Page 2 of 63 FirstFirst 1 2 3 4 12 52 ... LastLast
Results 26 to 50 of 1559
Thread: K66 Beta Test
  1. #26
    Nov 2015
    Wales
    579
    Though I suspect that for smart homes, the market has probably to wi-fi over wired ethernet.
    Ethernet to wifi adaptors exist. Or a USB wifi adaptor host could be written but I completely agree with you
  2. #27
    Senior Member fms1961's Avatar
    Jul 2015
    Northern Germany
    148
    Though I suspect that for smart homes, the market has shifted to wi-fi over wired ethernet.
    Indeed, but for development purposes, you will be happy to have an ethernet alternative to avoid the "chicken-and-egg-problem".
  3. #28
    Senior Member pictographer's Avatar
    May 2013
    San Jose, CA
    627
    Does this 'Beta Device' have a usable/official name?
    My preference is simple names. "Teensy 4.0" would be my favorite. "Teensy F1" if you want something more different than "Teensy 3.x". Not a fan of '++' because it is reminiscent of 1984 and C++, it's a little harder to type, maybe harder to search for, and versioning gets ugly, e.g. Teensy++ 4.2 with confusion regarding which other PJRC product is most similar.
  4. #29
    Feb 2014
    Colmar, France
    1,626
    I really like the idea of a Teensy F1 - like Formula 1
  5. #30
    Cheltenham, UK
    41
    Only use F1 if you want to be sued by Bernie
  6. #31
    1,481
    Well, my vote for names is for Teensy K66, and it's cheaper sister, Teensy K64
    The Etherenet, me thinks, will require a PHY chip/shield -- a power consumer. The mbed K64 (@120MHz) that I did some pre-K66 testing on has a PHY chip on board, and the lwIP Ethernet stuff worked just fine, though it uses mbed RTOS to manage all the TCP/IP tasks, see K64 testing, which includes some single-precision hardware float tests, and RNG and CAU tests.
  7. #32
    1,481
    NXP/Freescale has library for the K66/K64 crypto acceleration unit (CAU), but it's GNU assembler (.s). I got it compiled for the mbed, and just now tried compiling in the Arduino IDE in anticipation of the K66. Changed names to .S, but IDE wasn't happy with the .include xx.hdr file in the .S files. I assume the build commands needs a -I for assembler includes, sigh. The other thought was using the lib (cau.a) that I built for the mbed, but I don't know how to tell the IDE to use a .a file ? Any hints?
    I ultimately just pasted the included .hdr file in each of the .S files to get the CAU sketch to compile.
    The NXP/Freescale library only provides API to access the transform function for each of the crypto operations, additional coding would be required to manage multiple blocks, pad the hashes, and provide the various encryption modes (CCB, etc)
    EDIT: an alternate build solution worked. i copied libcau.a to hardware/tools/arm/arm-none-eabi/lib/ and in boards.txt changed to
    teensy35.build.flags.libs=-larm_cortexM4lf_math -lm -lcau
  8. #33
    17,624
    Quote Originally Posted by Xenoamor View Post
    Oh wow, I'm really excited for this one! 180MHz rated... I wonder how far we can push it!
    Good question. I did a little experimenting with 192 MHz, which seemed to work fine.
    The chip actually has a special HSRUN mode for faster than 120 MHz. Freescale isn't very specific, but it appears to slightly increase the internal voltage regulation inside the chip. Like the VLPR modes, HSRUN has some restrictions about turning more things on/off. So far I haven't adapted code to follow these closely. This is one of several areas that'll take some time to get everything implemented fully.
  9. #34
    17,624
    Actually, the name is one pretty big unresolved question at this point.
    First, I want to put the kibosh on "4.0". This is very much a 3.x product. Sure, we're getting a big step up in performance, a FPU and a few awesome new peripherals, but this is still a Cortex-M4 that very similar to Teensy 3.2 with excellent compatibility. Perhaps "4.0" will be meaningful when we get a Cortex-M7 in 65 or 40 nm silicon.
    Second, we're going to make this board in 2 versions, one with the K66 chip and another with a K64 chip. The main reason is 5V tolerance, which the K64 has but K66 does not. Other than max speed, memory size, and the extra USB host port, these 2 chips are very similar in feature set. So 2 names are going to be needed.
    I've been leaning towards Teensy 3.4 and Teensy 3.5, which keeps 3.3 available for a possible upgrade of 3.2 to a faster chip but keeping the same 28 pin form factor. Earlier I was thinking "Teensy+ 3.x" and "Teensy++ 3.x".
    Now's the time to go crazy with name ideas.
  10. #35
    6,444
    Given the MCU has K66 chip and K64 chip how about: T_3.6 (K66) and T_3.4 (K64)?
    That leaves room for a 5V T_3.4 upgrade to a T_3.5 as well?
  11. #36
    Jul 2013
    Colorado
    86
    +1 I was about to suggest the same.
  12. #37
    Senior Member Ben's Avatar
    Jul 2013
    Germany
    401
    Teensy 3.x HE (High end)
    or
    Teensy 3.x HP (High performance)
    You could start with 3.0 HE for a fresh start or 3.2 HE (or HP) to keep it consistent with the current T3.2, and you won't run into already-taken names when upgrading the T3.2
    The K64-based models could be named Teensy 3.x HE 5V or Teensy 3.x HP 5V.
  13. #38
    6,444
    Quote Originally Posted by fretless_kb View Post
    Since PJRC already has history with the T2 and T++2 :: perhaps T++_3.6 and T++_3.4 would be better?
  14. #39
    Teensy 3.4, 3.6
    I agree- I like the idea of something like "Teensy 3.4". Simple and straightforward.
    I won't say that the ++ nomenclature is double-plus-ungood, exactly, but it seems awkward to me.
  15. #40
    Feb 2014
    Colmar, France
    1,626
    I'd really like to see the updated boards.txt. Knowing about available F_CPU and more important, F_BUS values would greatly help me to prepare my test environment...
  16. #41
    3,535
    I like the simple 3.4 and 3.6. Or alternatively something like 3.45 and 3.4P for 5v versus performance.
  17. #42
    Germany NRW
    4,438
    https://github.com/PaulStoffregen/co...y3/mk20dx128.c
    look for __MK66FX1M0__
    You can make your own boards.txt..
  18. #43
    Germany NRW
    4,438
    A name that indicate the 5V tolerance /3 Volt only would make sense - easier for newbies and less questions (less destroyed teensys...)
    edit: something like Teensy 3.3 3V, Teensy 3.4 5V ?
  19. #44
    2,718
    I still think users will get confused, as it still runs at 3.3v, just the digital input pins can handle 5v. If you try to run ws2812b/neopixel or apa102/dotstar LEDs directly on the Teensy (or anything else that needs 5v data signal), it may not work. I tend to like KurtE's suggestion, perhaps adding a V or F suffix, i.e.
    • 3.4V (the K64 product that is 5v tolerant);
    • 3.6F (the K66 product that is fast).
    Or maybe:
    • 3.64;
    • 3.66.
  20. #45
    1,747
    For me, these names (Teensy 3.4 and Teensy 3.5) are fine, there is no real need for more complicated naming.
  21. #46
    6,444
    Easily confusing - T_3.2 compatible - but in a ++ size.
    The more powerful one can't handle high 5V, but the lower speed unit is 5V tolerant like T_3.
    At least having some ref to the CPU Model in the name K66 and K64 gives some SOLID reference when looking at MK64FX512 or MK66FX1M0 in the sources.
    Also not having a T_3.5 with a '5' in for the not 5V tolerant makes sense, and models T_3.6 and over could all be the 3.3V only variants.
  22. #47
    Jul 2013
    Germany
    401
    I added links to the relevant datasheets in Post #3 https://forum.pjrc.com/threads/34808...l=1#post106275
    Can someone please confirm I picked the correct PDFs?
  23. #48
    17,624
    Originally I was thinking "++", but lately I've been leaning towards simplicity. Definitely not wanting to make the number complex with a suffix or extra digits.
    Still undecided....
    Quote Originally Posted by Ben View Post
    Yes, those are the right ones.
    I'll post a boards.txt file next week, when we ship the first 10 boards.
    But F_BUS isn't in boards.txt. It's in kinetis.h, which you already have.
  24. #49
    Germany NRW
    4,438
    @paul, in mk20d128, you write:
    "// config divisors: 180 MHz core, 60 MHz bus, 25.7 MHz flash, USB = not feasible"
    Isn't it possible to use the IRC48 as clock for USB ?
    Edit: The new chips are a chance to switch to higher F_BUS... some time ago we learned that F_BUS can be overclocked much much more..
    Edit: I'll try to get 240MHz or more out of this beast..
  25. #50
    1,481
    EEPROM looking at eeprom.c, it appears K64/K66 will have 4KB of flash EEPROM
