Results 1 to 3 of 3
Thread: How to create a new USB device type with a Teensy 3.2
    Member Etienne's Avatar
    Mar 2016
    Ardeche, France
    50
    I'm trying to create a new USB device type with a Teensy 3.2, which will present a Joystick hid and a virtual serial interface. It is working but as I would like to include FFB feature to the joystick (and raw Hid as well later), I need another endpoint and a different descriptor. I have a working FFB descriptor from another project, but as I would like to avoid breaking the Joystick that is already available, I would like to have a new type of interface.
    To have the Joystick+Emulated Serial, I did this :
    I modified the usb_desc.h file in the teensy3 core, and added a new type that I've called "USB_FFB_RAWHID" with the following definitions :
    	#elif defined(USB_FFB_RAWHID)
    		#define VENDOR_ID		0x16C0
    		#define PRODUCT_ID		0x048A
    		#define MANUFACTURER_NAME		{'A','i','-','W','a','v','e'}
    		#define MANUFACTURER_NAME_LEN	7
    		#define PRODUCT_NAME			{'E','S','P',' ','W','h','e','e','l'}
    		#define PRODUCT_NAME_LEN		9
    		#define EP0_SIZE				64
    		#define NUM_ENDPOINTS			3
    		#define NUM_USB_BUFFERS	 	24
    		#define NUM_INTERFACE			2
    		#define JOYSTICK_INTERFACE		0// Joystick
    		#define JOYSTICK_ENDPOINT	        3
    		#define JOYSTICK_SIZE		        16
    		#define JOYSTICK_INTERVAL	        2
    	        #define SEREMU_INTERFACE      1	// Serial emulation
    		#define SEREMU_TX_ENDPOINT    1
    		#define SEREMU_TX_SIZE        64
    		#define SEREMU_TX_INTERVAL    1
    		#define SEREMU_RX_ENDPOINT    2
    		#define SEREMU_RX_SIZE        32
    		#define SEREMU_RX_INTERVAL    2
    		#define ENDPOINT1_CONFIG	ENDPOINT_TRANSIMIT_ONLY
    		#define ENDPOINT2_CONFIG	ENDPOINT_RECEIVE_ONLY
    		#define ENDPOINT3_CONFIG	ENDPOINT_TRANSIMIT_ONLY
    I also modified the boards.txt that you find in the "arduino-1.6.7\hardware\teensy\avr folder", I added the following lines just after "teensy31.menu.usb.rawhid.fake_serial=teensy_gatew ay":
    teensy31.menu.usb.ffb_hid=Joystick
    teensy31.menu.usb.ffb_hid.build.usbtype=USB_FFB_RAWHID
    teensy31.menu.usb.ffb_hid.fake_serial=teensy_gateway
    If I select "Joystick" in the "Arduino/Tools/Usb Type" menu, it is working as expected, which is pretty cool.
    Now I want to add FFB support, so I replaced the all the JOYSTICK_xxx defines with "FFB_JOYSTICK_xxx" defines, which results in usb_desc.h is :
    		#define EP0_SIZE				64
    		#define FFB_JOYSTICK_INTERFACE		0// Joystick
    		#define FFB_JOYSTICK_TX_ENDPOINT	3
    		#define FFB_JOYSTICK_TX_SIZE		16
    		#define FFB_JOYSTICK_TX_INTERVAL	1
    I also duplicated all the code in usb_desc.c where I have "#ifdef JOYSTICK_INTERFACE" and have replaced with "#ifdef FFB_JOYSTICK_INTERFACE" :
    static uint8_t ffb_joystick_report_desc[] = {
    	0x05, 0x01,                     // Usage Page (Generic Desktop)
    	0x09, 0x04,                     // Usage (Joystick)
    	0xA1, 0x01,                     // Collection (Application)
    	0x15, 0x00,                     // Logical Minimum (0)
    	0x25, 0x01,                     // Logical Maximum (1)
    	0x75, 0x01,                     // Report Size (1)
    	0x95, 0x20,                     // Report Count (32)
    	0x05, 0x09,                     // Usage Page (Button)
    	0x19, 0x01,                     // Usage Minimum (Button #1)
    	0x29, 0x20,                     // Usage Maximum (Button #32)
    	0x81, 0x02,                     // Input (variable,absolute)
    	0x25, 0x07,                     // Logical Maximum (7)
    	0x35, 0x00,                     // Physical Minimum (0)
    	0x46, 0x3B, 0x01,               // Physical Maximum (315)
    	0x75, 0x04,                     // Report Size (4)
    	0x95, 0x01,                     // Report Count (1)
    	0x65, 0x14,                     // Unit (20)
    	0x09, 0x39,                     // Usage (Hat switch)
    	0x81, 0x42,                     // Input (variable,absolute,null_state)
    	0x09, 0x01,                     // Usage (Pointer)
    	0xA1, 0x00,                     // Collection ()
    	0x26, 0xFF, 0x03,               //   Logical Maximum (1023)
    	0x75, 0x0A,                     //   Report Size (10)
    	0x95, 0x04,                     //   Report Count (4)
    	0x09, 0x30,                     //   Usage (X)
    	0x09, 0x31,                     //   Usage (Y)
    	0x09, 0x32,                     //   Usage (Z)
    	0x09, 0x35,                     //   Usage (Rz)
    	0xC0,                           // End Collection
    	0x95, 0x02,                     // Report Count (2)
    	0x09, 0x36,                     // Usage (Slider)
    	0xC0                            // End Collection
    #define FFB_JOYSTICK_INTERFACE_DESC_POS	JOYSTICK_INTERFACE_DESC_POS+JOYSTICK_INTERFACE_DESC_SIZE
    #define FFB_JOYSTICK_INTERFACE_DESC_SIZE	9+9+7
    #define FFB_JOYSTICK_HID_DESC_OFFSET	FFB_JOYSTICK_INTERFACE_DESC_POS+9
    #else
    #define FFB_JOYSTICK_INTERFACE_DESC_SIZE	0
    I also modified the line related to the MTP device :
    #define MTP_INTERFACE_DESC_POS		FFB_JOYSTICK_INTERFACE_DESC_POS+FFB_JOYSTICK_INTERFACE_DESC_SIZE
    Added also
    		// interface descriptor, USB spec 9.6.5, page 267-269, Table 9-12
    		9,                                      // bLength
    		4,                                      // bDescriptorType
    		FFB_JOYSTICK_INTERFACE,                     // bInterfaceNumber
    		0,                                      // bAlternateSetting
    		1,                                      // bNumEndpoints
    		0x03,                                   // bInterfaceClass (0x03 = HID)
    		0x00,                                   // bInterfaceSubClass
    		0x00,                                   // bInterfaceProtocol
    		0,                                      // iInterface
    		// HID interface descriptor, HID 1.11 spec, section 6.2.1
    		9,                                      // bLength
    		0x21,                                   // bDescriptorType
    		0x11, 0x01,                             // bcdHID
    		0,                                      // bCountryCode
    		1,                                      // bNumDescriptors
    		0x22,                                   // bDescriptorType
    		LSB(sizeof(ffb_joystick_report_desc)),      // wDescriptorLength
    		MSB(sizeof(ffb_joystick_report_desc)),
    		// endpoint descriptor, USB spec 9.6.6, page 269-271, Table 9-13
    		7,                                      // bLength
    		5,                                      // bDescriptorType
    		FFB_JOYSTICK_TX_ENDPOINT | 0x80,        // bEndpointAddress
    		0x03,                                   // bmAttributes (0x03=intr)
    		FFB_JOYSTICK_TX_SIZE, 0,                // wMaxPacketSize
    		FFB_JOYSTICK_TX_INTERVAL,               // bInterval
    #endif // FFB_JOYSTICK_INTERFACE
    and finally :
    	{ 0x2200, FFB_JOYSTICK_INTERFACE, ffb_joystick_report_desc, sizeof(ffb_joystick_report_desc) },
    	{ 0x2100, FFB_JOYSTICK_INTERFACE, config_descriptor + FFB_JOYSTICK_HID_DESC_OFFSET, 9 },
    After these changes, the device is still recognised under windows but it doesn't behave as before (axis are not moving anymore).
    I tried to create a new folder called "usb_ffb_hid" by duplicating the folder "usb_hid" at the same level as the "teensy3" core folder, but when I change the code in "usb.c" of this folder, it doesn't seem to be taken into account.
    So my question is : these folders (usb_disk,usb_flightsim,usb_hid, etc...) that you find near teensy3, are they used with the teensy 3.2 board ?
    I don't know where to look for in order to have my new interface type working like the first type I did, and also where to look for to add the code dealing with FFB, anyone having any idea ?
    Edit : I got it working as the initial joystick I did, it was the code I modified in joystick.cpp that was wrong. Now the axis are moving again. But to go further (adding FFB), my questions about the folders remain (usb_disk,usb_flightsim,usb_hid, etc...).
    22,753
    Quote Originally Posted by Etienne View Post
    No, those are all for Teensy 2.0 & Teensy++ 2.0.
    My earlier USB code for Teensy 2.0 wasn't designed to be flexible, so more device types were added by making more copies.
    Mar 2016
    Ardeche, France
    50
    Ok thank you very much for the quick reply.
    So I guess that everything happens in usb_dev.c if I want to deal with force feedback reports ?
