Results 1 to 21 of 21
Thread: Teensy 3.2 Sound Level Meter (sound measurement device)
    Feb 2016
    5
    Hi, I have been working for some time now on creating a sound level meter using the Teensy 3.2 (since it is perfect for this application). A SLM can be used for measuring sound pressure levels and reporting them an an A-weighted dB(sound pressure level), which is the NIOSH standard for measuring sound. At the moment it seems to be accurate to around 1-3 dB, but I am sure it can be improved (hoping for a little help from all you experts out there). I am hoping that this code will be good enough for people to be able to use for sound measurement with audio equipment, or for safety monitoring. I have built off the FFT library and used a lot of help from an open MIT course (http://alumni.media.mit.edu/~dlanman...ibel_meter.pdf). I have a few questions (and I am sure I have made some mistakes) about my code.
    First: Here is my code
    /* This program first computes a 1024 point FFT using the Audio Library provided by Pual Stoffregen. It then applies an a-weighting to the samples, sums them,
     *  then converts to dB SPL. Here, I have used the ADC for the microphone input instead of the audio shield. The Audio design tool provided by PJRC can be used to set up the
     *  audio connection. The microphone ciruit I used can be found at http://electronics.stackexchange.com/questions/16595/how-to-make-a-clean-amplified-microphone-analog-to-digital-conversion
     *  and is designed by Olin Lathrop I replaced R7 and R8 with 47K resistors. I also used the circuit diagram in the Audio design tool on PJRC (under the ADC tab there is a sample circuit). To provide a DC offset of .6V.
    #define GREEN 10
    float n;
    int i;
    float v[512] = {0};
    float magnitude = 0;
    float dB_holder;
    int db_int;
    float a_weight[512] = {0.000491601, 0.007439144, 0.026456683, 0.057237193, 0.097648235, 0.145530499, 0.19895028, 0.256192702, 0.315753433, 0.376341431, 0.436880336, 0.496502258, 0.554533348, 0.610473237, 0.663971116, 0.714800959, 0.762837753, 0.808035908, 0.85041046, 0.890021233, 0.926959868, 0.961339445, 0.993286373, 1.022934171, 1.050418819, 1.075875354, 1.099435459, 1.12122582, 1.141367062, 1.159973138, 1.177151032, 1.193000704, 1.207615207, 1.221080906, 1.233477786, 1.244879798, 1.255355228, 1.264967081, 1.273773452, 1.281827897, 1.289179783, 1.29587462, 1.301954369, 1.307457742, 1.312420463, 1.316875521, 1.320853401, 1.324382291, 1.327488281, 1.330195534, 1.332526449, 1.334501812, 1.336140927, 1.337461742, 1.338480956, 1.339214128, 1.339675764, 1.339879407, 1.33983771, 1.33956251, 1.339064892, 1.338355246, 1.337443324, 1.336338287, 1.33504875, 1.333582824, 1.331948154, 1.330151954, 1.328201037, 1.326101843, 1.323860472, 1.3214827, 1.318974007, 1.316339599, 1.313584419, 1.310713175, 1.307730349, 1.304640214, 1.301446848, 1.298154147, 1.294765835, 1.291285478, 1.28771649, 1.284062146, 1.280325589, 1.276509835, 1.272617788, 1.268652238, 1.264615874, 1.260511287, 1.256340974, 1.252107348, 1.247812737, 1.243459393, 1.239049492, 1.234585143, 1.230068386, 1.2255012, 1.220885501, 1.216223152, 1.211515958, 1.206765674, 1.201974005, 1.19714261, 1.1922731, 1.187367045, 1.182425973, 1.177451372, 1.172444693, 1.167407348, 1.162340715, 1.157246139, 1.152124932, 1.146978373, 1.141807712, 1.136614169, 1.131398936, 1.126163178, 1.120908033, 1.115634612, 1.110344003, 1.105037268, 1.099715447, 1.094379556, 1.08903059, 1.083669521, 1.078297301, 1.072914859, 1.067523108, 1.062122937, 1.05671522, 1.05130081, 1.045880542, 1.040455233, 1.035025683, 1.029592675, 1.024156975, 1.018719333, 1.013280482, 1.00784114, 1.00240201, 0.996963778, 0.991527118, 0.986092686, 0.980661126, 0.975233068, 0.969809127, 0.964389904, 0.958975988, 0.953567954, 0.948166364, 0.942771769, 0.937384705, 0.932005696, 0.926635255, 0.921273883, 0.915922069, 0.91058029, 0.905249011, 0.899928687, 0.894619763, 0.88932267, 0.88403783, 0.878765656, 0.873506548, 0.868260896, 0.863029082, 0.857811477, 0.852608441, 0.847420326, 0.842247473, 0.837090216, 0.831948877, 0.826823771, 0.821715204, 0.816623471, 0.811548862, 0.806491654, 0.80145212, 0.796430522, 0.791427115, 0.786442146, 0.781475853, 0.776528467, 0.771600212, 0.766691304, 0.761801951, 0.756932355, 0.752082709, 0.747253202, 0.742444013, 0.737655316, 0.732887277, 0.728140056, 0.723413808, 0.71870868, 0.714024813, 0.709362343, 0.704721397, 0.700102099, 0.695504567, 0.690928912, 0.686375241, 0.681843653, 0.677334244, 0.672847104, 0.668382317, 0.663939963, 0.659520116, 0.655122846, 0.650748219, 0.646396293, 0.642067124, 0.637760764, 0.633477258, 0.629216649, 0.624978975, 0.620764269, 0.616572561, 0.612403877, 0.608258238, 0.604135661, 0.600036161, 0.595959749, 0.59190643, 0.587876209, 0.583869084, 0.579885053, 0.575924108, 0.571986239, 0.568071433, 0.564179674, 0.560310942, 0.556465216, 0.552642469, 0.548842674, 0.5450658, 0.541311815, 0.537580682, 0.533872363, 0.530186816, 0.526524, 0.522883867, 0.519266371, 0.51567146, 0.512099084, 0.508549187, 0.505021714, 0.501516605, 0.498033801, 0.49457324, 0.491134857, 0.487718587, 0.484324362, 0.480952113, 0.47760177, 0.47427326, 0.47096651, 0.467681443, 0.464417985, 0.461176056, 0.457955577, 0.454756467, 0.451578645, 0.448422028, 0.445286531, 0.442172069, 0.439078556, 0.436005904, 0.432954025, 0.429922829, 0.426912226, 0.423922125, 0.420952434, 0.41800306, 0.41507391, 0.412164889, 0.409275902, 0.406406853, 0.403557647, 0.400728185, 0.397918372, 0.395128108, 0.392357295, 0.389605834, 0.386873625, 0.384160569, 0.381466565, 0.378791512, 0.37613531, 0.373497856, 0.37087905, 0.368278789, 0.36569697, 0.363133492, 0.360588252, 0.358061147, 0.355552074, 0.353060929, 0.35058761, 0.348132012, 0.345694033, 0.343273569, 0.340870517, 0.338484772, 0.336116231, 0.333764791, 0.331430348, 0.329112798, 0.326812038, 0.324527964, 0.322260474, 0.320009464, 0.31777483, 0.315556471, 0.313354282, 0.311168162, 0.308998008, 0.306843717, 0.304705188, 0.302582319, 0.300475007, 0.298383152, 0.296306653, 0.294245408, 0.292199316, 0.290168278, 0.288152193, 0.286150961, 0.284164484, 0.28219266, 0.280235393, 0.278292582, 0.276364131, 0.27444994, 0.272549913, 0.270663953, 0.268791961, 0.266933843, 0.265089501, 0.263258841, 0.261441767, 0.259638183, 0.257847996, 0.256071111, 0.254307435, 0.252556875, 0.250819337, 0.249094729, 0.247382959, 0.245683935, 0.243997567, 0.242323763, 0.240662434, 0.239013489, 0.23737684, 0.235752397, 0.234140071, 0.232539776, 0.230951422, 0.229374924, 0.227810195, 0.226257148, 0.224715697, 0.223185759, 0.221667247, 0.220160077, 0.218664167, 0.217179432, 0.215705789, 0.214243158, 0.212791454, 0.211350598, 0.209920507, 0.208501103, 0.207092304, 0.205694032, 0.204306207, 0.202928752, 0.201561587, 0.200204635, 0.19885782, 0.197521065, 0.196194293, 0.19487743, 0.193570399, 0.192273127, 0.19098554, 0.189707563, 0.188439124, 0.187180149, 0.185930567, 0.184690306, 0.183459294, 0.182237461, 0.181024737, 0.179821051, 0.178626335, 0.177440519, 0.176263535, 0.175095315, 0.173935792, 0.172784898, 0.171642567, 0.170508733, 0.16938333, 0.168266293, 0.167157558, 0.166057059, 0.164964734, 0.163880519, 0.162804351, 0.161736168, 0.160675908, 0.159623508, 0.158578909, 0.157542048, 0.156512867, 0.155491306, 0.154477304, 0.153470803, 0.152471745, 0.151480071, 0.150495724, 0.149518647, 0.148548783, 0.147586076, 0.146630469, 0.145681907, 0.144740336, 0.143805699, 0.142877944, 0.141957016, 0.141042862, 0.140135428, 0.139234663, 0.138340513, 0.137452928, 0.136571854, 0.135697243, 0.134829041, 0.133967201, 0.133111671, 0.132262402, 0.131419345, 0.130582451, 0.129751671, 0.128926959, 0.128108265, 0.127295544, 0.126488747, 0.125687829, 0.124892743, 0.124103444, 0.123319885, 0.122542022, 0.121769811, 0.121003206, 0.120242164, 0.119486641, 0.118736594, 0.117991979, 0.117252754, 0.116518877, 0.115790306, 0.115066999, 0.114348914, 0.113636011, 0.112928249, 0.112225587, 0.111527986, 0.110835406, 0.110147807, 0.109465151, 0.108787398, 0.108114511, 0.10744645, 0.106783179, 0.106124659, 0.105470853, 0.104821725, 0.104177238, 0.103537355, 0.10290204, 0.102271258, 0.101644973, 0.10102315, 0.100405754, 0.09979275, 0.099184104, 0.098579782, 0.09797975, 0.097383975, 0.096792423, 0.096205061, 0.095621857, 0.095042778, 0.094467792, 0.093896867, 0.093329972, 0.092767075, 0.092208144, 0.091653149, 0.09110206, 0.090554845, 0.090011475, 0.08947192, 0.088936151, 0.088404136, 0.087875849, 0.087351259, 0.086830338};
    // Sample time in milliseconds
    unsigned long Sampletime_ms = 1000;
    unsigned long Starttime;
    int l = 0;
    AudioInputAnalog         adc1;           //xy=155,82
    AudioAnalyzeFFT1024      fft1024_1;      //xy=348,95
    AudioConnection          patchCord1(adc1, fft1024_1); //created using the Teensy Audio design GUI
    //AudioSynthWaveformSine sinewave;// Generate sine wave to analyze, un-comment sinewave.frequency and sinewave.amplitude in setup
    //AudioConnection patchCord1(sinewave, 0, fft1024_1, 0); //Generate input signal for test, do not change these #s
      AudioMemory(12);
      Wire.begin(8); //I2c communication w/ Arduino
      Wire.onRequest(requestEvent); //I2C communication with Arduino
      fft1024_1.windowFunction(AudioWindowHanning1024);
      pinMode( GREEN, OUTPUT); //toggle led after each send to arduino
      //sinewave.amplitude(0.4); // From 0 at min to 1 at max
      //sinewave.frequency(1000.0); //Anywhere from 0 to 20kHz
      magnitude = 0;
      dB_holder = 0;
      //get the current time;
      Starttime = millis();
      while((millis() - Starttime) < Sampletime_ms){
        if (fft1024_1.available()) {
          for (i=0; i<511; i++) {
            n = fft1024_1.read(i);
            n = n * a_weight[i];
            v[i] = n;
            v[i] = 0.001953125 * pow(v[i],2); // 1/512 samples = .0019....
            magnitude = v[i] + magnitude;
          magnitude = db(magnitude);
          dB_holder = dB_holder + magnitude;
          magnitude = 0;
          ++l;
      dB_holder=dB_holder/l;
      db_int = (int) dB_holder;
      Serial.println(db_int);
      l = 0;
    float db(float n) {
       return log10f(n) * 10.0f + 125;
    void requestEvent() { //I2C communiation with Arduino. I am using the Arduino as a central hub for attaching many other types of sensors, including this one.
      byte myArray[1];
      myArray[0] = db_int;
      Wire.write(myArray, 1);
      digitalWrite(GREEN, HIGH);
      digitalWrite(GREEN, LOW);
    As you can see I have made a lookup table for the A-weighting and it is rather long. In the future I will make it a separate header file, but at the moment this works.
    My First question I have is what the sample length of the FFT function is. I have assumed that it is 512, because in the Hanning window Paul normalizes with this number (1/512). Is this correct? If this is true would the sample time period be then 512/44.1k = .0116s? I use this number when I am summing the individual magnitudes. The only reason I ask is because I would like to make a "slow" response time of 1s, so instead of changing the FFT sample number, I just run the regular loop over 1 second and average the dB levels over that period. I do not think this is the best way to do the sampling. My second question is whether I am correctly applying the weighting filter. Using the generated sine wave, it seems to respond correctly when changing the frequency while keeping the intensity at the same level. It also seems to respond well with the microphone and a produced noise, until I get into higher frequencies and I begin to see attenuation of the signal, which might very well just be the microphone and amplifying circuit (in which case I will change the A-weighting table to include a linearizing correction factor for the microphone input.) I also decided to sum all the real valued input signals (1/N(magnitude)^2) instead of 1/2 of them because I felt wierd excluding half of the sample data. Any help would be very much appreciated, and if there is something I can do to help make this code more usable for someone else, please let me know.
    Feb 2016
    5
    I realize that it may be hard to calibrate to dBspl if you do not use the same microphone I use. I am wondering how accurate it would be to calibrate based off of the microphones given sensitivity in the data sheets. If someone reading this would like to use the same microphone I am using, it is the electret taken off of the Adafruit max4466 breakout board. I decided to use my own amplifying circuit because the Adafruit circuit seems to have a large drop off in gain at any frequency above 8kHz. The microphone itself fairly linear, so I used it.
    Taken this code and simplified it, made some changes as the SPL calculation was off.. noise floor is a bit higher than I would expect from 13 bit, but otherwise it works great. Trying to make this into a 8x octave band SPL meter, with 1000ms or 125ms averaging options. Comments and tips are highly appreciated:
    /* Uses ADC1 as analog audio input, computes a 1024 point single sided spectrum using FFT1024 in the Audio Library provided by Pual Stoffregen.
     *  It then applies an a-weighting to the 512 single sided spectum bins,
     *  It sums the squareroot of the frequency bins, and squares it again after the suming of all freqeuncy bins is complete.
     *  It then takes the 20 * Log10 to obtaine  dBA SPL figure
     *  For testing I used a Panasonic wm-34a electret, fed from the 3.3V, through a 4k7 resistor. Signal output was taken from the 4k7 resitor via a 1uF
     *  capacitor to pin 16 (a.k.a A2). It callibrated to 94.04dB and 113.97dB with a B&K type 4231 callibrator, settles to 69.2dB without sound (noise floor)
     *  Thijs SchramaŽ04-05-2019
    int i;
    float v[512] = {0};
    float dB_holder;
    AudioConnection          patchCord1(adc1, fft1024_1); //created using the Teensy Audio design GUI, comment out for testing a simulated signal
    //prepare simulated signal, uncomment for testing a simulated signal
      analogReadResolution(16);
      AudioMemory(12);
      //generate simulated signal, uncomment for testing a simulated signal
      //sinewave.amplitude(0.05);        //  0 min to 1  max
      //sinewave.frequency(1000.0);     //  Anywhere from 0 to 20000
          magnitude = 0;
          dB_holder = 0;
          float v[512] = {0};
          for (i=0; i<512; i++) {
            v[i] = fft1024_1.read(i) * a_weight[i];
            magnitude = magnitude + sq(v[i]);
          magnitude = sqrt(magnitude);
          dB_holder = log10f(magnitude) * 20  + 125.05;
          Serial.println(dB_holder,2); // f[23] = 1kHz, f[82] = 3.5kHz, f[252] = 12kHz
    Got the octaveband SPL meter working usethe spectrum BIN weigthing factors for each octave band. These BIN weigthing factor BTW, were squared by the OP; they were way off! So I had the sqrt them again, or type in 512 individual numbers
    Especially in the higher bands, there is an elevated noise floor. This seems to be gereated by the FFT routine, as the floor floor is also present when I use a AudioSynthWaveformSineHires. Too bad I cann't make a 1/3rd octave SPL meter; that would require a longer FFT length.
    I hope some people will try out this code and give me some feedback. these are my first step in TeensyLand
     *  It then takes the 20 * Log10 to obtain  the dBA SPL figure
     *  octaveband BIN numbers (@ fft1024, fs=44.1kHz) could be improve by fractional BIN weigthing:
     *  2, 3/4, 5/8, 9/16, 17/32, 33/65 , 66/131, 132/262
    AudioSynthWaveformSineHires sine_hires1;    //xy=167,294
    AudioInputAnalog         adc1;           //xy=191,184
    AudioMixer4              mixer1;         //xy=373,182
    AudioAnalyzeFFT1024      fft1024_1;      //xy=421,292
    AudioConnection          patchCord1(sine_hires1, 0, mixer1, 1);
    AudioConnection          patchCord2(adc1, 0, mixer1, 0);
    AudioConnection          patchCord3(mixer1, fft1024_1);
    float a_weight[] = {0.000491601, 0.007439144, 0.026456683, 0.057237193, 0.097648235, 0.145530499, 0.19895028, 0.256192702, 0.315753433, 0.376341431, 0.436880336, 0.496502258, 0.554533348, 0.610473237, 0.663971116, 0.714800959, 0.762837753, 0.808035908, 0.85041046, 0.890021233, 0.926959868, 0.961339445, 0.993286373, 1.022934171, 1.050418819, 1.075875354, 1.099435459, 1.12122582, 1.141367062, 1.159973138, 1.177151032, 1.193000704, 1.207615207, 1.221080906, 1.233477786, 1.244879798, 1.255355228, 1.264967081, 1.273773452, 1.281827897, 1.289179783, 1.29587462, 1.301954369, 1.307457742, 1.312420463, 1.316875521, 1.320853401, 1.324382291, 1.327488281, 1.330195534, 1.332526449, 1.334501812, 1.336140927, 1.337461742, 1.338480956, 1.339214128, 1.339675764, 1.339879407, 1.33983771, 1.33956251, 1.339064892, 1.338355246, 1.337443324, 1.336338287, 1.33504875, 1.333582824, 1.331948154, 1.330151954, 1.328201037, 1.326101843, 1.323860472, 1.3214827, 1.318974007, 1.316339599, 1.313584419, 1.310713175, 1.307730349, 1.304640214, 1.301446848, 1.298154147, 1.294765835, 1.291285478, 1.28771649, 1.284062146, 1.280325589, 1.276509835, 1.272617788, 1.268652238, 1.264615874, 1.260511287, 1.256340974, 1.252107348, 1.247812737, 1.243459393, 1.239049492, 1.234585143, 1.230068386, 1.2255012, 1.220885501, 1.216223152, 1.211515958, 1.206765674, 1.201974005, 1.19714261, 1.1922731, 1.187367045, 1.182425973, 1.177451372, 1.172444693, 1.167407348, 1.162340715, 1.157246139, 1.152124932, 1.146978373, 1.141807712, 1.136614169, 1.131398936, 1.126163178, 1.120908033, 1.115634612, 1.110344003, 1.105037268, 1.099715447, 1.094379556, 1.08903059, 1.083669521, 1.078297301, 1.072914859, 1.067523108, 1.062122937, 1.05671522, 1.05130081, 1.045880542, 1.040455233, 1.035025683, 1.029592675, 1.024156975, 1.018719333, 1.013280482, 1.00784114, 1.00240201, 0.996963778, 0.991527118, 0.986092686, 0.980661126, 0.975233068, 0.969809127, 0.964389904, 0.958975988, 0.953567954, 0.948166364, 0.942771769, 0.937384705, 0.932005696, 0.926635255, 0.921273883, 0.915922069, 0.91058029, 0.905249011, 0.899928687, 0.894619763, 0.88932267, 0.88403783, 0.878765656, 0.873506548, 0.868260896, 0.863029082, 0.857811477, 0.852608441, 0.847420326, 0.842247473, 0.837090216, 0.831948877, 0.826823771, 0.821715204, 0.816623471, 0.811548862, 0.806491654, 0.80145212, 0.796430522, 0.791427115, 0.786442146, 0.781475853, 0.776528467, 0.771600212, 0.766691304, 0.761801951, 0.756932355, 0.752082709, 0.747253202, 0.742444013, 0.737655316, 0.732887277, 0.728140056, 0.723413808, 0.71870868, 0.714024813, 0.709362343, 0.704721397, 0.700102099, 0.695504567, 0.690928912, 0.686375241, 0.681843653, 0.677334244, 0.672847104, 0.668382317, 0.663939963, 0.659520116, 0.655122846, 0.650748219, 0.646396293, 0.642067124, 0.637760764, 0.633477258, 0.629216649, 0.624978975, 0.620764269, 0.616572561, 0.612403877, 0.608258238, 0.604135661, 0.600036161, 0.595959749, 0.59190643, 0.587876209, 0.583869084, 0.579885053, 0.575924108, 0.571986239, 0.568071433, 0.564179674, 0.560310942, 0.556465216, 0.552642469, 0.548842674, 0.5450658, 0.541311815, 0.537580682, 0.533872363, 0.530186816, 0.526524, 0.522883867, 0.519266371, 0.51567146, 0.512099084, 0.508549187, 0.505021714, 0.501516605, 0.498033801, 0.49457324, 0.491134857, 0.487718587, 0.484324362, 0.480952113, 0.47760177, 0.47427326, 0.47096651, 0.467681443, 0.464417985, 0.461176056, 0.457955577, 0.454756467, 0.451578645, 0.448422028, 0.445286531, 0.442172069, 0.439078556, 0.436005904, 0.432954025, 0.429922829, 0.426912226, 0.423922125, 0.420952434, 0.41800306, 0.41507391, 0.412164889, 0.409275902, 0.406406853, 0.403557647, 0.400728185, 0.397918372, 0.395128108, 0.392357295, 0.389605834, 0.386873625, 0.384160569, 0.381466565, 0.378791512, 0.37613531, 0.373497856, 0.37087905, 0.368278789, 0.36569697, 0.363133492, 0.360588252, 0.358061147, 0.355552074, 0.353060929, 0.35058761, 0.348132012, 0.345694033, 0.343273569, 0.340870517, 0.338484772, 0.336116231, 0.333764791, 0.331430348, 0.329112798, 0.326812038, 0.324527964, 0.322260474, 0.320009464, 0.31777483, 0.315556471, 0.313354282, 0.311168162, 0.308998008, 0.306843717, 0.304705188, 0.302582319, 0.300475007, 0.298383152, 0.296306653, 0.294245408, 0.292199316, 0.290168278, 0.288152193, 0.286150961, 0.284164484, 0.28219266, 0.280235393, 0.278292582, 0.276364131, 0.27444994, 0.272549913, 0.270663953, 0.268791961, 0.266933843, 0.265089501, 0.263258841, 0.261441767, 0.259638183, 0.257847996, 0.256071111, 0.254307435, 0.252556875, 0.250819337, 0.249094729, 0.247382959, 0.245683935, 0.243997567, 0.242323763, 0.240662434, 0.239013489, 0.23737684, 0.235752397, 0.234140071, 0.232539776, 0.230951422, 0.229374924, 0.227810195, 0.226257148, 0.224715697, 0.223185759, 0.221667247, 0.220160077, 0.218664167, 0.217179432, 0.215705789, 0.214243158, 0.212791454, 0.211350598, 0.209920507, 0.208501103, 0.207092304, 0.205694032, 0.204306207, 0.202928752, 0.201561587, 0.200204635, 0.19885782, 0.197521065, 0.196194293, 0.19487743, 0.193570399, 0.192273127, 0.19098554, 0.189707563, 0.188439124, 0.187180149, 0.185930567, 0.184690306, 0.183459294, 0.182237461, 0.181024737, 0.179821051, 0.178626335, 0.177440519, 0.176263535, 0.175095315, 0.173935792, 0.172784898, 0.171642567, 0.170508733, 0.16938333, 0.168266293, 0.167157558, 0.166057059, 0.164964734, 0.163880519, 0.162804351, 0.161736168, 0.160675908, 0.159623508, 0.158578909, 0.157542048, 0.156512867, 0.155491306, 0.154477304, 0.153470803, 0.152471745, 0.151480071, 0.150495724, 0.149518647, 0.148548783, 0.147586076, 0.146630469, 0.145681907, 0.144740336, 0.143805699, 0.142877944, 0.141957016, 0.141042862, 0.140135428, 0.139234663, 0.138340513, 0.137452928, 0.136571854, 0.135697243, 0.134829041, 0.133967201, 0.133111671, 0.132262402, 0.131419345, 0.130582451, 0.129751671, 0.128926959, 0.128108265, 0.127295544, 0.126488747, 0.125687829, 0.124892743, 0.124103444, 0.123319885, 0.122542022, 0.121769811, 0.121003206, 0.120242164, 0.119486641, 0.118736594, 0.117991979, 0.117252754, 0.116518877, 0.115790306, 0.115066999, 0.114348914, 0.113636011, 0.112928249, 0.112225587, 0.111527986, 0.110835406, 0.110147807, 0.109465151, 0.108787398, 0.108114511, 0.10744645, 0.106783179, 0.106124659, 0.105470853, 0.104821725, 0.104177238, 0.103537355, 0.10290204, 0.102271258, 0.101644973, 0.10102315, 0.100405754, 0.09979275, 0.099184104, 0.098579782, 0.09797975, 0.097383975, 0.096792423, 0.096205061, 0.095621857, 0.095042778, 0.094467792, 0.093896867, 0.093329972, 0.092767075, 0.092208144, 0.091653149, 0.09110206, 0.090554845, 0.090011475, 0.08947192, 0.088936151, 0.088404136, 0.087875849, 0.087351259, 0.086830338};
    int oct             = 0;                                   // octaveband counter
    int i               = 0;                                   // freq bin counter
    int n               = 0;                                   // averaging counter
    int ave             = 11;                                  // nr of averages
    float v[511]        = {0};                                 // bin magnitude values
    float magn[]        = {0,0,0,0,0,0,0,0};                   // temporaly magnitude of 8 bands
    float magn_f[]      = {0,0,0,0,0,0,0,0};                   // final magnitude of 8 bands after averaging
    float dB_oct[]      = {0,0,0,0,0,0,0,0};                   // dB converted value of 8 bands after averaging
    int bin_low[]       = {0, 2, 5, 10, 22, 41,  83, 166 };    // lowest  BIN number to include for 8 octavebands
    int bin_high[]      = {1, 3, 6, 12, 25, 50, 102, 204 };    // highest BIN number to include for 8 octavebands
    float mes = 0.00;
      sine_hires1.amplitude(1);     // generate a high resolution sine for testing
      sine_hires1.frequency(1000);   // set the frequency
      mixer1.gain(0, 1);            // mix in the the ADC Microphone
      mixer1.gain(1, 0);            // or mix the generated sine for testing
      fft1024_1.windowFunction(AudioWindowHanning1024); // Hanning for best, broadband, out of band, attenuation
      AudioMemory(12);
        magn[0]  = 0;                                          //reset the temporaly octavebands magnitue values to zero
        magn[1]  = 0;
        magn[2]  = 0;
        magn[3]  = 0;
        magn[4]  = 0;
        magn[5]  = 0;
        magn[6]  = 0;
        magn[7]  = 0;
        for (oct=0; oct<8; oct++) {                               // repeat 8 times for 8 octave bands
          for (i=bin_low[oct]; i<bin_high[oct]; i++) {            // retreive this octave BIN values and multiply each with their a_weigthing factor
            v[i] = fft1024_1.read(i) * sqrt(a_weight[i]);
            magn[oct] = magn[oct] + sq(v[i]);                     // sum their squared value, since they are uncorrelated signals
          magn[oct]   = sqrt(magn[oct]);                          // squareroot the SUM value, since they are uncorrelated signals
          magn_f[oct] = magn_f[oct] + magn[oct];                  // add value to average holder
        n      = n+1;                                             // keep track of number of averages = n
        if (n == ave) {                                           // once number of averages is reached
          Serial.println(999.99,2); // debug thingie
            magn_f[oct]  = magn_f[oct]/ave;                       // divide by number of averages
            dB_oct[oct]  = log10f(magn_f[oct]) * 20  + 120.20;    // convert to dB
            Serial.println(dB_oct[oct],2);
            magn_f[oct] = 0;
            dB_oct[oct] = 0;
          n         = 0;                                          // reset averaging counter
    and a Matlab visualistion routine :
    % MATLAB code for octaveband SPL meter, works with teensy 3.6 via serial com port connection, adjust COM port for your system
    clearvars
    close all
    dBoct = 60*ones(1,8);
    figure(1)
    clf
    set(gcf,'Position',[317         349        1418         650])
    bh1 = bar(dBoct);
    grid on; grid minor;
    ylim([10 121])
    xlim([0.5 8.5])
    ylabel 'dB]'
    xlabel 'octaveband'
    title 'Octaveband meter met Teensy 3.6'
    set(gca,'FontSize',24)
    hold on
    plot([0 9],[94 94])
    for n=1:8
        th(n)=text(n,100,num2str(dBoct(n)),'FontSize',20)
    end
    drawnow
    %seriallist
    s = serial('COM6', 'BaudRate', 115200);
    fopen(s);
    formatSpec = '%f';
    disp('serial port connected')
    global KEY_IS_PRESSED
    KEY_IS_PRESSED = 0;
    gcf
    set(gcf, 'KeyPressFcn', @myKeyPressFcn)
    while ~KEY_IS_PRESSED
        mes = fscanf(s,formatSpec);
        if mes == 999.99
          for n=1:8
                dBoct(n) = fscanf(s,formatSpec);
                th(n).String = num2str(dBoct(n));
          end
          bh1.YData = dBoct;
          drawnow
        end
    end
    disp 'closing serial connection'
    fclose(s);
    clear s
    disp 'closed'
    function myKeyPressFcn(hObject, event)
    KEY_IS_PRESSED  = 1;
    disp('key is pressed')
    end
    Here's the Matlab figure I use to visualize the octaveband SPL meter. Note the high noisefloor for the high freq bands. The high noisefloor is also present when using a software simulated sine signal .. how's that possible?
Name:	teenst octave band SPL meter.jpg
    Well, I found out through some measurement of raw spectra that is putout by the AudioAnalyzeFFT1024 , that it puts out a 16bit value. Now I understand that the ADC uses 16bit data, but why would the output of an FFT not be a float? Since a 1024 point FFT spreads the energy over 512 frequency bins, and the broadbandinput it 16bit, atleast 16+9=25bits are needed to avoid throwing away usefull resolution.
    can the output of AudioAnalyzeFFT1024 be set to float?
    Looking into the .cpp file that is called from the library, I see that the output of the CMSIS fft is a UNIT32, but it is squarerooted just before assigning it to the output. If I am not mistaken, if you squareroot a 32bit interger, you are left with 16bit.. hence the 16bit resolution of the AudioAnalyzeFFT1024
    Oct 2019
    10
    I am building a wearable sound level meter for some International Year of Sound events (in 2020), sponsored by ASA. I tried out some of the code above, but couldn't get it to reliably track my Class 1 SLM, so I started from scratch with a different approach. I thought it may be of interest to you guys, even though this thread has been dormant for a few months.
    First, I'm using a MEMS microphone with I2S output.
    I used the GUI to build a filter bank with octave-band filters from 31.5 Hz to 8 kHz. These are fed to RMS detectors. The outputs of the RMS detectors are scaled for the A-weighting corrections, and accumulated. These are then log averaged over the measurement interval (500 ms in the code below) to produce LAeq over this interval.
    I've done some experiments with the filters to check linearity with the pink noise source, and it's good enough for what I'm doing. It tracks very well with the real SLM from the low 20s up to over 100 dBA. Within 1 dB.
    This will be connected to a large display that a person will be able to wear in various environments to raise awareness of sound levels, both high and low.
    #include <Arduino.h>
    AudioSynthNoisePink      pink1;          //xy=117,268
    AudioInputI2S            i2s1;           //xy=118,193
    AudioMixer4              mixer1;         //xy=260,240
    AudioFilterStateVariable filter31;       //xy=456,195
    AudioFilterStateVariable filter63;       //xy=456,235
    AudioFilterStateVariable filter125;      //xy=456,275
    AudioFilterStateVariable filter250;      //xy=456,315
    AudioFilterStateVariable filter500;      //xy=456,355
    AudioFilterStateVariable filter1000;     //xy=456,395
    AudioFilterStateVariable filter2000;     //xy=456,435
    AudioFilterStateVariable filter4000;     //xy=456,475
    AudioFilterStateVariable filter8000;     //xy=459,528
    AudioAnalyzeRMS          rms31;          //xy=630,195
    AudioAnalyzeRMS          rms63;          //xy=630,235
    AudioAnalyzeRMS          rms125;         //xy=630,275
    AudioAnalyzeRMS          rms250;         //xy=630,315
    AudioAnalyzeRMS          rms500;         //xy=630,355
    AudioAnalyzeRMS          rms1000;        //xy=630,395
    AudioAnalyzeRMS          rms2000;        //xy=630,435
    AudioAnalyzeRMS          rms4000;        //xy=630,475
    AudioAnalyzeRMS          rms8000;        //xy=630,515
    AudioConnection          patchCord1(pink1, 0, mixer1, 1);
    AudioConnection          patchCord2(i2s1, 0, mixer1, 0);
    AudioConnection          patchCord3(mixer1, 0, filter31, 0);
    AudioConnection          patchCord4(mixer1, 0, filter63, 0);
    AudioConnection          patchCord5(mixer1, 0, filter125, 0);
    AudioConnection          patchCord6(mixer1, 0, filter250, 0);
    AudioConnection          patchCord7(mixer1, 0, filter500, 0);
    AudioConnection          patchCord8(mixer1, 0, filter1000, 0);
    AudioConnection          patchCord9(mixer1, 0, filter2000, 0);
    AudioConnection          patchCord10(mixer1, 0, filter4000, 0);
    AudioConnection          patchCord11(mixer1, 0, filter8000, 0);
    AudioConnection          patchCord12(filter31, 1, rms31, 0);
    AudioConnection          patchCord13(filter63, 1, rms63, 0);
    AudioConnection          patchCord14(filter125, 1, rms125, 0);
    AudioConnection          patchCord15(filter250, 1, rms250, 0);
    AudioConnection          patchCord16(filter500, 1, rms500, 0);
    AudioConnection          patchCord17(filter1000, 1, rms1000, 0);
    AudioConnection          patchCord18(filter2000, 1, rms2000, 0);
    AudioConnection          patchCord19(filter4000, 1, rms4000, 0);
    AudioConnection          patchCord20(filter8000, 1, rms8000, 0);
    uint8_t prescale = 20;  // Prescaler for RMS detector output
    float offset = 91;    // Microphone calibration
    float Awt = 0;
    float AwtAccum = 0;
    float LAeq = 0;
    uint8_t n = 0; // number of measurements to average
    unsigned long sampletime = 500;  // Sampling interval
    unsigned long starttime;
    void setup(){
      AudioMemory(20);
      pink1.amplitude(0.01);  // for testing filters
      mixer1.gain(0,1);  // microphone level
      mixer1.gain(1,0);  // pink noise level
    // Setup filter center frequencies and Q (1 octave)
      filter31.frequency(31.5);
      filter31.resonance(1.414);
      filter63.frequency(63);
      filter63.resonance(1.414);
      filter125.frequency(125);
      filter125.resonance(1.414);
      filter250.frequency(250);
      filter250.resonance(1.414);
      filter500.frequency(500);
      filter500.resonance(1.414);
      filter1000.frequency(1000);
      filter1000.resonance(1.414);
      filter2000.frequency(2000);
      filter2000.resonance(1.414);
      filter4000.frequency(4000);
      filter4000.resonance(1.414);
      filter8000.frequency(8000);
      filter8000.resonance(1.414);
    void loop(){
      n = 0;
      AwtAccum = 0;
      starttime = millis();  // Get initial time
      // Loop and accumulate values during sampling interval
      while((millis() - starttime) < sampletime){
        // Wait untl data avaiable from all octave-band filters
        if (
                rms31.available() &&
                rms63.available() &&
                rms125.available() &&
                rms250.available() &&
                rms500.available() &&
                rms1000.available() &&
                rms2000.available() &&
                rms4000.available() &&
                rms8000.available()
    // Apply A-weighting and accumulate squared Vrms values from each band
            Awt = 0;
            Awt += sq(rms31.read()   * prescale * 0.01071519 );  //squared Vrms
            Awt += sq(rms63.read()   * prescale * 0.04897788 );
            Awt += sq(rms125.read()  * prescale * 0.15667510 );
            Awt += sq(rms250.read()  * prescale * 0.37153523 );
            Awt += sq(rms500.read()  * prescale * 0.69183097 );
            Awt += sq(rms1000.read() * prescale              );
            Awt += sq(rms2000.read() * prescale * 1.1481536  );
            Awt += sq(rms4000.read() * prescale * 1.1220185  );
            Awt += sq(rms8000.read() * prescale * 0.8810489  );
    // At this point, Awt is a sum of squared voltages.  Total voltage
    // would be sqrt of this value.
            AwtAccum += Awt;  // Accumulates sums of sqaured voltages from each loop
            n++;  // Increment average counter for later averaging
          delay(1);  // Won't loop without this for some reason
    // Power is proportional to V^2.  AwtAccum is a sum of V^2 values.
    // Average power is sigma(P)/n, equivalent to sigma(V^2)/n.
    // 10Log(sigma(V^2)/n) = average SPL
    // offset = mic calibration
        LAeq = round(10 * log10f(AwtAccum / n) + offset);
        Serial.println(LAeq,0);  // Report 0 decimal places
    Cool! will look at it when I get home
    The code looks elegant and simple. Do you run this on a Teensy 4? How much processor time % are you using?
    Could you tell me what discrepenties you encoutered with my FFT approach?
    Oct 2019
    10
    It's running on a 3.2. AudioProcessorUsage() reports 25.8.
    With your code, I just couldn't get linearity between levels. I didn't make notes, but if I calibrated to, say, 40 dBA and then increased the signal to 80, it didn't track well. I'm not sure why. One concern I had is that the bin size of 43 Hz is pretty course at low frequencies. I also couldn't figure out if an RMS level is calculated. Lp is of course based on RMS pressure, and thus RMS voltage. Maybe I'm just missing that in the code.
    BTW, the A-weighting multipliers I'm using are 10^(L/20) where L is the standard correction in dB for each octave band.
    Oct 2019
    10
    This is the rig:
Name:	2019-12-20 11.14.00.jpg
    The set up looks tidy. And nice to have class 1 meter.
    I will go through my code again.. might have made an eroor somewhere.
    Thanks for showing your project!
    Oct 2019
    10
    I've added an LED matrix display with octave-band bar graph (dBZ) and A-weighted numerical display.
    Code:https://github.com/ereuter/IYS-SLM/blob/master/main.cpp
    Oct 2015
    Vermont, USA
    209
    I'm part of the team that makes Tympan, which at its heart is a Teensy 3.6 with an audio codec (and bluetooth module, and LiPo battery plus charger circuit). I did a single-channel and two-channel sould level meter:
    * One Chan: https://github.com/Tympan/Tympan_Lib...oundLevelMeter
    * Two Chan: https://github.com/Tympan/Tympan_Lib...velMeter_2Chan
    My example code uses audio classes in the Tympan_Library. You can use these classes to do A-weighting or C-weighting. You can also choose between SLOW or FAST time averaging. As a result, you've got a bit of flexibility. Do be aware, however, that these audio classes use floating point arithmetic (hence the "_F32" at the end of the class names), so you would have to use a Teensy 3.5/3.6 or 4.0.
    Perhaps you'll find the software library (or the Tympan hardware) helpful as you implement your own SLM.
    Chip
    Oct 2015
    Vermont, USA
    209
    However it is that you implement the software for your sound level meter, the hard part (IMO) is calibrating the device. There are many choices:
    * You can decide to use a single-point pure-tone calibration (1kHz tone at a known SPL)
    * Or, you can do a single-point filtered-noise calibration (1/3rd octave filtered noise centered at 1 kHz, at a known SPL)
    * Or, you could do a frequency-dependent calibration in octaves or in 1/3rd octaves (at known SPL)
    Note that the enclosure that you use to house your mics will likely change the frequency response and sensitivity of the mics (and sensitivity versus angle of incidence), so be sure to calibrate the device in its final packaging.
    Chip
    Oct 2019
    10
    Thanks, Chip. I'm an acoustics professor and consultant, and have several Class 1 SLMs and calibrators at my disposal.
    Also, thanks for the link to the library. I'll take a look.
    Oct 2015
    Vermont, USA
    209
    Great! I have this kind of equipment, too. With this equipment, I thought that calibration would be trivial. I was wrong. My simple enclosure caused a lot of problems. Acoustic resonances and shadowing. Even once I figured out those issues, the noise generated by handling my device (or by wind on my device) was really hard to manage.
    So, I'm sure that you know all this....I guess that this message is merely a gentle reminder that seemingly-simple things can be the most challenging. In my case, the SLM algorithm/software was the easy part and the enclosure/calibration proved to be the hard part. YMMV.
    Chip
    Dec 2016
    6
    a_weight[] coefficients?
    How did you calculate the A-weight coefficients? I used formula from https://en.wikipedia.org/wiki/A-weighting
    and getting different values.
    Oct 2015
    Vermont, USA
    209
    My code for computing the IEC1672 coeff is here:
    https://github.com/Tympan/Tympan_Lib...ting_IEC1672.h
    And here:
    https://github.com/Tympan/Tympan_Lib...EC1672_coeff.h
    If you find a discrepancy, I'd be super happy to hear of it!
    Chip
    Dec 2016
    6
    Cheers for prompt answer, I wrote a python script to generate a_weight[] variable.
    import math
    coefficients_number = 512
    step = 43
    start = 43
    end = coefficients_number * step
    results_array = []
    print '// this file is generatet by phyton script a-curve-gen.py'
    print '// a-weight curve size ',coefficients_number,' coefficients with ',step, 'Hz resolution'
    print '// start: ', start, ' end: ', end, 'step: ', step
    print ''
    i = 0
    for f in range(start, end+1, step):
        coeff = (12194**2 * f**4) / ( (f**2 + 20.6**2) * math.sqrt( (f**2 + 107.7**2) * (f**2 + 737.9**2) ) * (f**2 + 12194**2) )
        results_array.append(coeff)
        i = i + 1
    # convert array to string
    results_string = ', '.join([str(elem) for elem in results_array])
    print 'float a_weighting_curve[512] = {'
    print results_string
    print '};'
