Adafruit.io MQTT
The MQTT part will be fine, but you don't say how you are getting your Teensy to connect to Adafruit IO?
There will be some minor hurdles there matching up a wifi or ethernet module to work with with the examples but if you can get internet connectivity to work the MQTT should be fine.
Is in you can't compile the library, or you can't get the CC3000 to work for anything?
Before trying to get MQTT to work would suggest getting a handle on basic network connectivity first.
The CC3000 is working, but can't compile the Adafruit MQTT example without errors.
Resuming:
Setup-> teensy 3.1 + CC3000 wifi breakout board + io.adafruit.com account
Testing-> Adafruit MQTT Library (CC3000) -> needs the Adafruit SleepyDog Arduino Library
When I try to verify/compile the mqtt_cc3k (CC3000) example from Adafruit_MQTT_Library the IDE give me errors:
Error compiling for board Teensy 3.2 / 3.1.
Arduino: 1.6.8 (Windows 10), TD: 1.28-beta1, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimized (overclock), US English"
Build options changed, rebuilding all
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:14:4: error: expected constructor, destructor, or type conversion before '(' token
 ISR(WDT_vect)
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp: In member function 'int WatchdogAVR::enable(int)':
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:25:21: error: 'wdt_enable' was not declared in this scope
     wdt_enable(_wdto);
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp: In member function 'void WatchdogAVR::reset()':
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:31:15: error: 'wdt_reset' was not declared in this scope
     wdt_reset();
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp: In member function 'void WatchdogAVR::disable()':
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:36:17: error: 'wdt_disable' was not declared in this scope
     wdt_disable();
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp: In member function 'int WatchdogAVR::sleep(int)':
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:46:5: error: 'uint8_t' was not declared in this scope
     uint8_t wdps = ((sleepWDTO & 0x08 ? 1 : 0) << WDP3) |
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:46:13: error: expected ';' before 'wdps'
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:52:9: error: 'cli' was not declared in this scope
     cli();
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:54:5: error: 'MCUSR' was not declared in this scope
     MCUSR &= ~(1<<WDRF);
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:54:19: error: 'WDRF' was not declared in this scope
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:59:5: error: 'WDTCSR' was not declared in this scope
     WDTCSR |= (1<<WDCE) | (1<<WDE);  // Set WDCE and WDE to enable changes.
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:59:19: error: 'WDCE' was not declared in this scope
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:59:31: error: 'WDE' was not declared in this scope
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:60:14: error: 'wdps' was not declared in this scope
     WDTCSR = wdps;                   // Set the prescaler bit values.
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:61:19: error: 'WDIE' was not declared in this scope
     WDTCSR |= (1<<WDIE);             // Enable only watchdog interrupts.
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:63:9: error: 'sei' was not declared in this scope
     sei();
In file included from %UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:8:0:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/avr/sleep.h:36:23: error: expected primary-expression before 'asm'
 #define sleep_cpu()  (asm("wfi"))
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/avr/sleep.h:38:23: note: in expansion of macro 'sleep_cpu'
 #define sleep_mode()  sleep_cpu()
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:67:5: note: in expansion of macro 'sleep_mode'
     sleep_mode();
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/avr/sleep.h:36:23: error: expected ')' before 'asm'
     sleep_mode();
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:77:25: error: 'wdt_enable' was not declared in this scope
         wdt_enable(_wdto);
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp: In member function 'void WatchdogAVR::_setPeriod(int, int&, int&)':
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:89:20: error: 'WDTO_8S' was not declared in this scope
         wdto     = WDTO_8S;
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:93:20: error: 'WDTO_4S' was not declared in this scope
         wdto     = WDTO_4S;
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:97:20: error: 'WDTO_2S' was not declared in this scope
         wdto     = WDTO_2S;
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:101:20: error: 'WDTO_1S' was not declared in this scope
         wdto     = WDTO_1S;
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:105:20: error: 'WDTO_500MS' was not declared in this scope
         wdto     = WDTO_500MS;
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:109:20: error: 'WDTO_250MS' was not declared in this scope
         wdto     = WDTO_250MS;
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:113:20: error: 'WDTO_120MS' was not declared in this scope
         wdto     = WDTO_120MS;
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:117:20: error: 'WDTO_60MS' was not declared in this scope
         wdto     = WDTO_60MS;
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:121:20: error: 'WDTO_30MS' was not declared in this scope
         wdto     = WDTO_30MS;
%UserProfile%\Documents\Arduino\libraries\Adafruit_SleepyDog_Library\utility\WatchdogAVR.cpp:125:20: error: 'WDTO_15MS' was not declared in this scope
         wdto     = WDTO_15MS;
Adafruit has merged the code, so you can get this working by just getting the latest from Adafruit's library. :)
Edit: oh, and you'll need to remove an AVR define... which I removed here. Maybe wait for 1.28 release (within the next day or two)
Nice, I have been wanting to see good example for MQTT for my ESP8266 on Teensy - so double win here as AdaFruit shows it working on Huzzah!
Good to see Teensy sleep and watchdog too - slight bug in README.md - doesn't note the fixes to include Teensy
Is there a way to wake a Teensy early from Watchdog.sleep(); with a pin interrupt prepared in advance? That would be great to see if so.
Has anyone implemented something similar using the esp8266? I'm looking to use adafruit or aws to do mqtt and I'd like to setup the teensy to work over WiFi for internet connection..
I was thinking of using a particle and passing the payload to the teensy but it would be nice if I could do it all in one..
I have used the above library with ESP8266. You would need to follow the instructions on that page. Mainly:
* Load nodemcu on the 8266.
* Edit the init.lua file
* Upload the init.lua file to node MCU
* Connect the 8266 RX and TX to Teensy's RX and TX.
* Use and modify the example code from that page.
Notice that I have mentioned that I am using this setup to connect to a privately running MQTT. I don't use Adafruit's MQTT server.
HTH
Thanks very much I really appreciate you taking the time.. Sorry I'm totally new to all of this and reading like crazy!
I really hope I can pull this project off haha hoping to do some screen work with a bit of video and a images and then some mqtt to get some servos moving!
An update: while working, the NodeMCU solution was very hard to use/modify.
I have set to a new solution, which is much stable and do not require to flash anything on the ESP8266:
Amazing library that uses AT commands to emulate a "client" library: https://github.com/bportaluri/WiFiEsp
A simple MQTT library that works for me: https://github.com/knolleary/pubsubclient
HTH
hello Do you have any basic code to share - with both libraries mentioned above thanks in advance Charles
This code wasn't intended to more than a prototype, that worked, so I left it as is....
The code is waiting for messages from nRF24L01 and post them to MQTT server.
The most relevant piece of code that you might be interested in is:
WiFiEspClient net;
PubSubClient client(net);
For the rest, just follow the examples on the PubSubClient library.
Hope it will help you.
// undefine this if WIFI settings are hardcoded into nodemcu lua script
#include <RF24.h>
#include "WiFiEsp.h"
#include "WiFiEspClient.h"
#include <PubSubClient.h>
// WIFI settings to pass towards esp
char SSIDNAME[] =  "myssid";
char SSIDPASS[] =  "mypassword";
// baudrate towards computer (USB) and towards esp
#define USB_BAUDRATE  19200
#define ESP_BAUDRATE  19200
int status = WL_IDLE_STATUS; //
WiFiEspClient net;
void messageReceived(char *topic, char *payload, unsigned int length) {
  Serial.print("incoming: ");
  Serial.print(topic);
  Serial.print(" - ");
  Serial.print(payload);
// periodically send data to esp (in milliseconds)
unsigned long interval = 1000;
// general consts
const uint8_t PIN_ESP_ENABLE =  6;
// stop unless you want to modify the code :)
int x = 0;
static char sreg = 0;
static unsigned long previousMillis = 0;
static unsigned long currentMillis = 0;
static boolean connected = 0;
// positions
const uint8_t POS_BASE           = 1;
const uint8_t POS_WORKING_GREEN  = 2;
const uint8_t POS_WORKING_YELLOW = 3;
const uint8_t POS_WORKING_RED    = 4;
const uint8_t POS_LEARNING       = 5;
const uint8_t POS_OTHER          = 6;
const uint8_t POS_NADA           = 7;
uint8_t curPos=POS_NADA;
//radio
RF24 myRadio (14, 16);
byte addresses[][6] = {"1Cube"};
const uint32_t RF_MAGIC_NUMBER        = 136768103;
const uint8_t RF_CHANNEL              = 119;
const uint16_t RF_MILLIS_PACE         = 2000;
const uint8_t RF_MISSING_BITS_COUTNER = 20;
typedef struct  {
    uint32_t magic = RF_MAGIC_NUMBER;
    uint8_t pos;
} tRFData;
tRFData rfData;
unsigned long prevRF = 0;
uint8_t missingBits = RF_MISSING_BITS_COUTNER;
void printPosName(uint8_t pos){
    const char *posNames[8];
    posNames[0] = "NONE";
    posNames[POS_BASE] = "BASE";
    posNames[POS_WORKING_GREEN] = "GREEN";
    posNames[POS_WORKING_YELLOW] = "YELLOW";
    posNames[POS_WORKING_RED] = "RED";
    posNames[POS_LEARNING] = "LEARNING";
    posNames[POS_OTHER] = "OTHER";
    posNames[POS_NADA] = "NADA";
    Serial.print(posNames[pos]);
    // Serial = USB (console)
    // Serial3 = tx3/rx3 - esp
    Serial.begin(USB_BAUDRATE);
    Serial3.begin(ESP_BAUDRATE);
    // wait for serial hardware to finish setup
    while (!Serial3);
    pinMode(PIN_ESP_ENABLE, OUTPUT);
    digitalWrite(PIN_ESP_ENABLE,LOW);
    digitalWrite(PIN_ESP_ENABLE,HIGH);
    WiFi.init(&Serial3);
    if (WiFi.status() == WL_NO_SHIELD) {
         Serial.println("WiFi shield not present");
         // don't continue
         while (true);
    while ( status != WL_CONNECTED) {
        Serial.print("Attempting to connect to WPA SSID: ");
        Serial.println(SSIDNAME);
        // Connect to WPA/WPA2 network
        status = WiFi.begin(SSIDNAME, SSIDPASS);
    client.setServer("myMQTTServerAddress", 1883);
    Serial.println("You're connected to the network");
    printWifiData();
    printCurrentNet();
    // if not connected and stuff then restart and init
    Serial.flush();
    myRadio.begin();
    myRadio.setChannel(RF_CHANNEL);
    myRadio.setPALevel(RF24_PA_HIGH);
    myRadio.openReadingPipe(0, addresses[0]); // Use the first entry in array 'addresses' (Only 1 right now)
    myRadio.startListening();
    Serial.println("After RF init");
    MQTT_connect();
void MQTT_connect() {
  Serial.print("checking wifi...");
  while (WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  Serial.print("\nconnecting...");
  while (!client.connect("taskCubeMQTTz")) {
    Serial.print(".");
  Serial.println("\nconnected!");
  // client.unsubscribe("/example");
void printWifiData()
  // print your WiFi shield's IP address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print your MAC address
  byte mac[6];
  WiFi.macAddress(mac);
  char buf[20];
  sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", mac[5], mac[4], mac[3], mac[2], mac[1], mac[0]);
  Serial.print("MAC address: ");
  Serial.println(buf);
void printCurrentNet()
  // print the SSID of the network you're attached to
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print the MAC address of the router you're attached to
  byte bssid[6];
  WiFi.BSSID(bssid);
  char buf[20];
  sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", bssid[5], bssid[4], bssid[3], bssid[2], bssid[1], bssid[0]);
  Serial.print("BSSID: ");
  // print the received signal strength
  long rssi = WiFi.RSSI();
  Serial.print("Signal strength (RSSI): ");
  Serial.println(rssi);
    if(!client.connected()) {
        MQTT_connect();
    currentMillis = millis();
    // RF24
    if (currentMillis - prevRF >=  RF_MILLIS_PACE) {
        if (myRadio.available()) {
            myRadio.read(&rfData, sizeof(rfData));
            if (rfData.magic == RF_MAGIC_NUMBER) {
                printPosName(rfData.pos);
                curPos=rfData.pos;
                Serial.println(' ');
                Serial.println("Error in receiving");
            //read rest of buffer
            while(myRadio.available()) {
            if (missingBits == 0) {
                curPos = POS_NADA;
                missingBits--;
        //convert int to char
        char buf[5];
        String(curPos).toCharArray(buf,5);
        client.publish("taskCube/status",buf);
        prevRF = currentMillis;
