Results 1 to 6 of 6
Thread: DSP Instructions
    DSP Instructions
    I'm trying to code a hilbert transform in DSP, to implement a single-signal direct conversion receiver. This seems to be within the realm of the possible on the Teensy 3.2 ... IF I can use DSP instructions (not the pre-built library calls). Are these available? I guess I don't fully understand the development framework for the ARM architecture. I'm trying to relate using the AVR's as an example and something's not clicking.
    Gary Tennyson
    Jun 2013
    So. Calif
    2,828
    Not sure about GCC (Arduino) using DSP instructions, or by default, versus other compilers like IAR, Keil.
    If you use floating point, the current Teensy's don't have that ARM feature. Next one will. May not matter to your app.
    Don't most such transforms use a lot of transcendental functions?
    AVR... well, that's a light-year away from ARMs.
    1,213
    Some of the functions in the Audio library use DSP functions. These inline functions are defined in dspinst.h which is in arduino-1.6.9\hardware\teensy\avr\libraries\Audio\utility\ .
    The synth_sine.cpp file in the audio library, for example, uses functions such as multiply_32x32_rshift32_rounded() and multiply_accumulate_32x32_rshift32_rounded(). Each of these is defined in dspinst.h and each usually compiles down to one DSP instruction and all DSP instructions execute in a single cycle.
    There's a PDF document which describes these instructions but, inevitably, I can't find it right now.
    Try this link: http://infocenter.arm.com/help/index.../CIHJJEIH.html
    Select Multiply and Divide Instructions.
    Pete
    Senior Member adrian's Avatar
    Oct 2015
    Wellington, NZ
    504
    I thought an older version of the CMSIS DSP library ran on teensy 3.x ... for example that is where the heavy lifting for the FFT routine originates from in the audio library ...
    2,507
    Quote Originally Posted by garytennyson View Post
    Gary Tennyson
    first question: how do you like to do the Hilbert transform? (FFT or FIR). I would suggest FFT, as it is then trivial, especially if you combine with bandpass filter.
    FFT implementation is build in. However, due to fixed point DSP scaling is somewhat tricky fot FFT-IFFT combo and need some experiments.
    second question: are you happy with 16 bit? then Teensy 3.2 has optimized DSP instructions. If not, depending in your timing requirements T3.2 may be too slow (multi-MHz direct conversion may be too much, but I have not done the Maths)
    21,288
    This thread is a perfect example of why you ought to explain your project and goals, rather than just ask a narrow tech question.
    But to answer your specific question "can use DSP instructions.... Are these available?", yes, they are available. This message has more info about how to really use them.
    https://forum.pjrc.com/threads/26767...ll=1#post58616
