95 E10 B10 62 PTB16 DISABLED PTB16 SPI1_SOUT UART0_RX FTM_CLKIN0 FB_AD17 EWM_IN
64 K9 PTA12 CMP2_IN0 CMP2_IN0 PTA12 CAN0_TX FTM1_CH0 RMII0_RXD1/MII0_RXD1 I2C2_SCL I2S0_TXD0 FTM1_QD_
first attempt at an ethernet shield... Submitted it to OSH Park just this morning and ordered all the missing parts from Digikey. While I imagine it'll be a year until we have really good, usable networking, before absolutely finalizing the beta test I want to receive just 1 ethernet packet, even if only a broadcast ARP and ICMP (ping) datagram. There'll be a couple extra boards, if anyone *really* wants to dig into the low-level ethernet stuff.
I've long thought that it would be wise to build educational boards with a few pins that have extra protection (eg, a resistor and a BAT54S). Then encourage beginners to use these pins.
Mine is in the local mail truck and should arrive in a few hours. I've hacked a boards.txt, but I assume Paul will release something official soon ...I got my Beta-testboard !
It is luxurious!
2K performance run parameters for coremark.
CoreMark Size : 666
Total ticks : 16824
Total time (secs): 16.824000
Iterations/Sec : 356.633381
Iterations : 6000
Compiler version : GCC4.8.4 20140725 (release) [ARM/embedded-4_8-branch revision 213147]
Compiler flags :
Memory location : STACK
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcmatrix : 0x1fd7
[0]crcstate : 0x8e3a
[0]crcfinal : 0xa14c
Correct operation validated. See readme.txt for run and reporting rules.
CoreMark 1.0 :[B] 356.633381[/B] / GCC4.8.4 20140725 (release) [ARM/embedded-4_8-branch revision 213147] / STACK
It is luxurious!
Here's a boards.txt file to use.
As you could guess from "-DTEENSYDUINO=129", this is meant to be used with Teensyduino 1.29-beta2.
Unless Paul changes his mind, looks to me that it is all right here: https://forum.pjrc.com/threads/34808-K66-Beta-Test?p=106782&viewfull=1#post106782 "Please keep all the beta test info only on this forum thread"Should we coordinate library testing / porting with a list in this thread or via github-issues?
Teensy did not respond to a USB-based request to automatically reboot.
@defragster: it looks from the core files that there is no suitable divider for the USB clock when run at 180MHz.
Happy Birthday !
180MHz: Maybe there is a trick and the IRC48 clock canbe used somehow.
just for fun, i tried 240 MHz... works.. (but not with SIM_CLKDIV1_OUTDIV4(8); instead value 7 works (?))
Edit:
...but F_BUS with 240MHz does not work Oh, there is indeed a limit..
