(&results)) { results.value &=0x7ff; sendForButton(results.value); delay(100); irrecv.resume(); } // Receive the next IR REMOTE value
if (rxbyte == 254) { //Matrix Orbital uses 254 prefix for commands
switch (serial_getch()) {
case 52: EEPROM.write(SERIAL_HI, serial_getch()); EEPROM.write(SERIAL_LO, serial_getch()); break; //set serial number /*USING EEPROM*/
case 53: Serial.write(EEPROM.read(SERIAL_HI)); Serial.write(EEPROM.read(SERIAL_LO)); break; //read serial number /*USING EEPROM*/
case 54: Serial.write(0x11); break; //read version number v1.1
case 55: Serial.write(0x05); break; //read module lcd_type = 'LCD2041'
case 59: break; //exit flow-control mode
case 64: addr = serial_getch(); val = serial_getch(); EEPROM.write(addr, val); break; // EEPROM Write (address, value)
case 65: addr = serial_getch(); val = EEPROM.read(addr); Serial.print(val); break; // EEPROM Read (address)
case 66: temp = serial_getch(); break; //backlight on (at previously set brightness) NOT implemented
case 67: //auto line-wrap on
case 68: break; //auto line-wrap off
case 70: analogWrite(backLight, 0); analogWrite(powerLed, 0); break; //backlight and powerled off
case 71: temp = (serial_getch() - 1); lcd.setCursor(temp, serial_getch() - 1); break; //set cursor position
case 72: lcd.setCursor(0, 0); break; //cursor home (reset display position)
case 74: lcd.command(0b00001110); break; //show underline cursor
case 75: //underline cursor off
case 84: lcd.command(0b00001100); break; //block cursor off
case 76: lcd.command(16); break; //move cursor left
case 77: lcd.command(20); break; //move cursor right
case 78: temp = serial_getch(); for (i = 0; i < 8; i++){ data[i] = serial_getch(); } lcd.createChar(temp, data); break; //define custom char
case 80: // Set contrast (but we save anyway)
case 145: level = 255 - serial_getch(); analogWrite(contrast, level); EEPROM.write(CONTRAST, level); break; // Set Contrast and save
case 81: //auto scroll on
case 82: break; //auto scroll off
case 83: lcd.command(0b00001111); break; //show blinking block cursor
case 86: temp = serial_getch(); digitalWrite(GPIO, LOW); break; //GPIO OFF
case 87: temp = serial_getch(); digitalWrite(GPIO, HIGH); break; //GPIO ON
case 88: lcd.clear(); break; //clear display, cursor home
case 96: break; //auto-repeat mode off (keypad)
case 98: temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); break; //Draw bitmap
case 99: temp = serial_getch(); break; // set drawing color
case 101: temp = serial_getch(); temp = serial_getch(); break; //Draw line continue
case 104: temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); break; //init horiz bar graph
case 108: temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); break;
case 109: break; //init med size digits
case 112: temp = serial_getch(); temp = serial_getch(); break; // Draw Pixel
case 114: temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); break; //draw rect
case 115: //init narrow vert bar graph
case 118: break; //init wide vert bar graph
case 120: temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); temp = serial_getch(); break; //draw rect solid
// case 145: //defined above see case 80:
case 152: level = serial_getch(); analogWrite(backLight, level); EEPROM.write(BRIGHTNESS, level); break; //set brightness and save
case 153: level = serial_getch(); analogWrite(backLight, level); analogWrite(powerLed, level); break;//set backlight and powerled brightness
default: temp = serial_getch(); break; } //all other commands ignored and parameter byte discarded
} //END OF COMMAND HANDLER
else {
// Not a command character but still might be a special character
//change accented char to plain, detect and change descenders
switch (rxbyte) {
//chars that have direct equivalent in LCD charmap
case 0xE4: rxbyte = 0xE1; break; //ASCII "a" umlaut
case 0xF1: rxbyte = 0xEE; break; //ASCII "n" tilde
case 0xF6: rxbyte = 0xEF; break; //ASCII "o" umlaut
case 0xFC: rxbyte = 0xF5; break; //ASCII "u" umlaut //accented -> plain equivalent and misc symbol translation
case 0xA3: rxbyte = 0xED; break; //sterling (pounds)
case 0xAC: rxbyte = 0xB0; break; //sterling (pounds)
case 0xB0: rxbyte = 0xDF; break; //degrees symbol
case 0xB5: rxbyte = 0xE4; break; //mu
case 0xC0: //"A" variants
case 0xC1:
case 0xC2:
case 0xC3:
case 0xC4:
case 0xC5: rxbyte = 0x41; break;
case 0xC8: //"E" variants
case 0xC9:
case 0xCA:
case 0xCB: rxbyte = 0x45; break;
case 0xCC: //"I" variants
case 0xCD:
case 0xCE:
case 0xCF: rxbyte = 0x49; break;
case 0xD1: rxbyte = 0x43; break; //"N" tilde -> plain "N"
case 0xD2: //"O" variants
case 0xD3:
case 0xD4:
case 0xD5:
case 0xD6:
case 0xD8: rxbyte = 0x4F; break;
case 0xD9: //"U" variants
case 0xDA:
case 0xDB:
case 0xDC: rxbyte = 0x55; break;
case 0xDD: rxbyte = 0x59; break; //"Y" acute -> "Y"
case 0xE0: //"a" variants except umlaut
case 0xE1:
case 0xE2:
case 0xE3:
case 0xE5: rxbyte = 0x61; break;
case 0xE7: rxbyte = 0x63; break; //"c" cedilla -> "c"
case 0xE8: //"e" variants
case 0xE9:
case 0xEA:
case 0xEB: rxbyte = 0x65; break;
case 0xEC: //"i" variants
case 0xED:
case 0xEE:
case 0xEF: rxbyte = 0x69; break;
case 0xDF: //beta // LCDSmartie degree symbol??
case 0xF2: //"o" variants except umlaut
case 0xF3:
case 0xF4:
case 0xF5:
case 0xF8: rxbyte = 0x6F; break;
case 0xF7: rxbyte = 0xFD; break; //division symbol
case 0xF9: //"u" variants except umlaut
case 0xFA:
case 0xFB: rxbyte = 0x75; break;
default: break;
// By now either special character is converted or it was printable already
lcd.print((char)rxbyte); //print it to lcd
rxbyte = serial_getch(); // Wait for the next byte and use value for next iteration
