Results 1 to 8 of 8
Thread: Burned teensy 3.1, can I replace mk20dx256?
    May 2016
    3
    Hello!
    I have burned 2 teensy boards. One was working just fine, but something nasty happened during copter crash, so board is fired, last one I burned 10 minutes ago with a wrong transistor connecting (12v on a digital pin).
    I can get one mk20dx256 brand new and (hope so) it's possible to place it instead of original. Is it worth a try? Will it work?
    Nov 2015
    Wales
    579
    ... I've never actually considered that. Yes in theory you can
    May 2016
    3
    Quote Originally Posted by Xenoamor View Post
    Thanks!
    Local sellers in Russia are really so greedy that they selling Teensy twice as much as here. So for me it's really a chance...
    Nov 2015
    Wales
    579
    We have 50+ dead teensys so I'll probably give it a try when I get a chance
    May 2016
    3
    WOW! In your case, I would definitely give it a try. If you will have some results, please, write a word here, it's really interesting!
    Nov 2015
    Wales
    579
    We're pretty swamped at the moment so we've taken to calling them high tech fuses as we're changing them so often. High voltage hot plugging doesn't play well with electronics
    Jun 2013
    So. Calif
    2,828
    We have 50+ dead teensys ...
    Wow. How'd that happen?
    25,492
    First, remove the MK20 chip and visually inspect to check if any of the pads or traces were destroyed in the desoldering process.
    Then apply regulated 3.3V power, to the 3.3V pin and GND, and check if the MINI54 (Teensy 3.1) or MKL02 (Teeensy 3.2) is still alive. Watch the DC voltage on PROGRAM and RESET. Both should be at 3.3V normally, and both should go low to nearly 0 volts when you hold the pushbutton.
    If both those signals respond, solder a new (blank) MK20 chip. If the pins are soldered properly, your Teensy should work again.
    If the pads or traces are destroyed or the MINI54 or MKL02 doesn't respond, discard the board. Don't waste a perfectly good MK20 chip.
