CorVanEssen
I just started my first Teensy project (hurray!). I've soldered the Teensy 3.2 to the prop shield and a small 8 Ohm speaker and so far I have managed to test the orientation demo and for sound I successfully tested the Talkie examples.
So everything seems to be in good working order on the hardware side.
I tried to copy a RAW file (converted with sox) to the flash memory with the rawfile-uploader python script after uploading the CopyFromSerial script. This says it has successfully copied the file. But when I run the ListFiles script it I only get the message: 'All Files on SPI Flash chip:' and then nothing.
The LED on the Teensy flashes fast when running the CopyFromSerial script and then burns continuously. It doesn't go off after the supposed copying.
(do I need to change something in the CopyFromSerial script?)
At this point I don't know how to continue so any help is very much appreciated.
For completion, this the version I used for the python script. I only changed the memory size to 8.
#!/usr/bin/python
# Uploads raw audio files to Teensy + Audio board with SPI Flash on board. To use this program, first
# load the 'CopyFromSerial' example sketch. When it first runs, it will format the SPI flash chip
# (this may take a long time for larger chips; a 128MB chip that I am using can take almost 10 minutes,
# but smaller 16MB ones should be faster).
# While the chip is being formatted, the LED (pin 13) will toggle at 1Hz rate. When the formatting is
# done, it flashes quickly (10Hz) for one second, then stays on solid. When nothing has been received
# for 3 seconds, the upload is assumed to be completed, and the light goes off.
# You can start this program immediately upon plugging in the Teensy. It will buffer and wait until
# the Teensy starts to read the serial data from USB.
import serial, sys, os, time
if (len(sys.argv) <= 2):
print("Usage: '" + sys.argv[0] + " <port> <files>' where:\n\t<port> is the TTY USB port connected to Drum Master\n\t<files> is a list of .RAW files (bash globs work).")
sys.exit()
#Special bytes
BYTE_START = "\x7e"
BYTE_ESCAPE = "\x7d"
BYTE_SEPARATOR = "\x7c"
#Flash size (in MB). Change this to match how much space you have on your chip.
FLASH_SIZE = 8
totalFileSize = 0;
for i, filename in enumerate(sys.argv):
if (i >= 2):
totalFileSize = totalFileSize + os.path.getsize(filename)
flashSizeBytes = FLASH_SIZE * 1024 * 1024
if (totalFileSize > flashSizeBytes):
print("Too many files selsected.\n\tTotal flash size:\t" + "{:>14,}".format(flashSizeBytes) + " bytes\n\tTotal file size:\t" + "{:>14,}".format(totalFileSize) + " bytes")
sys.exit()
ser = serial.Serial(sys.argv[1])
print("Uploading " + str(len(sys.argv) - 2) + " files...")
if (i >= 2):
startTime = time.time();
sys.stdout.write(str(i - 1) + ": ")
sys.stdout.write(filename)
sys.stdout.flush()
f = open(filename, "rb")
fileLength = os.path.getsize(filename)
try:
encoded = []
#Start byte
encoded.append(BYTE_START)
#Filename
for byte in os.path.basename(filename):
encoded.append(byte)
#End of filename
encoded.append(BYTE_SEPARATOR)
#File length (uint32_t)
encoded.append(chr((fileLength >> 24) & 0xFF));
encoded.append(chr((fileLength >> 16) & 0xFF));
encoded.append(chr((fileLength >> 8) & 0xFF));
encoded.append(chr((fileLength >> 0) & 0xFF));
#Binary data, with escaping
for byte in f.read():
if byte == BYTE_START or byte == BYTE_ESCAPE:
encoded.append(BYTE_ESCAPE)
encoded.append(chr(ord(byte) ^ 0x20))
else:
encoded.append(byte);
#Write end of data byte
ser.write("".join(encoded))
finally:
f.close()
endTime = time.time();
print(" (" + str(round(fileLength / 1024 / (endTime - startTime), 2)) + " KB/s)");
print("All files uploaded")
