Results 1 to 3 of 3
Thread: AudioInputAnalog circuit sensitivity
    Mar 2016
    7
    I'm using the circuit from:
    http://www.pjrc.com/teensy/gui/?info=AudioInputAnalog
    With a Teensy LC, what component would I adjust to alter the sensitivity? I'm using this with headphone output from an MP3 player.
    I'm also passing through the audio signal to an amp/headphones.
    Thanks,
    David
    20,761
    None of the Teensy Audio Library works on Teensy-LC yet. Someday a subset of the library will support LC, and some initial work has already started towards that goal... but a *lot* more remains to be done to port to LC's less powerful DMA controller.
    Today only Teensy 3.0, 3.1, 3.2 are supported so far.
    Mar 2016
    7
    Hi Paul,
    I'm using the LCAnalyzeFFT library which is working ok for my needs (simple beat detection)
    However the output data seems quite low unless I max out the volume on the mp3 player.
Tags for this Thread
