Results 1 to 5 of 5
Thread: Teensyduino v1.28 OS X installer "damaged"
    Aug 2014
    6
    Downloaded Teensyduino v1.28 today and got an error that Teensyduino.app was damaged and could no be opened. D/L'd again with no help (same checksum.) I notice that the v1.27 installer is 111MB whereas the v1.28 installer is 97MB. This on OS X El Capitan v10.11.4 (latest version as of this date.)
    See attached screenshot of error.
    MD5sum of my download:
    ~ $ openssl dgst -md5 < installed/teensyduino-v1.28.dmg
    99abc53b68f99b860e5d385d75381e4e
    Thanks for your help.
Name:	v1.28 error.png
    21,319
    Can you try running this command in a Terminal window (in the directory with the application, probably /Volumes/Teensyduino)
    codesign -d -vvvv teensyduino.app/
    Hopefully this will give some more info about why it's broken.
    Aug 2014
    6
    Here you go.
    /Volumes/Teensyduino $ codesign -d -vvvv teensyduino.app/
    Executable=/Volumes/Teensyduino/teensyduino.app/Contents/MacOS/TeensyduinoInstall
    Identifier=com.pjrc.teensyduino
    Format=app bundle with Mach-O thin (i386)
    CodeDirectory v=20200 size=4804 flags=0x0(none) hashes=233+3 location=embedded
    Hash type=sha1 size=20
    CandidateCDHash sha1=59b183bd2cc62e772c02f85a8a700a14a746b6c2
    Hash choices=sha1
    CDHash=59b183bd2cc62e772c02f85a8a700a14a746b6c2
    Signature size=8548
    Authority=Developer ID Application: PJRC.COM, LLC
    Authority=Developer ID Certification Authority
    Authority=Apple Root CA
    Timestamp=Apr 10, 2016, 6:29:38 AM
    Info.plist entries=16
    TeamIdentifier=MN24EXDEN2
    Sealed Resources version=2 rules=12 files=4
    Internal requirements count=1 size=180
    Thanks.
    21,319
    All that info looks correct. The MD5 matches my copy here. I'm afraid I just do not know why it's failing.
    Aug 2014
    6
    Doh! On a whim I rebooted my machine and after that the v1.28 installer completed just fine. I have no idea what the reboot cleared up, but all's well now.
