ornaments+crimes extended / polymorphic 16bit CV genererator
mxxx
ornaments+crimes extended / polymorphic 16bit CV generator
fyi / fwiw ...
since this is built around a teensy 3.x, i figured why not post it here, too:
the hardware has been around for a while, but there has been in the works a/the new and proper firmware (in the creation of which i wasn't really involved) which turns the module in a nifty, multi-function CV generator/processor (for use with modular synthesizers):
the beta release can be found here: https://github.com/mxmxmx/O_C , including the schematics, gerber files, and a fair amount of code.
the main purpose of this is producing precision control voltages, but there's a couple of random and LFO-type functionalities included, too. a/the bottle neck in this regard was the single SPI port, which is shared by the DAC8565 and the OLED, so achieving decent sample rates was tricky/impossible; we ended up using a custom SPIFIFO/DMA driver for the DAC and OLED which manages 16.6kHz and draws/write single pages, so as to minimize any interference with time-sensitive stuff. not too bad, but a second SPI port would have been convenient ...
anyways, here's a little run-down of what it does:
* CopierMaschine: is an enhanced version of the original quantising digital emulation of a four stage analogue shift register (ASR).
* Harrington 1200: provides basic neo-Riemannian Tonnetz transformations of triadic chords, triggered by the digital (gate/trigger) inputs.
* Automatonnetz: combines Tonnetz transforms with a "vector" sequencer - it can be both a chord sequencer and a melody sequencer, but not of the usual kind.
* Quantermain: is a quad pitch quantiser for external voltages, with editable preset scales, even fully editable user-scales incl. microtonal tunings, etc; it can do clocked (trigger-driven) quantising, or continuous quantising, with a latency of under 100 microseconds; it also features quad Turing Machines and/or May-Verhulst logistic maps as optional, semi-random, internally generated CV sources.
* Quadraturia: is a wavetable quadrature LFO, based on the "Easter egg" in the Mutable Instruments Frames module.
* Low-rents: is a dual Lorenz and Rössler (strange attractor) modulation generator, partially based on the "Easter egg" in the Mutable Instruments Streams module.
* Piqued: is a quad voltage-controlled envelope generator, based on envelope generator code from the Mutable Instruments Peaks module, but extending it with voltage control, additional envelope types, including re-triggering (looping) envelopes, additional segment shapes, adjustable trigger delays, and a unique Euclidean "trigger filter" which turns the app into a Euclidean rhythm generator which can output envelopes, not just gate or trigger pulses.
* Dialectic Ping Pong: is a quad bouncing ball envelope generator, based on a hidden mode of the Mutable Instruments Peaks module.
* Viznutcracker, sweet!
: is a quad "byte beat" equation generator, which can be used as an audio source to generate curious but often interesting 8-bit noises and tunes, or which can be clocked by an external source to produce "byte beat" control voltage sequences.
* References: is a simple utility app that outputs specific reference voltages on each channel to help tune or calibrate VCOs and other modules.
hardware:
- teensy 3.1 / 3.2
- 4x precision CV outputs, 16-bit (TI DAC8565), output range: -3v / +6v, "in-the-loop" compensated, for best DC accuracy, with 9 calibration points at -3v to +6V per channel settable in firmware to ensure excellent linearity (+/- 1mV accuracy across a 9 octave pitch CV range is achievable).
- 4x CV inputs, -3.5v / +6.5v, 12bit, 100k input impedance.
- 4x trigger/gate inputs, threshold ~ 2.5v, 100k input impedance.
- two rotary encoders, with built-in push switches.
- two push buttons.
- 128 x 64 pixel 1.3" OLED display (SPI / SH1106 driver chip).
- trigger-to-quantised-output latency < 100 microseconds
- apps use a 16.7kHz internal timer (CPU overclocked to 120MHz), therefore the DAC update (sample) rate is 16.7kHz on each of the 4 channels.
- ADCs are also read at 16.7kHz but in many of the "apps" running on O+C, 16 values are averaged to remove noise, meaning that the effective sample rate for CV inputs is about 1 kHz. Digital (gate/trigger) inputs are read at 16.7 KHz - this ensures very low latency.
- +/-12V power only, ca. 85mA power draw on +12V bus, much less on -12V bus).
WOW. just WOW
soundclips of what this does with a synth? I take it that it generates control patterns for synth parameters? analog control signals!
MAN, this is a whole new world .... how does it plug in to an amp:rolleyes:
yes, just control patterns. so it'll really depend on what else is in your system, which mode you use, and so on.
the initial "ASR" (analogue shift register) function is a classic from the 70s; it's commonly used to generate "arabesque" patterns.
i don't have any proper soundclips. here's a test-track though, made with one of the early prototypes where you can sort of hear the "arabesque" thing (driving 4 analog oscillators/voices, in this case):
https://soundcloud.com/menschenimhotel/further-memory-problems
and here's a crappy phone video showing the ASR screen saver:
the other modes, say the chaotic functions stuff, would have very different effects on whatever else sits downstream, of course.
Merci. I will look at this when I am not at work ... AWESOME
thanks.
here's another one:
that's quad quantiser mode (in the video, only two channels are being used (one driving an oscillator, the other modulating the cut-off of a filter)). typically you'd use that to process incoming control voltages / force them to a particular scale (Volt/octave). in this case, we included some additional features, where the source "voltage" is generated internally. LFSR type things, in this case.
Mxmxmx,
Can I ask how you're driving the OLED? I've picked up one of thos 1.3" oleds SPI with sh1106 chipset and I'm struggling to find a working driver for it. It appears you were using a hacked version of u8glib but I see you dropped it a couple of months ago from the repo. How are you now doing your rendering?
Mxmxmx,
hi mongrol,
sorry, only seen this now. yeah, i/we used u8glib initially, but it was too inefficient (probably not an issue in general, but in this case, consistently updating the DAC8565 at a somewhat decent sample rate was/is the main priority, as was not wasting too much time with drawing frames so that the input/output latency is low); we only kept the init sequence from u8glib, most the rest works very different. see here for the basic driver code. this renders + sends the pages individually, most of the SPI happens via DMA, so it's generally quicker and doesn't delay time-critical stuff as badly.
it should be possible to repurpose that for other stuff, though using u8glib will be more straightforward. this is still using u8glib (NB: SPI clock is pin 14 in this case, so you might need to adjust spi4teensy, too)
