I have gotten a lot of dust and particles on theTeensy 3.2 because the PCB which it was soldered onto was trimmed down. I know it is generally safe, but I wanted to ask anyways whether it is safe to use normal Isopropyl Alcohol (91%) to clean the Teensy? I was planning on just pouring the alcohol over the teensy and lightly running a toothbrush over it. Or Should I just dip the toothbrush in the alcohol and clean the teensy with the wet toothbrush?
Was planning on using this: http://www.walgreens.com/store/c/walgreens-isopropyl-alcohol-91/ID=prod6056571-product
-Thank You
-Thank You
