Problem with time library on arduino 1.0.5
NicolasAK
Hi all,
I'm a big noob when it comes to arduino and I'm having a hard time getting my code to compile. After commenting irrelevant parts that worked fine, I only left code related to the time library and giving errors. Here is my code:
#include <Arduino.h>
#include <stdio.h>
#include </home/user/Desktop/solarfurnace/asm/unistd.h>
#include <math.h>
#include </home/user/Desktop/solarfurnace/Time/Time/Time.h>
#include </home/user/Desktop/solarfurnace/Helios/Helios.h>
#include </home/user/Desktop/solarfurnace/AccelStepper/AccelStepper.h>
#define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
#define TIME_REQUEST 7 // ASCII bell character requests a time sync message
void setup ()
setSyncProvider(requestSync); //set function to call when sync required
Serial.println("Waiting for sync message");
void loop ()
if(Serial.available() )
processSyncMessage();
void processSyncMessage() {
// if time sync available from serial port, update time and return true
while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of a header and ten ascii digits
char c = Serial.read() ;
Serial.print(c);
if( c == TIME_HEADER ) {
time_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
c = Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
setTime(pctime); // Sync Arduino clock to the time received on the serial port
time_t requestSync()
Serial.print(TIME_REQUEST,byte(0));
return 0; // the time will be sent later in response to serial mesg
When i try to compile it, I get the following error:
_L_control.cpp.o: In function `loop':
/usr/share/arduino/O_L_control.ino:87: undefined reference to `setSyncProvider(unsigned long (*)())'
/usr/share/arduino/O_L_control.ino:87: undefined reference to `setTime(unsigned long)'
collect2: error: ld returned 1 exit status
Can you help me figure it out?
Why are you using such an old version of Arduino?
Why are your files included from /home/user/Desktop/solarfurnace/AccelStepper and not the specified Arduino user libraries folder?
I Arduino is linking your library files correctly. You need to install them from the dropdown menu from with the Arduino enviroment
This code was initially written by a group of students who built the solar furnace in question . I'm modifying it,so I took the file with all the stuff they had. As for the old version, I thought that since they did this work years ago, it might be a version issue so I installed an old one :p
Can you post the contents of "/home/user/Desktop/solarfurnace/Time/Time/Time.h" please?
Also what device is this for?
time.h - low level time and date functions
July 3 2011 - fixed elapsedSecsThisWeek macro (thanks Vincent Valdy for this)
- fixed daysToTime_t macro (thanks maniacbug)
#ifndef _Time_h
#define _Time_h
#include <inttypes.h>
typedef unsigned long time_t;
typedef enum {timeNotSet, timeNeedsSync, timeSet
} timeStatus_t ;
typedef enum {
dowInvalid, dowSunday, dowMonday, dowTuesday, dowWednesday, dowThursday, dowFriday, dowSaturday
} timeDayOfWeek_t;
typedef enum {
tmSecond, tmMinute, tmHour, tmWday, tmDay,tmMonth, tmYear, tmNbrFields
} tmByteFields;
typedef struct {
uint8_t Second;
uint8_t Minute;
uint8_t Hour;
uint8_t Wday; // day of week, sunday is day 1
uint8_t Day;
uint8_t Month;
uint8_t Year; // offset from 1970;
} tmElements_t, TimeElements, *tmElementsPtr_t;
//convenience macros to convert to and from tm years
#define tmYearToCalendar(Y) ((Y) + 1970) // full four digit year
#define CalendarYrToTm(Y) ((Y) - 1970)
#define tmYearToY2k(Y) ((Y) - 30) // offset is from 2000
#define y2kYearToTm(Y) ((Y) + 30)
typedef time_t(*getExternalTime)();
//typedef void (*setExternalTime)(const time_t); // not used in this version
/* Useful Constants */
#define SECS_PER_MIN (60UL)
#define SECS_PER_HOUR (3600UL)
#define SECS_PER_DAY (SECS_PER_HOUR * 24UL)
#define DAYS_PER_WEEK (7UL)
#define SECS_PER_WEEK (SECS_PER_DAY * DAYS_PER_WEEK)
#define SECS_PER_YEAR (SECS_PER_WEEK * 52UL)
#define SECS_YR_2000 (946684800UL) // the time at the start of y2k
/* Useful Macros for getting elapsed time */
#define numberOfSeconds(_time_) (_time_ % SECS_PER_MIN)
#define numberOfMinutes(_time_) ((_time_ / SECS_PER_MIN) % SECS_PER_MIN)
#define numberOfHours(_time_) (( _time_% SECS_PER_DAY) / SECS_PER_HOUR)
#define dayOfWeek(_time_) ((( _time_ / SECS_PER_DAY + 4) % DAYS_PER_WEEK)+1) // 1 = Sunday
#define elapsedDays(_time_) ( _time_ / SECS_PER_DAY) // this is number of days since Jan 1 1970
#define elapsedSecsToday(_time_) (_time_ % SECS_PER_DAY) // the number of seconds since last midnight
// The following macros are used in calculating alarms and assume the clock is set to a date later than Jan 1 1971
// Always set the correct time before settting alarms
#define previousMidnight(_time_) (( _time_ / SECS_PER_DAY) * SECS_PER_DAY) // time at the start of the given day
#define nextMidnight(_time_) ( previousMidnight(_time_) + SECS_PER_DAY ) // time at the end of the given day
#define elapsedSecsThisWeek(_time_) (elapsedSecsToday(_time_) + ((dayOfWeek(_time_)-1) * SECS_PER_DAY) ) // note that week starts on day 1
#define previousSunday(_time_) (_time_ - elapsedSecsThisWeek(_time_)) // time at the start of the week for the given time
#define nextSunday(_time_) ( previousSunday(_time_)+SECS_PER_WEEK) // time at the end of the week for the given time
/* Useful Macros for converting elapsed time to a time_t */
#define minutesToTime_t ((M)) ( (M) * SECS_PER_MIN)
#define hoursToTime_t ((H)) ( (H) * SECS_PER_HOUR)
#define daysToTime_t ((D)) ( (D) * SECS_PER_DAY) // fixed on Jul 22 2011
#define weeksToTime_t ((W)) ( (W) * SECS_PER_WEEK)
/* time and date functions */
int hour(); // the hour now
int hour(time_t t); // the hour for the given time
int hourFormat12(); // the hour now in 12 hour format
int hourFormat12(time_t t); // the hour for the given time in 12 hour format
uint8_t isAM(); // returns true if time now is AM
uint8_t isAM(time_t t); // returns true the given time is AM
uint8_t isPM(); // returns true if time now is PM
uint8_t isPM(time_t t); // returns true the given time is PM
int minute(); // the minute now
int minute(time_t t); // the minute for the given time
int second(); // the second now
int second(time_t t); // the second for the given time
int day(); // the day now
int day(time_t t); // the day for the given time
int weekday(); // the weekday now (Sunday is day 1)
int weekday(time_t t); // the weekday for the given time
int month(); // the month now (Jan is month 1)
int month(time_t t); // the month for the given time
int year(); // the full four digit year: (2009, 2010 etc)
int year(time_t t); // the year for the given time
time_t now(); // return the current time as seconds since Jan 1 1970
void setTime(time_t t);
void setTime(int hr,int min,int sec,int day, int month, int yr);
void adjustTime(long adjustment);
/* date strings */
#define dt_MAX_STRING_LEN 9 // length of longest date string (excluding terminating null)
char* monthStr(uint8_t month);
char* dayStr(uint8_t day);
char* monthShortStr(uint8_t month);
char* dayShortStr(uint8_t day);
/* time sync functions */
timeStatus_t timeStatus(); // indicates if time has been set and recently synchronized
void setSyncProvider( getExternalTime getTimeFunction); // identify the external time provider
void setSyncInterval(time_t interval); // set the number of seconds between re-sync
/* low level functions to convert to and from system time */
void breakTime(time_t time, tmElements_t &tm); // break time_t into elements
time_t makeTime(tmElements_t &tm); // convert time elements into time_t
#endif /* _Time_h */
This is a code run on Arduino mega 2560
Thanks a lot for the help ^^
Looks like an old version of the Time lib.
Get the newest version. Changes were made for compatibility with newer Arduino.
