Hum ...
Of course I will buy spare ! Lot of them ( currently I only have 3 board but I can sacrifice one to test!! )
But before trying anything I want to fully understand each step of what I am trying to do.
And currently I don't understand the flash_write(const uint16_t *code, uint32_t addr, uint32_t data) function...
I believe that I understand the FSEC register, I read what bytes I should overwrite in the datasheet ... => 0xEC ( MEEN part of FSEC register set to 10 )
I took the register address you gave => 0x40c
So if I understood well the theory I just should put the correct data ( 0xEC ) in the correct spot of the flash ( address 0x40c ) ...
To do so I should use the function that I don't fully understand yet : flash_write ...
What part seems not correct according to you ? My usage of the flash_write function with the " do_flash_cmd[] = {
0x2380, 0x7003, 0x7803, 0xb25b, 0x2b00, 0xdafb, 0x4770}; " wich is what is writed in the eeprom.c ??? Or the two informations I plan to use: address and data ?
