I'm trying to clock in 61 bits which are purely multiplexed data (no communication protocol - pure bits). It has a corresponding clock signal. I've largely had success by running an interrupt routine by taking the clock rising edge and then reading the bit on DATA_PIN, but I fear it is not robust. I do get transients where bits seem to be a little garbled which is what I'm trying to fix.
The clock runs at approximately 60 kHz. The teensy 3.2 is overclocked at 96MHz. This gives me approximately (1 / 60e3 ) / (1 / 96e6) = 1600 clock cycles to obtain the bit before the next rising edge occurs. I'm not entirely sure if this is sufficient.
I know the Arduino has a ShiftIn() function in its API but I do not see one for the Teensy. Does anyone have suggestions for this?
Thanks,
Amar
Thanks,
Amar
