Hi!
On the teensy 3.2 (which I read has a more powerful voltage regulator which I need for an esp8266-01) the side 3.3v pin has limited current, but the back 3.3v pin has more. In prototyping I use the back pin and it is all fine. The Teensy 3.1 eagle components I have seen mostly* connect the two 3.3v which I guess is wrong? Is it safe to connect them?
*The SparkFun component has separate pins as "3v" side pin, and "3.3v" back pin which I guess is correct.
